emanage help
Old Jul 11, 2005 | 11:02 AM
overZealous1's Avatar
overZealous1
Default emanage help
my car is finally just about ready, should have motor in by the end of the week. anyone following my other post (2nd day into the motor build) will be able to see what i have and what i have done to the motor and parts. i bought my emanage separately so i am starting with a completely blank setting. i am afraid my car will not even start if i hit the ignition with the stock tables on the ecu.
any help on intial timing and fuel settings would be greatly appreciated. i have not even powered the e-o1 programmer up yet so i am not familiar with how it is set up so any advice might need to be done in laymans terms. i do have a wideband a/f gauge so i am hoping to get it close enough on my own to be able to drive the car to get it tuned on a dyno. just need it to run first, lol.
Old Jul 11, 2005 | 02:58 PM
overZealous1
bump. need the info, lol
Old Jul 12, 2005 | 09:30 AM
overZealous1
aww come on, someone must have atleast some initial setting suggestions. how about the toggle placements inside? anybody? anything?
Old Jul 12, 2005 | 04:28 PM
JSP-Z's Avatar
JSP-Z
I'm not sure if you want to try and plug in any numbers yourself... possible someone could email you a base map to start out with.
Possibly Sharif or Phunk could offer assistance here. Good luck and be careful.
Old Jul 12, 2005 | 04:37 PM
westpak's Avatar
westpak
SFZCC
Well emailing a base map wont help unless he can load it with a laptop and you need the Greddy software and cable.
Here are the setting for the base map, no ignition since the stock doesn't have ignition in it.
You also have to set the basic parameters on the e01 like the injector sizing.
Attached Thumbnails emanage help-addinjectormap.jpg   emanage help-boostlimiter.jpg
Old Jul 12, 2005 | 04:45 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Call my cell...I'll walk you throught it in 5 mins. Make sure you are seated in your car, when you call me. 626-485-2100
Old Jul 13, 2005 | 10:34 AM
overZealous1
thanks westpak for the effort to load those images. i believe i am running nearly the exact parts as sharif so i will get everything powered back up and run through everything on the e-01 to get familiar with it first then call if i need more help. the info i got from sharif on aim should get me able to start the car atleast which is mostly all i need, thanks.
ChrisMCagle
Tuning
205
Apr 22, 2005 11:14 AM
hndumafia
Apr 13, 2005 11:20 PM
cariza
Oct 1, 2004 06:20 AM
Sharif@Forged
Jul 15, 2004 12:26 AM
derek_i
May 9, 2004 08:27 AM
