Turbonetics Detonating on 93 Octane
Old Dec 11, 2005 | 09:35 AM
  #181
kcobean's Avatar
kcobean
Let us know how it goes JET. Can't wait to hear the results of that thing.
Old Dec 11, 2005 | 09:49 AM
  #182
35ounces's Avatar
35ounces
03 CS Track 6MT
Originally Posted by JETPILOT
Sorry David.... missed your post in there.
Yes there are 2 ports for use with a boost controller.
Respect
JET
Thanks JET. We are all very anxious to see your results with this.
Old Dec 11, 2005 | 10:13 AM
  #183
Peking's Avatar
Peking
With a wastegate this big I demend it be aknowledged.
Respect JET
Damn that is pretty big, like the comparison pic with the chap stick
Looking forward to the pics of that thing on the car lol.
Old Dec 11, 2005 | 01:14 PM
  #184
MIAPLAYA's Avatar
MIAPLAYA
Sorry bro....I'm pretty damn sure I posted a reply about it. I posted two replies. One about fuel and one about the gate. Not sure what happened. Props on that thing. Its like your kid being born with a 12"er. "Watch out, working with a monster here!!" Props.
Old Dec 11, 2005 | 01:24 PM
  #185
JETPILOT's Avatar
JETPILOT
Originally Posted by nissansource
good luck fitting it its big did you get the 38 to 44 adapter
Nope... gonna mount it in a different location so there is no 90 degree exit from the up pipe. That 90 degree mounting is likely the problem here.
I skipped over the measly 44 and went firectly to 48.
Respect
JET
Old Dec 11, 2005 | 05:33 PM
  #186
ronum1's Avatar
ronum1
I just got the TN Kit for the G35 coupe, I have a 2003 6mt
At this very moment my only mod is the HKS Dual Hi Power Ti Exhaust
I'm worried about everything I have just read in this thread, Do you guys think I will be facing a problem. My plan is to keep to run the kit the way it is suppose to be run, I also have the stock exhaust, do you think I should put that one on instead?
Im worried, Any ideas?
Old Dec 11, 2005 | 05:35 PM
  #187
ronum1's Avatar
ronum1
I'm worried about everything I have just read in this thread, Do you guys think I will be facing a problem. My plan is to run the kit the way it is suppose to be run, I also have the stock exhaust, do you think I should put that one on instead?
(Also I know that if i have to do a reverse y pipe so the exhaust can work )
Old Dec 11, 2005 | 05:36 PM
  #188
kcobean's Avatar
kcobean
I honestly wouldn't worry about it until it becomes an issue for you. There is another guy here (D350Z10) who has the EXACT same modified exhaust I have, and he never had this issue with the Evolution, so don't sweat it....get the install done and go from there.
Old Dec 11, 2005 | 05:42 PM
  #189
MIAPLAYA's Avatar
MIAPLAYA
+10000 If it aint broke dont fix it till it is. Install the kit as planned. If an issue arises then it can be remedied. But like was said before with 30+ members with this kit installed we are looking at a small percentage of people who had an issue. And of course most of them had essentially straight pipes installed on the car
Old Dec 11, 2005 | 06:27 PM
  #190
Meatshackle's Avatar
Meatshackle
Don't sweat it. I'm very happy with my TN G35 kit.
Granted it's only been on the car for about 8 hours or so.
Old Dec 14, 2005 | 06:27 AM
  #191
35ounces's Avatar
35ounces
03 CS Track 6MT
Any update JET?
Old Dec 14, 2005 | 08:53 AM
  #192
JETPILOT's Avatar
JETPILOT
UPDATE: My new $1600 ATS carbon single clutch took a dump. Soooooo I'm focusing on the clutch now. The clutch will arrive tomorrow and I will install it.... well damned if I know when I will have time anymore to do anytjhing.
Respect
JET
Old Dec 14, 2005 | 08:56 AM
  #193
MIAPLAYA's Avatar
MIAPLAYA
Respect
JET
OUCH!!! That sucks bro...what clutch are you replacing it with? I recently saw a post that one guy has his JWT clutch holding 600+ not bad for a $380 clutch...
Old Dec 14, 2005 | 12:49 PM
  #194
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Respect
JET
Just remember that the ATS single disc is rated at just 320 crank hp, or 400 crank hp with the 1300kg pressure plate. It is a really wimpy clutch. We recommend the twins and triples for FI. They can hold between 700-1500 crank hp, depending on the configuration.
Old Dec 14, 2005 | 02:35 PM
  #195
JETPILOT's Avatar
JETPILOT
I HAD the 1600kg Pro Spec single carbon with CCM pressure plate which SHOULD have been good up to approx 525 flywheel horespower. I'm making about 450fwhp.
Well...... my turbo ate it for lunch.
I am replacing it with the ATS twin carbon clutch. $2000 more dinero.
I will send the single carbon clutch back to ATS and they will rebuild it. Then I will offer someone a sweet deal on it.
Respect
JET
Old Dec 14, 2005 | 03:07 PM
  #196
Sharif@Forged
Forged Performance
Respect
JET
So you had the mack daddy of single disc clutches. How did you manage to destroy this clutch??
Hey Jet, you might want to consider the 1350kg pressure plate on that twin. BTW, we are the largest distributor of VQ35 ATS product in the country. Give us a call if you havent ordered already.
Old Dec 14, 2005 | 03:32 PM
  #197
JETPILOT's Avatar
JETPILOT
Just by getting on it.... and just from a roll even. No launches. No power shifting. It just started slipping.
I would go from a 4000 rpm roll @ about 30 mph. The clutch just started slipping one day and got progressively worse each time I went WOT.
I got the 1100 Kg twin carbon with the standard compound and lightweight flywheel. I bought it already. I took whatever Yasu had in stock as I can't wait for a shipment from Japan. The 1100Kg should be good for 700 fwhp they say. I will see soon if that is true.
Respect
JET
Old Dec 14, 2005 | 03:36 PM
  #198
MIAPLAYA's Avatar
MIAPLAYA
LOL chaulk up another clutch to turbo tq curves Although I'm sad to hear you have to spend the cash at least you know your car has some ***** behind it...
  #199
Sharif@Forged
Forged Performance
Make sure to break it in for 1000miles. I know it will be torture, but the clutch will last longer, and perform better.
Old Dec 14, 2005 | 03:57 PM
  #200
redline350ZZ's Avatar
redline350ZZ
With my success with the Tilton Rally clutch / flywheel combo the fact that it holds 690tq @ flywheel........and costs a little over 1,000..... I wonder why more people dont have it.....
