Cooling Mist water injection....
Old Oct 13, 2005 | 12:05 PM
  #61
GurgenPB's Avatar
GurgenPB
UltimateSleeper
hehe no no .... Seriously...all I kow about water injection, I learned in the last 7 days. There are some incredibly interesting articles out there on it, historical and technical. waterinjection.info is a great place to start. Combine what you learn there with a little commonsense...and that's all you need.
Old Oct 13, 2005 | 12:21 PM
  #62
Gman2004's Avatar
Gman2004
Originally Posted by GurgenPB
but if oyu have an emanage ultimate or plan to use it, just be conservative with the WI until someone comes up with a map for it.
What makes using WI different with the Emange Ultimate as compared to the other forms of engine management?
Old Oct 13, 2005 | 01:14 PM
  #63
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Gurgen,
I don't have my electronics hooked up yet. But I'm thinking it is possible to create a linear coefficent for the MAF output. As long as injector inlet pressure remains constant, it is easy to create a correlation of MAF voltage to the observed IPW.
Map Injector EPW Vs Maf voltage to create a linear relation of voltage to air mass flow.
Its that simple. Corrections can be made by normalizing to the observed A/F ratio.
Another way to try it... You can infer a air mass flow rate based on injector duty cycle if you normalize to the A/F ratio. You don't really need a MAF voltage when you have injector duty cycle and A/F ratio!
And both injector EPW and A/F are linear and easy to interpret.
Having a linear coefficent could make life a lot easier when trying to adjust water flow rate based on air mass flow rate.
I'll create a correlation as soon as I get the EU and Innovate hooked up.
Old Oct 13, 2005 | 01:36 PM
  #64
G3po's Avatar
G3po
Gurgen in reponse to part of your response above:
"...and you are delivering the same flow of water, you an see how the WFR will be falling off as you reach redline."
From my experience with many years of WI on several aps, this "is" actually part of the behaviour you want. It has been proven that an engine is more prone to detonation during "Peak TQ" conditions . If you note the shape of most gas engine TQ curves (FI-VQ included) you will find that peak TQ occurs mid band and tapers towards redline. In order to gain the maximum effective and minimal water/methanol consumption you actually want the water/fuel ratio ot taper above mid band out to redline. This is why simple on/off boost referenced systems still work quite effectively. Now in some cases what can occur if full optimum mid band water rate is delivered too low in the rpm band, the engine can "lay down" due to too high a Water to fuel ratio. This is why a duak nozzle or a simple ramped approach is the next best step . Also not that the reason dual nozzles are mostly used in very high output applications is that a single huge nozzle at a reasnable pump psi ~140psi does not provide ideal atomization. Two smaller nozzle proved both better atomizationa dj higer aggregate flow.
A full independant 3d mapped technique "independent" of fuel injector duty cycle can be ideal , but IMO the small added benefit does not justify the cost nor complexity in a street driven vehical.
Old Oct 13, 2005 | 01:59 PM
  #65
coolingmist's Avatar
coolingmist
We were asked by one of your members to reply to this thread. We are very busy and dont have time to review this entire thread. If you have a specific question feel free to ask us here and I will reply as time permits. A background on our company. We have been in the business for about 4 years, been selling for about 2. We are located in Atlanta, GA and our retail outlet will be opening shortly. We offer a 90 day warranty + 7 day a week support. We have dealers in many countries and across the US.
The systems you see on our site are based off of boost. There is an exclusive 1-25 psi boost switch that comes with the kit. You can adjust the switch from 1-25. When it hits your adjust point it will start to spray, when it drops below it will turn off. We have seen over 100 HP for diesels and as much as 87 HP on a car (precision dynotune in new jersey got 87 HP out of a new EVO with our kit).
We have every conceivable option from brass water filters to poly. From Nylon hose, to synthetic to stainless steel teflon.
Cars that have over 500 HP need 2 nozzles.
I read some comments about progressive controllers on one of the earlier pages.
We have a tuning controller that will be out shortly. These will be sold as part of a kit and individually on our site. Those of you that have purchased a kit from us will easily be able to purchase this controller and add to your kit when it becomes available. Infact, we have a limited number of controllers on our first run, but those that purchase a kit now will get first shot at the controller before the public. I cant get into specifics about how it works, other than to say its the most advanced controller on the market.
anyone with questions please let us know. We have a forum on our site with questions and answers also. Also, we go by the name Coolingmist rather than Cooling Mist. Thanks!
Old Oct 13, 2005 | 02:56 PM
  #66
atlsupdawg#2's Avatar
atlsupdawg#2
Originally Posted by atlsupdawg#2
002-M-P,
Don't mean to hijac your thread here bro. Been wondering something and wanted to see if anyone's got any idea.
I know most people locate the injection nozzle(s) close to the throttle body (as did I) on the intake tubing. Do you think it would make a difference if the nozzle(s) were tapped into the intake plenum itself? Seems like you'd have a wider dispersement of the cooling fluid if you sprayed into the manifold and less restriction from the throttle body (if there is a restriction at all).
G3po you seem to be the resident expert on WI so would you mind touching on this theory here?? 002-M-P posted Coolingmist's install directions but I kinda wanted a brief explanation on why this would or wouldn't work..
Old Oct 13, 2005 | 02:58 PM
  #67
002-M-P's Avatar
002-M-P
Welcome coolingmist
Old Oct 13, 2005 | 03:12 PM
  #68
G3po's Avatar
G3po
Honestly in a "blow thru FI" application. Pretty much all the SC and TTs sued on the Z/G to date (except Stillen) , placement of the nozzle(s) post MAF and pre TB is the place to be. Placement in the plenum would add little benefit and could actually cause addtional issues. One being you would need and to add anti-siphon solenoid which isn't needed for a Pre-TB install , even though I would recommend a simple check valve inline between the pump and nozzle as a minimal precaution in any install. As for pre-TB placement anywere more than ~3 inches pre TB and post MAF should work fine to avoid any signinficant wetting of the Throttle plate or the MAF element.
Old Oct 13, 2005 | 03:14 PM
  #69
G3po's Avatar
G3po
Cool . so what info will you squirt out the serial port?
Old Oct 13, 2005 | 04:33 PM
  #70
theking's Avatar
theking
This is what I was ineffectively trying to say. Glad "Coolingmist" is on here. What is the stategy with your new controller?
Old Oct 14, 2005 | 12:02 PM
  #71
GurgenPB's Avatar
GurgenPB
UltimateSleeper
As long as it has a configurable (mappable) output...e.g. a subinjector output, then you are fine.
Originally Posted by Hydrazine
Gurgen,
Hey Tony,
You are right... that setup is very mch possible. Inf act, the best way would probably be to input fuel pressure as an aux mappable input and combine that with IPW information...and oyu are all set.
However, setting up a 2D IPW-only referenced system is not a bad way to go either.. it's just that at higher boost applications, your ratio will be lower...but you will still be receiving constant WFR.
In fact, Tony, I just thought of something else...something that will allow one to use the cheaper cooling mist solution with a 0-5v input. The Innovate! AuxBox modulates all of the inputs into 0-5v analog outs, and these are available for tapping if you are using te digital serial LogChain. So, one of the channels that is configured to receive IPW for logging purposes, is then converted into a 0-5v output. One can just tap that. BTW...you can do the same with the MAP sensor output...which is a 3 bar MAP sensor. Hence, you will no longer need to spend additional $100+ for a map sensor for an EU setup...just tap auxbox output into the pressure harness signal/ground!!! This is what I am doing.
Old Oct 14, 2005 | 12:16 PM
  #72
Hydrazine's Avatar
Hydrazine
Hey Tony,
Hey I like it! 0-5 V output not just for logging but also as a control signal. And finish it off with a variable duty cycle output from the EU.
The combination of EU with the Innovate AuxBox should provide powerfull tools for new ways of engine management.
I really need to get the electronics hooked up. I have so many cool projects to dig into.
Old Oct 14, 2005 | 12:33 PM
  #73
GurgenPB's Avatar
GurgenPB
UltimateSleeper
Can't wait to hear about those.
If you think that's cool...just wait for Innovate's engine management to come out!!!! Good stuff, with their usual genious twists.
Old Oct 14, 2005 | 10:35 PM
  #74
Zivman's Avatar
Zivman
For the APS guys. I have been informed that there is a Unichip module that can control a W/M injection. It can be used with the Unichip piggyback that the APS kit uses. Similar to the boost module.
I might be using this on my build. Will get more details on this in the next few days.
Old Oct 14, 2005 | 11:13 PM
  #75
GurgenPB's Avatar
GurgenPB
UltimateSleeper
Hey Tony
Innovate is also going to be having a ViisalBasic-based programming feature that you can use to program the processor inside the AuxBox (next gen AuxBox from what i am hearing) to calculate various values and output conditional signals...precisely what you and I discussed when i first demoed the system for you.
I a mgetting ready to do individual cylinder EGT to really nail down AFR's, and WI for that matter. If I go with Aquamist, I think I will do individual cylinder WI injection nozzles.
Man...only if I had more time. This school/work thing get int he way tooooo much. j/k
Old Oct 15, 2005 | 09:07 AM
  #76
Hydrazine's Avatar
Hydrazine
If we only had more time....
Old Oct 16, 2005 | 09:02 AM
  #77
theking's Avatar
theking
Sounds like you have some great projects going on. I'd like to see what your findings are on cylinder egt's. This will be great info for everyone. Thanks for puting in all this r&d!
Old Dec 4, 2005 | 08:44 PM
  #78
tecni's Avatar
tecni
ok, call me stupid but I've been hearing about this water injection thing and I guess I just don't know enough about it.
Where does it spray the water/alcohol? Into the intake??? If so, I thought water in the combustion chamber was deadly for the motor and bent the rods upon compresson of the pistons?
Am I missing something here?
Please explain
Old Dec 4, 2005 | 09:01 PM
  #79
002-M-P's Avatar
002-M-P
Please explain
The theory is that by spraying water into the intake stream at high pressure so that it is a fine mist that atomizes quickly, you can decrease the chance of detonation because the heat in the airstream gets absorbed by the atomized water before it goes into the engine. The alcohol part, can also be mixed to give a slight octane boosting effect and cause the resevoir tank in the car not freeze in the winter.
I still have actually not used my WI system. When the car was on the dyno for tuning the ambient air temps were about 76 degrees. My intake temps at the throttle body ranged between 83 and 88 degrees. With this I realized that there was no reason to run the water injection until I ran more boost or until it was much hotter outside. The Greddy intercooler is just so incredibly efficient, there is very little need for W/I until higher boost.
Old Dec 4, 2005 | 09:13 PM
  #80
overZealous1's Avatar
overZealous1
Please explain
what you are referring to is hydolock. that is when you get enough water in the cylinder that it will not fit in the combustion area of tdc. the water won't compress and you get bent stuff. w/i injects a mist of water or water methanol that is used to cool the intake charge and bring down combustion temps through the steam created. this is only a fine mist injected in. as explained earlier, the best place is after the maf but before the throttle body to get the best misting and distribution.
