whos purchased blocks from SGP
I am going to buying or building a block here soon for my aps tt g35 and i was wondering who has purchased a block from sgp and how happy they where with the product... any info would be awesome.. like which set up you went with and whatever you think i should know.. im interested in upgraded long block number 1
thanks
thanks
Originally Posted by ActionJackson
What's the difference between a long or short block for FI applications in our cars?
Longblock = block, heads
Shortblock = block
Rolling shortblock = block, crank, crank bearings, etc.
On any of them, you pick certain things such as cams, piston, rods, sleeves, etc.
I would say go for it. They've built dozens of VQ motors and they know what they're doing, and they stand behind their work.
I got the upgraded long block 3 but with Arias Extreme Duty pistons instead of the CP's.
I have put 5K miles on my upgraded long block in about 2 months. everything done except valves and sleeves. I drove like grandma for the first 1K miles and the other 4K I have driven the car like I stole it. I am very happy with their work.
ok this is what i want.. i think.. one question i have is since i have the 05 with the 295 hp rated engine.. can i even get cams to work right? isnt there a variable valve exhaust thing going on? has anyone upgraded there block on the 298 hp engine? do you guys know if i will run into any problems or if there is anything i should look in to... this type of modifaction is uncharted teritory for me and im trying to learn as much as possible.. sorry im such a newb
Block oil passages cleaned
Block redecked
Block Bored and Honed using a Torque Plate
Crank balanced
Crank journals polished
New Main and Rod bearings w/ceramic coating
*Pauter Rods
ARP Rod Bolts
*CP Pistons .020 over(8.5:1 or 11.5:1)
*ARP Main Studs
*ARP Head Studs
Heads oil passages cleaned
Heads redecked
Ported exhaust and intake runners
5 angle valve job
Valve Stem Heights set
Cold Clearance set
New Valve stem seals
New Nissan Head gaskets
New Nissan Oil Pump
New Nissan Cam seals
Block redecked
Crank balanced
*Pauter Rods
ARP Rod Bolts
*ARP Main Studs
*ARP Head Studs
Heads redecked
5 angle valve job
Cold Clearance set
New Nissan Oil Pump
I wasn't paying attention while driving last night and I went from 3rd to 2nd while go about 70 mph. Redlined to 8K rpms.
this block can take some abuse! really scared the chit out of me.
Originally Posted by Rayden2001
Well I'm in the same boat now, I'm trying to decide which package to go with now.
