Ross Racing Pistons...anyone?
Old Oct 26, 2005 | 09:52 AM
MIAPLAYA's Avatar
MIAPLAYA
Default Ross Racing Pistons...anyone?
Does anyone know if Ross has made a piston set for the VQ yet? I know almost everyone is running Arias or CP but I am interested in seeing some other options. A few good friends have used Ross Pistons in the past and they performed absolutely amazingly under some pretty bad race conditions...Also would be interested to see if JE has a set either. I just saw that SGP is now selling Wiseco with their basic short block which looks like a pretty damn good deal also...Wiseco pistons and Eagle Rods sound nice...
Old Oct 26, 2005 | 10:05 AM
350Zteve's Avatar
350Zteve
I think you would have great results with all the top piston companies. I persnally like Wiseco the best, but they all make great products. My vote would be for Wiseco. Also check out the extreme duty Arias pistons that Forged Internals sells. Definately something to consider if your building a psycho motor.
Old Oct 26, 2005 | 10:11 AM
MIAPLAYA's Avatar
MIAPLAYA
Yes I've looked long and hard at those extreme duty pistons but in all honesty I'm not looking to make 1000 WHP. I want something that can take me to 550- MAYBE 650 every once in a while. My main goal is a solid 550 RWHP daily driver. But I absolutely can't stand hearing piston slap and I would want the motor to sound no different then stock. I know that those are complete opposites when you build a motor. So honestly the Extreme Duty Arias ones are probably not going to be necessary. I may even go with Eagle Rods as my plans dont exceed 650 and I think thats what the SGP website says those are good to. I am seriously considering the basic shortblock from them but with all ARP hardware added. They sell the Wiseco 8.5:1 pistons and Eage rods installed with all machine work for $2700+$1000 core which is a good deal. I was just curious about Ross pistons. I have heard some very amazing stories about their longevity even when being pinged on and it was pretty damn impressive.
Old Oct 26, 2005 | 04:05 PM
350Zteve's Avatar
350Zteve
Do you know if the Wiseco's (or Ross for that matter) for the Z are zero silica or not? That's the best thing about the extreem duty pistons is they are silica free which makes them MUCH more resistant to detonation. Either way, that SGP motor sounds like a good deal and the Eagle rods will laugh at 650hp. There are tons of boosted Integra motors making over 600hp on Eagles (with 2 less rods to share the load).
Old Oct 26, 2005 | 04:10 PM
MIAPLAYA's Avatar
MIAPLAYA
Agreed on the rods....I called Eagle and they said they could handle more like 800. As for the pistons I was not able to reach anyone at Ross today mainly cause I ran out of time before they closed but I don't believe they are zero silica and I'm almost positive the Wisecos are not. I have heard some bad stories about the Wisecos circulating lately but I spoke with SGP today and was assured it was a tuning issue.
Edit: On another note I have heard a few zero silica piston motors in the past and when cold they do seem to be a bit louder then stock...I did get a chance to hear Todds car with the Arias extreme duty pistons though and it seemed to be about the same as stock.
Old Oct 26, 2005 | 04:58 PM
mchapman's Avatar
mchapman
I know of 1 built motor here in Australia using Ross forged pistons, he might chime in when he sees the thread.
I just got some high silicon Arias extreme duty pistons to avoid the potential issues with low silicon while still getting a beefier designed piston.
Old Oct 26, 2005 | 05:28 PM
MIAPLAYA's Avatar
MIAPLAYA
Very nice...and that would be great if he could!!
Old Oct 26, 2005 | 05:53 PM
cjb80's Avatar
cjb80
Ross pistons are good, but they require huge piston to wall clearances. I have used them in many motors that I built for S2000's, but I was running like .006" piston to wall clearance. After having built my Z motor, I am happied running a smaller clearance. I am currently running Wiseco, and I just ordered Arias, and I imagine they will both work similarly. One thing that I won't do again is the banodized coating which Ross offers. All of the motors that I built with the banodizing seemed to burn more oil for some reason..
Chris
PS-Ross was stocking these pistons about 6 months ago, so by now they should have them off the shelf.
Old Oct 26, 2005 | 05:54 PM
MIAPLAYA's Avatar
MIAPLAYA
Chris
I guess its Arias for me then...
Old Oct 26, 2005 | 07:58 PM
Carlitos's Avatar
Carlitos
Chris
I do have ROSS on my G and yes my clearance is .006" I don't think thats a problem as my engine is quiet and I don't have a blow by problem. I did get a Swain coating on the pistons.
My ROSS-Pauter combo is giving me a 546rhp street tune and 581rwh race fuel no n2o. (I did run a 50hp shot on the track, 11.3@127.8)
here is one pic
Old Oct 26, 2005 | 08:15 PM
g356gear's Avatar
g356gear
Those look like a higher compression piston.....10.0:1???
Old Oct 27, 2005 | 02:45 AM
mchapman's Avatar
mchapman
Correct.
Old Oct 27, 2005 | 08:01 PM
2JZfan's Avatar
2JZfan
buying pistons is the easiest engine choice there is -- you want CP, period.
I could go on forever about all the little things that makes them superior, but consider this single story... We once made a pull in our 1500hp mustang and had one of the two fuel pumps fail... the complete pull was at 17:1 AFR making over 1000hp at 30+ psi of boost... no engine damage at all... perfect compression and leakdown afterwords... the year before, we blew through several probe pistons (made by Ross) with FAR less abuse than that...
CP CP CP
Old Oct 27, 2005 | 08:17 PM
failsafe306's Avatar
failsafe306
Originally Posted by 2JZfan
buying pistons is the easiest engine choice their is -- you want CP, period.
CP CP CP
IYO, do the Arias Extreme Duty's compare to CP's?
Old Oct 27, 2005 | 08:30 PM
2JZfan's Avatar
2JZfan
In a word, no. Will the Arias, Wiseco, Ross, etc. be an upgrade over stock and work "ok" in a 500rwhp motor? Almost definitely. But to me, when you factor the time and money to machine the motor, build it and install it, why let a few hundred bucks stand between "good" pistons and "the best"... I order my engine parts from the largest supplier of aftermarket race pistons in the world... they sell just about ALL brands of pistons, and not just to Joe Meathead who is building a GTO in his driveway, they spec out and sell pistons to the big boys running pro race teams... These guys tell me that the feedback from all of their builders is that CP is at the top of the list. My personal experience is in synch with that, so I have no reason to experiment with anything else.
Old Oct 27, 2005 | 09:56 PM
phunk's Avatar
phunk
CJ Motorsports
Cp.
Old Oct 27, 2005 | 11:38 PM
Acree's Avatar
Acree
Originally Posted by phunk
Cp.
i wasn't aware they had pistons available for the 350z. it's not on their website.
http://www.cppistons.com/sCompactNEW.htm
Old Oct 28, 2005 | 06:53 AM
theking's Avatar
theking
They definitely do. They can also make whatever custom piston setup you want. They have done some custom specs I know of for the VQ35.
Old Oct 28, 2005 | 06:57 AM
03Z33's Avatar
03Z33
There's another 350Z race team running the Ross Pistons and they love them. You have to know exactly what you want though, because Ross have a few options in materials and sizes, you can run tighter clearances than what they recommend no problem.
apex locator
Jul 23, 2021 02:27 AM
Fixxxercask
Interior
Oct 6, 2015 10:17 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
