need procharger Belt, web site
Old Sep 22, 2005 | 06:10 PM
jy535's Avatar
jy535
Default need procharger Belt, web site
WHats up, i stripped every tooth on my cog belt i think..... not the belt on the front of the procharger, the one in the back, does n e one have a web site to find cheap belt, or whats the best best, i think ati would be expensive, but n e one with inputs appreciated
Old Sep 22, 2005 | 07:16 PM
overZealous1's Avatar
overZealous1
it is a gates belt. call ati and get the part # or look at the installtion manual and get the part #. punch in that part # and "gates" and do a search, you will come up with a bunch of different choices from the gates website too. unfortunately i forgot the part # myself. the one you stripped is about $25-$30 at an industrial supply place. good luck.
btw- buy 2!! of each!!! carry in the car!! i know this from experience, lol
Old Sep 23, 2005 | 03:02 AM
RBALDINELLII's Avatar
RBALDINELLII
Call your local Purvis Bearing shop or any heavy duty industrial shop. They can get them to you easily and next day. My last belt I bought was $20.
Old Sep 23, 2005 | 03:48 PM
KPierson's Avatar
KPierson
If I remember correctly the Gates part number is printed on the belt. That might make it a bit easier to find it!
Old Sep 23, 2005 | 03:54 PM
Badmonkey's Avatar
Badmonkey
How did it strip? How was the tensioning on the belt? Just trying to see if there is anything to do to prevent this.
Old Sep 23, 2005 | 06:03 PM
overZealous1
i went through about 3 belts in 4 months. mine would not strip the teeth, they would just completely fail. my tension was good, but i never took the time to perfectly align the cog pulleys. i gather the heat generated from the constant misalignment is what was causing my failures. mine would snap when doing a burnout or something, but i was running 15psi pulleies too putting it under more stress. unfortunately the gates belts they use are the strongest belts available for the size. just buy 2 when ever you loose one and keep it in the car. i lost one down in arizona on a trip and had to drive 1600 miles home with the blower not running. gas mileage sucked!!
Old Sep 23, 2005 | 06:12 PM
KPierson's Avatar
KPierson
I never had a problem with mine except when it was first installed and the tensioner bolts weren't tight. On they dyno the tensioner slipped and instantly destroyed one of the belts. Other then that, I made sure they were tensioned right and never had any issues with them.
Old Sep 23, 2005 | 07:14 PM
jy535's Avatar
jy535
well hopefully its something little, and i will not have many prob...... im bringing my car to mrc tomorrow and im gonna have the belt fixed, i was racing shifting into 3rd gear, and bang it was gona i new right away, it felt like the car just fell off, it sucked...... i was in the middle of a good race..... i hope a lil adjustment will fix the problem, my teeth on the belt were shot, nothin left, but the thing the belt rest on is kinda wearing down to,.......
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Fixxxercask
Nov 9, 2015 11:10 AM
350z82
Oct 1, 2015 06:25 PM
Tochigi_236
Sep 27, 2015 03:40 PM
