Just started my Turbonetics Install !!
Old Dec 29, 2005 | 11:25 PM
  #61
MIAPLAYA's Avatar
MIAPLAYA
LOL good stuff...keep us posted..
Old Dec 30, 2005 | 05:47 AM
  #62
Alberto's Avatar
Alberto
Cranky FI Owner
Originally Posted by Ep3
Good to hear you finally started alberto you had that kit in the closet for how long?.. now you can make some $ off the TT guys good luck w/ everything
Old Dec 30, 2005 | 06:49 AM
  #63
EM-EFER's Avatar
EM-EFER
Hey alberto, Did you have to put back on the plenums right away?? It could have made it easier for getting at the downpipe for tightening it.. also for the IC piping to get at it from the top
Old Dec 30, 2005 | 06:54 AM
  #64
EM-EFER's Avatar
EM-EFER
I would like to know just to make my install go a little easier
Old Dec 30, 2005 | 07:24 AM
  #65
redline350ZZ's Avatar
redline350ZZ
I kow having the plenum out of the way help'd with my tranny removal
also while u have it off.....Change the pluggs..so much easier to do it then....
Make sure Fuel pump doesnt get tangled....Fuel lines and all....Tank gauge wont read right......
Heat wrap made a big diffrence in cooling..Engine doesnt seem to get too hot...
And when doing the 2 taps....you dont have to go crazy cause they are taper'd.....
The wastegate turbo assy install was my most PITA part....Helps to put a little crazy glue on nuts to keep them in place....
and the glue on the turbonetic heat wrap will burn off...( the wastegate downpipe) I would say use regular wrap on that part to prevent the smoke... IMO
and MIA server forum???? hehehe
Old Dec 30, 2005 | 08:02 AM
  #66
Alberto's Avatar
Alberto
Cranky FI Owner
Yes the plenums are back on the car, and I already swapped in som e1 step colder Iridium plugs...will begin working on it again shortly.
Old Dec 30, 2005 | 03:56 PM
  #67
MIAPLAYA's Avatar
MIAPLAYA
The server webpages are pretty much done..I just need to get the server configured properly before its finished. I know I've been lagging but work has been hell lately...
Old Dec 30, 2005 | 10:17 PM
  #68
Alberto's Avatar
Alberto
Cranky FI Owner
Exclamation
Ok well worked for a long time on the install today, got a lot done. First off let me mention some things that I thought were a pain in the d!ck that I hadnt heard mentioned before.
The 9/16" drill bit for the oil return tap, most standard 10mm chuck drills wont hold a bit that large, cuz that drill bit has a 13mm chuck, so I had to go to Home Depot and rent a drill that could barely hold it in. The weak bracket holding the a/c line you have to push out of the way sucks my b@lls because you reuse the factory bolt that holds the dipstick guide-which is a little on the short side after adding the bracket. We messed with that for almost 1 hour with no success so I finally said screw the guide and put the bracket in without it. The 1 hex bolt on the exhaust side o fthe turbo connected to the bracket connected to the ac compressor is retarded too, would be much easier if it was a regualr bolt head instead of a hex. And the worst part of all-THE WASTEGATE. What a PITA, it is very difficult to install the top bolts coming through the discharge pipe down into the wastegate. If you know a midget, call him over and have him put his little hands up there to put the bolts through, it was very difficult. We ended up running mad extensions from above with swivels to tighten those
Other than those headaches it was cool, oh and I wasnt thinking and cut the oil return to specs but my oil return is in the pan spacer so I shouldnt have cut that line because now it wont reach, so Ill replace it with longer hose tomorrow. All we have to do is mount that back down pipe which will take 2 minutes, and run the IC piping.
I had a friend that likes to do electrical start the Fuel pressure guage and Innovate wideband install. The FP was np problem Im runnign that to an SPT fuel line tap.I had heard the wideband wouldnt reach but I figured out a way. I had a friend run the wires down through the shifter assembly right down to the center of the car where the extra bung will go, no need for lengthening or drilling the floorboard which Ive also heard. Other than the pipes go together pretty smoothly, and we heat wrapped what we could.
Pics coming....
Old Dec 30, 2005 | 10:23 PM
  #69
Alberto's Avatar
Alberto
Cranky FI Owner
First pic are the Innovate wideband wires being run down the shifter assembly.
Second pic-under car shot of WB comign down through shifter assembly -dont worry its not close to the driveshaft.
Third pic-WB zip-tied with the clip/harness inside of the undertray away from wind, 02 sensor awaiting last downpipe.
Fourth pic-inside car shot witgh everything apart...
Attached Thumbnails Just started my Turbonetics Install !!-iwbin-large-.jpg   Just started my Turbonetics Install !!-incomingdown-large-.jpg   Just started my Turbonetics Install !!-intied-large-.jpg   Just started my Turbonetics Install !!-gauge1-large-.jpg
Old Dec 30, 2005 | 10:26 PM
  #70
Alberto's Avatar
Alberto
Cranky FI Owner
Heat wrapped piping and turbo sitting in car pics...
Attached Thumbnails Just started my Turbonetics Install !!-wrapped-large-.jpg   Just started my Turbonetics Install !!-wrapunder-large-.jpg   Just started my Turbonetics Install !!-uwrap-large-.jpg   Just started my Turbonetics Install !!-snailin-large-.jpg
Old Dec 30, 2005 | 10:50 PM
  #71
vitaminZ's Avatar
vitaminZ
Thumbs up
+1 lol
you are almost on the homestretch. i like the way the innovate wiring was run. never thought of that. is the shifter sealed in someway so that water CAN"T make it's way into the vehicle? Good job! :thumbsup:
Old Dec 30, 2005 | 11:01 PM
  #72
Alberto's Avatar
Alberto
Cranky FI Owner
The shifter is just sealed with that metal ring and some rubber and sound deadning stuff, it will be fine My goal is to finish tomorrow before 4pm so me and my friends can get cleaned up and party hard to celebrate the install and this past year....
Old Dec 31, 2005 | 09:24 AM
  #73
MIAPLAYA's Avatar
MIAPLAYA
Congrats bro....Sorry I couldn't have been more help last night...Glad you figured out the wastegate bolts..they are in fact a PITA to get on...Quick tip, if you haven't already installed the charge piping. There are three pipes that get the air from the intercooler to the MAF. The first one is easy its like a U bend, the second one runs along the bottom of the pullies, on that pipe if you already installed the oil feed line to the tee tap..its going to have to come off, the next pipe is the weird curved pipe. HUGE NOTE HERE, install the 45 coupler to the second pipe with BOTH t bolts on there when you mount it to its solid mounts. It is a PITA to fit your hands down there past the fans when you put on the 3rd pipe and getting a t bolt over the coupler after its on is dam near impossible...
Old Dec 31, 2005 | 10:18 AM
  #74
Alberto's Avatar
Alberto
Cranky FI Owner
^^ Thanks man Ill be on that soon.
Old Dec 31, 2005 | 11:08 AM
  #75
protocav's Avatar
protocav
as far as i remember, you need to drill 3 holes in the bottom of the fuel pump assembly, instead of 2.
Chad
Old Dec 31, 2005 | 01:25 PM
  #76
MIAPLAYA's Avatar
MIAPLAYA
Chad
In the G instructions it says 3 but in the Z instructions it only says 2. I'll have to ask Johnny what the difference is but I imagine 2 should work just fine..
Old Dec 31, 2005 | 02:54 PM
  #77
down_shift's Avatar
down_shift
Can you show me more info on heat wrapping the piping etc? Which pipes etc? And also where to get heat wrap? I need to get ready to do mine.
Old Jan 1, 2006 | 05:05 PM
  #78
nissansource's Avatar
nissansource
Almost There
Old Jan 1, 2006 | 05:09 PM
  #79
vitaminZ's Avatar
vitaminZ
Hoping for a positive outcome. keep us posted!
Old Jan 1, 2006 | 05:39 PM
  #80
kalima275Z's Avatar
kalima275Z
Get 'er done!
