BLOW THIS!!! or should i?
Old Dec 12, 2005 | 10:56 PM
NOBI's Avatar
NOBI
Default BLOW THIS!!! or should i?
from an engineering standpoint would it be safe to run boost with the AAM or motordyne spacers? ie would they leak because of the 2 sets of gaskets?i plan on going vortech in the future and want to do the whole plenum mod, or spacer, but dont wnat to be stuck with something that has to be taken off when the blower goes on. thoughts please!
Old Dec 13, 2005 | 02:44 AM
teh215's Avatar
teh215
You'll be OK.
Old Dec 13, 2005 | 04:35 AM
jpc350z's Avatar
jpc350z
Default AAM Spacer
I have the AAM spacer and Vortech now for about 1k miles and no problem..
Old Dec 13, 2005 | 04:55 AM
taurran's Avatar
taurran
Turbo + Motordyne = Good. See sig.
Old Dec 13, 2005 | 11:02 AM
NOBI's Avatar
NOBI
thanks guys, hey jpc what kind of numbers are you putting down?? and i see you have dc stainless, how did that effect your exhaust note? i have the hi power exhaust at rt cat combo and its a tad raspy unless its really hot. getting them put in tomorrow and i cant wait to see how it sounds.
Old Dec 13, 2005 | 11:35 AM
jpc350z's Avatar
jpc350z
The headers made the exhaust note very noticable and mean sounding..The last dyno with the 3.12 pulley got me 314 ft lbs Tq. and 380 Hp..
Old Dec 13, 2005 | 01:23 PM
dynamic6er's Avatar
dynamic6er
No Leaks! Tested to 15PSI on vehicle and 30PSI on the bench. CNC Quality mating surfaces have a better finish then stock and we use a modified OEM gasket to ensure 100% sealing.
Old Dec 14, 2005 | 08:18 PM
NOBI's Avatar
NOBI
thank you for all the input! looks like its a spacer afterall.
Old Dec 15, 2005 | 02:02 PM
BamBam's Avatar
BamBam
Just to add to Dave's mention.. I am running the AAM spacer and doing boost up to 10 PSI now. Running fine for over 2K miles.
Building engine and expect to be running MUCH higher in the spring....
Old Dec 15, 2005 | 02:20 PM
NOBI's Avatar
NOBI
let us know how it goes.
Old Dec 15, 2005 | 09:22 PM
BamBam's Avatar
BamBam
Will do.
I think either Dave or I will start a thread about the build soon. It should be pretty extensive and take a few months to get everything done right.
--B
apex locator
Jul 23, 2021 02:27 AM
m_0g
Jun 3, 2021 10:05 AM
Juztin
Nov 22, 2015 07:03 AM
brooklyn
Feb 10, 2003 02:35 PM
