View Poll Results: Which one
Supercharger
15
44.12%
Turbo Kit
19
55.88%
Voters: 34. You may not vote on this poll
Which would you recommend to an FI noob
Old Oct 27, 2005 | 02:39 PM
oaktown2000's Avatar
oaktown2000
Default Which would you recommend to an FI noob
As far as complexity, maintenance, problems, etc...
Old Oct 27, 2005 | 04:49 PM
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
I recommend to you to research. After plenty of researching, you'll find out what you prefer, I know I did.
We'll especially need to know more information before we can vote.
Old Oct 29, 2005 | 02:14 PM
More Power's Avatar
More Power
APS twin turbos, APS plenum, and APS exhaust all the way. If you can't afford that go APS single turbo.
Old Oct 29, 2005 | 02:34 PM
overZealous1's Avatar
overZealous1
there is so much info on this site and posts dedicated to showing strengths and weaknesses for almost any kit available. pretty sure one is stickied too. you have hours of rerading ahead, lol.
Old Oct 29, 2005 | 02:57 PM
roncfpz's Avatar
roncfpz
They're both complex, require maintenance, and may cause problems. Not easy to answer with the limited info.
Old Oct 29, 2005 | 04:03 PM
Jaki's Avatar
Jaki
In most cases people will vote for the kit that they have. You really need to set a goal for what kind of a car you want, and then we can all vote and go into details.
Old Oct 30, 2005 | 02:41 AM
Dubai's Avatar
Dubai
I can summurize the diffrence between them,
Advantages of Supercharger:
-Easy to install
-Costs less
-Less torque output, less traction problems
Disadvantages of Supercharger:
-Constant grade of fuel has to be used octane wise, you cant go lower than 93-94 on certain setups
-Low Torque Output, you might want to haul things
-No way to vary boost other than changing pulleys
Advantages of Turbocharger:
-Works sort of like a switch, if you dont rev up high enough, it wont spool up, saves gas when off the throttle
-Torque up high
-Easily tunable, use a Boost Controller, all turbos have a max flow rate though, remember that
-Able to use lower grade octane at lower boost levels 87-89
Disadvantages of Turbocharger
-Turbo lag if the turbo is big enough
-Excessive torque output at max boost when racing, can throw car sideways
Old Nov 5, 2005 | 10:35 PM
xxx4reggie's Avatar
xxx4reggie
with the z we can use 87 gas??
Old Nov 6, 2005 | 12:38 AM
iceman21_23's Avatar
iceman21_23
yes i can use 87 gas but the ecu will cut back power, because of it
Old Nov 6, 2005 | 08:40 PM
xxx4reggie's Avatar
xxx4reggie
but will it hurt the z in any way besides less hp
like messing the engine up
Old Nov 7, 2005 | 03:25 AM
captj3's Avatar
captj3
You cannot use 87/89 octane with either set up or you will blow your motor with FI. Thats bad advice.
Old Nov 7, 2005 | 12:18 PM
Brandon@Forged
You can use 87/89 octane with a forced induction kit, however, you have to tune for it.
You can use 87/89 octane while N/A, your ECU will sense any knock that may be harmful and adjust the ignition timing. (you'll run hotter EGTs and should have only slightly less power) I don't recommend doing this all the time.
Old Nov 7, 2005 | 05:25 PM
xxx4reggie's Avatar
xxx4reggie
thanks!!
needed that info
AbrasiveRaysive
Sep 20, 2021 02:29 PM
apex locator
Jul 23, 2021 02:27 AM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
SharX59
Sep 27, 2015 09:23 AM
