aps tt upgraded actuators... what boost controller?
Old Nov 11, 2005 | 11:21 AM
paranormal's Avatar
paranormal
Evil Boy 4 LIFE
Default aps tt upgraded actuators... what boost controller?
question for you guys with upgraded actuators.. what boost controller are you guys using? and also what actuators and what are they rated at?
ps. ... what emu too
thanks
Old Nov 11, 2005 | 11:30 AM
cjb80's Avatar
cjb80
I am using the Greddy Profect B Spec 2, it works fine. Forge Actuators, and Emanage Ultimate. I made 530 rwhp/475 Torque at 12.5 psi, and then my clutch started slipping so I had to stop. The tuning wasn't even done at that boost level, so I expect I could have gotten more power. My ECU is set to rev out to 7500, and I only went to 6800, so another 20-30 horsepower could be had with the extra RPM....
Old Nov 11, 2005 | 11:52 AM
RedLeader's Avatar
RedLeader
paranormal-
Greddy Profec B-Spec II, UniChip, and upgraded Garrett actuators that Torque Freaks found for me during my build. Right now, I'm boosting 14lbs and maxing out the APS injectors. New injectors go in Monday. I'll post when it's finished.
Old Nov 12, 2005 | 04:19 PM
G3po's Avatar
G3po
Originally Posted by RedLeader
paranormal-
hi bruce , Rob gave me a ride in your beast while I was dropping of some mo parts for my install, at ~14psi, simply amazing how smooth and fast it spools. I guess the FMU A/F gets a little "wavy" at high rpm, so it's up to 650 RCs for ya
Old Nov 13, 2005 | 12:00 PM
RedLeader's Avatar
RedLeader
Default Team Effort
G3po-
Rob is going to be even MORE of an expert when he gets through with my project. It should save some time on future projects. Can I have a ride in yours when it's finished?
Bruce
Old Nov 13, 2005 | 12:31 PM
paranormal's Avatar
paranormal
Evil Boy 4 LIFE
hey whats the min boost setting on the garret actuators? cant wait to see your new results!
Old Nov 13, 2005 | 06:18 PM
G3po's Avatar
G3po
depends other factors such as exhaust and TPs/Cats.
On Redleader's Z , (8.5CR , TPs and Stillen TD) I seem to recall it was putting down around 7psi the way TQ freaks had them adjusted. After tightening them up the base is somewere around ~10psi. With a good boost controller (like the Greddy Profec) 20psi is then possible . So a tunable range of ~10-20psi
Old Nov 13, 2005 | 10:49 PM
KPierson's Avatar
KPierson
With my upgraded actators the lowest boost I've managed is around 10psi. My installer hooked the wastegates directly to my plenum (I believe) to run the lowest (laggiest) boost possible until I can get it tuned.
On a side note, the car is absolutely no fun to drive anymore!
Old Nov 14, 2005 | 07:14 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
paranormal, if you retain the Unichip, then you can't readily use another boost controller. Your tuner could disable the boost control function of the Unichip, but instead, most people are removing the Unichip completely, along with the boost control solenoid. Replacing it with EU or UTEC (when its ready to ship), and couple it with a Blitz SBC Id boost controller, or other quality dual solenoid high capacity boost controller.
Old Nov 14, 2005 | 07:24 AM
Nismo350ZRT's Avatar
Nismo350ZRT
Sharif, can the Unichip control the boost with upgraded actuators? I plan on upgrading my actuators but retaining the Unichip.
Old Nov 14, 2005 | 07:38 AM
Sharif@Forged
Forged Performance
Yes it can.
Old Nov 14, 2005 | 08:31 AM
RedLeader's Avatar
RedLeader
paranormal-
They preset my actuators to establish a minimum. If you didn't preset them, I assume you could start out at zero boost, and use a BC to achieve higher boost.
Sharif-
Rob wasn't happy with the control he was getting with the UniChip, so he installed the Greddy and says it's quick and solid up to the point where he runs out of fuel. I'll know more after the bigger injectors are in and he turns up the boost.
Bruce
Old Nov 14, 2005 | 08:50 AM
Sharif@Forged
Forged Performance
Sharif-
Bruce
Bruce, that doesnt surprise me, as the APS boost control solenoid is tiny, and you will get much better control with a higher capcity boost controller.
Old Nov 14, 2005 | 01:02 PM
paranormal's Avatar
paranormal
Evil Boy 4 LIFE
thanks.. i got a few weeks till my engine is done being built so im just trying to weigh out all my options.. most likey im gonna go with the utec and a boost controller..waiting to see some results from someone else with the same setup!
Old Nov 14, 2005 | 01:28 PM
RedLeader's Avatar
RedLeader
I looked at the Blitz but wanted something compact without the big screen. If I had an Evo and was running really high boost, I might have gone with the dual-solenoid setup. The Greddy was what Rob @Z-Car Garage advised, so I gave in to the voice of experience. It's comparitively inexpensive, doesn't have a lot of whistles and bells, and works.
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
