eManage Ulimate--Almost here..and MUCH IMPROVED!
Old Oct 14, 2005 | 05:47 AM
  #541
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Originally Posted by folex187
Here's another question to the people who have been running this for awhile:
Vehicle Speed Map- Anyone had success with it? It is intended to correct load problems. For instance, if your car was tuned for lets say 4th gear you might run rich in the low gears and lean in 5 or 6. The Speed map allows you to compensate for this.
I would like to use the A/F target map to adjust the Speed map for a "complete" tune. Any thoughts on this idea?
Yes it can do this, but we're having trouble finding a suitable ECU speed signal wire, that we can input and output through the EU.
Old Oct 14, 2005 | 08:38 AM
  #542
350zDCalb's Avatar
350zDCalb
builtZmotors
Default Lost coolant temp signal--any ideas????
my EU would display coolant temp on the datalogger...yesterday, after putting in a koyo radiator, i went to start my car and datalog and the coolant temp wasn't displayed on the datalogger...so, i went into the checklist and checked water temp..it pulled it up on the datalogger, but it acts like there is no signal????
any ideas????
THX
Old Oct 14, 2005 | 11:44 AM
  #543
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
I would try looking up the temp sensor harness location in the service manual.
Its probably something as simple as a disconnected harness.
Old Oct 14, 2005 | 03:55 PM
  #544
350zDCalb's Avatar
350zDCalb
builtZmotors
wouldnt that be the same wire that controls the oem water temp gauge on the dash?. cause that one works fine, just no signal for EU....
as far as i know, wires are still intact (dont want to go under dash, waiting to see if anybody has imput on some sort of setting that ay have changes, software wise, not physical wiring issue??)
Old Oct 15, 2005 | 02:54 PM
  #545
KTaylor's Avatar
KTaylor
Sorry if this is a repost but I am looking into to getting the EU and Profec E-01 and heard that these two are not compatible. Is this true? Thanks
Old Oct 15, 2005 | 03:00 PM
  #546
350zDCalb's Avatar
350zDCalb
builtZmotors
true, the profec e-01 will not work with the EU....get the EU and talk to sharif about what Blitz has to offer as far as boost controllers
Old Oct 15, 2005 | 03:10 PM
  #547
KTaylor's Avatar
KTaylor
ok thanks. I also heard that greddy might be coming out with a new version that would work with the EU. if thats true i might wait a little. Do u kno anything bout that?
Old Oct 16, 2005 | 02:28 PM
  #548
roncfpz's Avatar
roncfpz
I believe it does but in a limited capacity; boost controller only. Sharif can certainly expand on the limitations. I certainly hope Greddy comes out with a new e-01 that is completely compatible with EU.
Old Oct 16, 2005 | 05:02 PM
  #549
Sharif@Forged
Forged Performance
That correct. The current Profec e-01 doesnt interface with the EU as it did with the blue. It can still do boost control, and some basic logging, but there is no way to connect is to the EU. Greddy is working on a replacement for the e-01 that will be compatible with th EU, but its many months out..no ETA.
Todd, I assume you always had coolant tempt wired into your EU..correct? If so, maybe a connector of some kind was cut/disconnected when you removed your stock radiator fan?? Just a thought. I assume your coolant temp guage on the dash is working...correct?
Just make sure your temp sensor configuration wasnt accidentally changed in the EU parameters area.
Old Oct 16, 2005 | 05:33 PM
  #550
350zDCalb's Avatar
350zDCalb
builtZmotors
so, i just checked continuity between the coolant wire from the ecu (#39 i believe) and the corresponding pin on the emanage harness...wire is fine
then i started up the car and played with parameteres....for some reason, when the laptop first communicates with the EU, coolant temp was not displayed on the datalogging option, when i went into the "imput data" tab on the data logger, the "water temp" box was not highlighted, so i could not check it...before, the water temp would be checked and the datalogger would display realtime coolant temps...
so, i opened my last tune that i had saved...then exported the data...when going back to the datalogger, the "water temp" was still not displayed, but now, when i went into the "imput data" tab, the water temp option was highlighted...so i checked it, and now it displays coolant temp, likek it did before..
so, for some odd reason, the configuration changed...but now it is remedied
Old Oct 16, 2005 | 05:39 PM
  #551
Sharif@Forged
Forged Performance
Glad it was an easy fix...maybe it was a laptop glitch or something.
Old Oct 17, 2005 | 05:33 PM
  #552
35ounces's Avatar
35ounces
03 CS Track 6MT
Do the diodes fix the problem with the EU blowing coils or can it still blow coils if you leave the key in the ignition too long?
Old Oct 17, 2005 | 05:40 PM
  #553
Sharif@Forged
Forged Performance
No diodes needed or recommended with the EU. The coils can still be damaged if you leave the key in the on position, when the engine is not running. Greddy is also working on a fix for that.
Old Oct 17, 2005 | 06:10 PM
  #554
ZU L8R's Avatar
ZU L8R
Viper Sellout
where is everyone mounting there EU?
Old Oct 17, 2005 | 07:38 PM
  #555
Badmonkey's Avatar
Badmonkey
Mine is mounted in the tray behind the pax seat, in the compartment, under the cover. Does any of that make sense? I extended the wires with 2 15 conductor cables.
Old Oct 17, 2005 | 10:33 PM
  #556
sentry65's Avatar
sentry65
the burninator
been noticing an odd problem since my EU install. Not entirely sure it's because of the EU, might be something totally different.
My dome lights don't work anymore - nothing.
also, I have a hypervoltage kit that normally has a blinking LED when it's hooked up to the battery. It's not blinking anymore.
Could this be because of the EU for some odd reason or does it sound like I blew some sort of auxillary fuse or something? I had an A/F gauge added and an oil temp gauge added. I'm using a hawker oddesey battery that's about 2 months brand new and have always gotten around 14 volts from it
I can just take it to the dealer. The car is under warrenty, but the timing on this is uncanny that it started happening the day I got my car back from the EU install. If the dealer figures it's something with the EU, then I'm gonna have to pay them for fixing it. I called Dynocomp and they say they didn't do anything that'd have anything to do with that stuff.
Old Oct 17, 2005 | 10:36 PM
  #557
Badmonkey's Avatar
Badmonkey
Sounds like a fuse, or something small like that.
Old Oct 17, 2005 | 11:36 PM
  #558
sentry65's Avatar
sentry65
the burninator
ok pretty much think I figured out what it is, but I'm not 100% sure.
would someone mind looking at their fuse box and seeing if the 10 amp fuse called A/T Cont. is plugged in? Mine is missing. It's in the upper left section. 2nd from upper left.
sorry for the off topic...
Old Oct 17, 2005 | 11:41 PM
  #559
Badmonkey's Avatar
Badmonkey
I think that is for an Automatic Transmission car.
Old Oct 17, 2005 | 11:50 PM
  #560
sentry65's Avatar
sentry65
the burninator
that's what I was thinking, but I can't find anything in the service manual that actually documents it. bah to the dealer I go.
