eManage Ulimate--Almost here..and MUCH IMPROVED!
Old Nov 21, 2005 | 11:32 AM
  #581
002-M-P's Avatar
002-M-P
Sharif told me he thinks it can be done, he just can't test it on his own car because he already has the 7100 rpm reflash.
Old Nov 21, 2005 | 11:44 AM
  #582
IceY2K1Max's Avatar
IceY2K1Max
You've got to be kidding...nobody has tried this since Greddy updated the firmware for the VQ35 crank sensor?
Old Nov 21, 2005 | 12:27 PM
  #583
roncfpz's Avatar
roncfpz
Sharif, any updates to the rev limiter issue with EU? Can you test it by raising it to 7200rpms like Booger did with his reflash?
Thanks,
Ron
Old Nov 21, 2005 | 08:41 PM
  #584
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Thanks,
Ron
Hey Ron, havent played with it yet. According to the Greddy docs, it is possible on fuel cut equipped ECU's, such as the VQ35. In theory, it can be done, I just havent tested it yet, as its not very straightforward the first time around.
Old Nov 22, 2005 | 06:04 AM
  #585
roncfpz's Avatar
roncfpz
Sharif, thanks and special thanks for all your testing and efforts on the EU. I probably speak for many of us in saying that I really appreciate it.
Ron
Old Nov 22, 2005 | 06:57 AM
  #586
Sharif@Forged
Forged Performance
The crank sensor update allows real time timing display, but has nothing to do with the rev limit increase, as its setup in the EU.
Old Nov 22, 2005 | 09:52 AM
  #587
IceY2K1Max's Avatar
IceY2K1Max
You guys are WIMPS~!
I tried on mine...however I don't have the crank signal option just ignition pulses or tach and it didn't work. Popped a code and God only knows what else.
Anyways, I can't BELIEVE you guys haven't tried. Such wimps.
Old Nov 22, 2005 | 09:55 AM
  #588
IceY2K1Max's Avatar
IceY2K1Max
What? All you do is enter the before cutoff point and new rev-limiter point and max out all the cell values for fuel. Or better yet, do like Greddy says and log up to the stock limiter and then just continue with the injection pulse width or duty cycle value, but watch your WB02 of course. Just take baby steps increasing the limiter 100rpms at a time.
IMO, VE is falling off by the stock limiter, so as long as you don't decrease pulse width, you won't go lean.
Old Nov 23, 2005 | 10:06 AM
  #589
roncfpz's Avatar
roncfpz
So the "wimps" want to know, have you successfully raised the rev limit using the EU to 7100rpms?
Ron
Old Nov 23, 2005 | 10:52 AM
  #590
IceY2K1Max's Avatar
IceY2K1Max
Ron
I don't have the crank signal hookup though. Somebody needs to grow some and give it a try.
Old Nov 25, 2005 | 06:08 AM
  #591
DandyMax's Avatar
DandyMax
Ya I can't believe nobody's tried this on a VQ35 yet either! You only have to go 1 or 200 rpms past to know it works. It shouldn't hurt anything if done properly.
Like Ice I've tried it months ago on a VQ30 but it doesn't work without the crank input. Perhaps it uses it to know when to fire the injectors after the ECU cuts out.
C'mon... somebody try this!!
Old Nov 27, 2005 | 08:18 AM
  #592
Sharif@Forged
Forged Performance
Two-Step launch is working now: link here: https://my350z.com/forum/showthread....13#post1883713
Old Nov 27, 2005 | 05:31 PM
  #593
punish_her's Avatar
punish_her
I set up the 2 step and it works great. Set it a 3k RPM to play with it to see if its good. Just used the speed signal wire Sharif used in his 2 step setup.
Having some funny results after hooking up the Auto AF setup.
One, I don't think its acivating, havn't seen a diffrence in the AF. Started at 14-15, nadda on the adjustment. Tryed many diffrent activation setups to try and activate it. Just inputed 12.5 across the AF adjust map. I see where the map trace shows the cells are activating. I'll dik with it a little more to see whats going on.
Two, if I accelerate quickly I get some really dicked up acceleration. It gets to about 3.5K-4.5K RPM then sputters like crazzy. It gets a couple of hundred past that then hit a hard acceleration. Its only under hard acceleration though, if I keep it arround 30-40% throttle its fine and accelerates as desired. If I'm at 4.5K RPM and I stomp it it accelerates just fine. So the trouble zone is 1K-3.5K hard acceleration.
Any suggestions. Been working on it for hours now and I'm stumped. I'll try more later to see if I can figure it out.
Thanks
Hawaii Mike
Old Nov 28, 2005 | 10:34 AM
  #594
overZealous1's Avatar
overZealous1
i am using the a/f target map and it seems to be working perfectly for me. i have had no time to hit a dyno yet, so my only adjustments have been scaling the actual injector pulse and cutting some of the maf signal. other than that i have made no adjustments in the ij. map, but my a/f is running right where it should as to what i inputted into the a/f target map. i am using from 1% throttle on up, and has been right on all the time.
one thing i am curious though, is there a map showing the adjustments being made or does it come up in the ij. map after awhile to see where it is adjusting the a/f and adding or subtracting fuel?
Old Nov 28, 2005 | 10:39 AM
  #595
Sharif@Forged
Forged Performance
The INJ map should be written by the AF target parameters...you should see changes on your map.
Mayself and a few others have the AF target mapping working...so I know it does work.
NOTE: Its highly advisable to use the AF target feature just for tuning, and then turn off the feedback once done. I do not trust wideband o2 sensors included in most wideband kits...to dial in AF all the time. You could also use AF target tuning to periodically adjust your INJ table as the weather changes..for instance.
Old Nov 28, 2005 | 11:06 AM
  #596
mazzoo's Avatar
mazzoo
What's the largest injector the eManage Ultimate can handle?
Old Nov 28, 2005 | 11:10 AM
  #597
Sharif@Forged
Forged Performance
750cc high impedence injector. You will need to get creative with scaling, and fuel pressure, but its doable.
Old Nov 28, 2005 | 11:41 AM
  #598
mazzoo's Avatar
mazzoo
Can I get the injectors from you?
Old Nov 28, 2005 | 04:08 PM
  #599
Peking's Avatar
Peking
Yes you can (from Sharif), check out his website... www.forgedinternals.com
Old Nov 28, 2005 | 06:56 PM
  #600
Sharif@Forged
Forged Performance
I dont have the 750cc injectors on the website, but they are also $550. Drop me an email or PM if you need them. THANKS!
