Gauge orientation: Autometer A-pillar pod
Old Dec 11, 2005 | 07:46 AM
Tekwon-V's Avatar
Tekwon-V
Default Gauge orientation: Autometer A-pillar pod
I got all my gauges ready as my TN kit is in the mail. Also, I got the Autometer A-pillar pod that holds 3 gauges, part number 22809... or something like that haha.
Does this pop in? I tried test-fiting it but i couldnt really orient the pod to pop in. It almost seemed like I had to remove the dash by the "Z vent" by the door/pillar.
I wanted to check before I break the A-pillar pod, lol.
BTW, I got the boost gauge, water temperture, and the oil temperture gauge. I am a baller on a budget and quite could not dish out the $$$ for the wideband a/f. lol.
Old Dec 11, 2005 | 08:06 AM
MIAPLAYA's Avatar
MIAPLAYA
It will kind of slide in between the panels of the car. I'll see if I can get soem better pics of mine tonight.
Old Dec 11, 2005 | 08:45 AM
Meatshackle's Avatar
Meatshackle
Turbo on a budget? Didn't think that was possible.
Old Dec 11, 2005 | 08:58 AM
Zivman's Avatar
Zivman
The pillar needs to be mounted to the stock A-pillar. You need to remove the stock one and drill holes for the push pins that were supplied with the autometer pillar pod. there should be instructions that came with it.
Also, you should have skipped all the other gauges in favor of a wideband, especially on a TN kit. If you had a custom tune, you could get buy without one. But because TN uses a cookie cutter reflash you could be running a lean AFR and you wouldn't even know about it until it's too late.
Just look at all the recent posts about lean AFRs with that kit.
Old Dec 11, 2005 | 10:38 AM
Tekwon-V's Avatar
Tekwon-V
hmm, so it's a replacement, rather than an overlay-style. MIA, is yours an autometer one too?
haha yea. i am hoping the ecu reflash would 'work out' for me as i will have no other modification than the kit itself. i am just keeping my fingers crossed. from what i've read, people with additional modification (in addition to the kit) are having most problems with it.
i am going to have the car on the dyno soon after the install to make sure everything is ok before i get jiggy with it. at that time, if necessary, i will get a custom tune, along with additional parts such as wideband a/f. i have posted a thread about this issue too.
Old Dec 11, 2005 | 10:42 AM
Zivman's Avatar
Zivman
NO, the autometer attaches to the stock A-pillar
Old Dec 11, 2005 | 10:47 AM
Tekwon-V's Avatar
Tekwon-V
lol, i re-read your post and understand it now. i guess i will just have to muscle it in with a finesse.
Old Dec 11, 2005 | 10:48 AM
Zivman's Avatar
Zivman
lol, i re-read your post and understand it now. i guess i will just have to muscle it in.
Pull off the oem A-pillar - no need to muscle anything in
Old Dec 11, 2005 | 12:23 PM
BLN350Z's Avatar
BLN350Z
There is NO NEED to remove the stock Apillar. The Autometer Apillar just slides over the Stock one and it isn't very hard to do. I don't even use the push pins supplied with mine as it is a tight and Factory looking fit without them!
Old Dec 11, 2005 | 12:57 PM
Zivman's Avatar
Zivman
As easy as it is to remove I recommend you mount it the correct way. It just snaps off. just sliding it over the stock a-pillar without securely mounting it in place is a bit ghetto IMO
Old Dec 11, 2005 | 01:00 PM
BLN350Z's Avatar
BLN350Z
You Couldn't tell the difference if you tried except you don't see the push Pins Mr Ghetto!
Old Dec 11, 2005 | 01:17 PM
MIAPLAYA's Avatar
MIAPLAYA
If you check the AFR post install and its good (in the piping not the tailpipe) as long as you dont bolt on a basically staright pipe exhaust or install cams you should be fine. I'd rather have a cookie cutter flash that works for 95% of the customers then a James Bond smoke screen.
Old Dec 11, 2005 | 02:05 PM
failsafe306's Avatar
failsafe306
Hey, I grew quite fond of my Z's smoking habits; cops couldn't read my plates haha!
Old Dec 11, 2005 | 02:49 PM
BoOsTedz33TT's Avatar
BoOsTedz33TT
you got a 3 gauge A pillar me too, i always wondered whats gonna happend if my side airbags blow, im gonna have a wideband in my mouth
Old Dec 11, 2005 | 03:40 PM
Tekwon-V's Avatar
Tekwon-V
i looked into the whole curtain airbag issue a while back. wasnt able to find a clear answer but i think it will be ok.
Old Dec 11, 2005 | 03:47 PM
Tekwon-V's Avatar
Tekwon-V
Originally Posted by MIAPLAYA
If you check the AFR post install and its good (in the piping not the tailpipe).....
tail pipe method isn't as accurate?
Old Dec 11, 2005 | 04:13 PM
MIAPLAYA's Avatar
MIAPLAYA
Not even close...
Old May 26, 2006 | 10:07 AM
james840a's Avatar
james840a
Im looking for a 3-gauge pod, a-pillar. But i want dont want to slide over the Stock one. I thought i saw somewere that there is a direct replacement ver. Can someone help me out? plus a web link to order too.
Thanks
Old May 26, 2006 | 10:23 AM
overZealous1's Avatar
overZealous1
the autometer one is still a very clean install, and it covers so much of the factory pillar, you can bairily tell it is laying over it. now i have a question, how the heck are you guys running the wiring to the gauges if you are not pulling off the stock pillar?
the install will be much better if you pull the stock pillar, it is simple (just pull on it) and drill the holes to mount the pillar and do your wiring in one shot.
Old May 26, 2006 | 11:37 AM
MIAPLAYA's Avatar
MIAPLAYA
I have pics of my gauges here http://members.***.net/turbonetics350z
