Greddy Mushroom of Death replacement
Old Jan 14, 2008 | 05:33 AM
  #81
DJ SMITTY's Avatar
DJ SMITTY
CIN Motorsports
I'm ordering my K&N's today. My turbos were just gross when we took them off. F'ing mushrooms of death haha.
Old Jan 14, 2008 | 05:43 AM
  #82
QuadCam's Avatar
QuadCam
Originally Posted by Audible Mayhem
i would go with some 150 mm HKS filters, they are perfect replacemtents and have many different color filter elements...
check them out
I want to figure out a way to run full 3" inlet pipes all the way to the turbos!!!
Old Jan 14, 2008 | 07:01 PM
  #83
punish_her's Avatar
punish_her
Originally Posted by NCPG
Does anyone know, offhand, the filter area of the Greddy Mushroom filters? I was going to compare it with some of the K&N options.
Its a little more dificult than say the K&N's. Since its esentialy a dome and not quite a half a sphere you can get a decent estimate by taking the distance from the top of the dome to the base and multiply that by the circumfrance of the base of the filter. By doing that you essentialy divide it out to a parabala. You can get a decent idea but will need trig to get an accurate measurement of the surface area.
Old Jan 14, 2008 | 07:02 PM
  #84
punish_her's Avatar
punish_her
You have plenty of room down there, all you need is the correctly bent 3" pipe and a 3" coupler.
Old Jan 15, 2008 | 05:04 AM
  #85
QuadCam's Avatar
QuadCam
The driver's side is pretty tight with the AC compressor right there. Also, I'm pretty sure that both motor mount brackets need some working over with a die grinder, too.
Old Feb 27, 2008 | 11:08 PM
  #86
KarenZ's Avatar
KarenZ
does anyone know if the hks filters are better than the greddy filters?
Old Feb 27, 2008 | 11:20 PM
  #87
punish_her's Avatar
punish_her
Irealy doubt it. Foam rubber is foam rubber. The holes are WAY too big but they have to be to make the filter breathable since the material it self isnt. The K&N on the other hand the material is ALL breathable so you have the tighter holes and the oil which give FAR superior filtration.
Old Feb 28, 2008 | 07:07 AM
  #88
IslandZavage's Avatar
IslandZavage
does the replacing the musrooms cause anyone to have to re-tune? any noticable difference aside from air filtration being better?
Old Mar 17, 2008 | 05:23 PM
  #89
Barzten1's Avatar
Barzten1
subscribed
Old Mar 24, 2008 | 06:49 PM
  #90
Barzten1's Avatar
Barzten1
I should be getting my in the next couple days. Havent driven it in 5 weeks. Talk about blue ballZ! Any updates?
Old Mar 24, 2008 | 07:25 PM
  #91
Bullitproof's Avatar
Bullitproof
check them out
Can you link me to the page? I was looking on the hks website and i dont order the wrong thing.
Old Mar 25, 2008 | 06:53 AM
  #92
merlin3's Avatar
merlin3
check them out
Do you have a part # as I'm not sure what all you need. I see the filter elements available but everything else I see is like an intake kit.
Old Mar 25, 2008 | 06:59 AM
  #93
Jason333's Avatar
Jason333
hi
http://www.hksusa.com/products/?id=787
Those are the replacement filter elements that you need. Just use the size Jeremy stated (ie 150mm under element size). They have different colors, so no one part #.
Old Mar 25, 2008 | 07:31 AM
  #94
merlin3's Avatar
merlin3
but that's just the element am I supposed to take my greddy filters apart and use those?
Old Mar 25, 2008 | 08:42 AM
  #95
TTRANK's Avatar
TTRANK
Just pulled my motor yesterday and my driver's side turbo was nasty from all the blow by I get on that side. My pass side has a catch can and was nice and clean.
While it's out we are going to make new intake pipes for my AEM filters that go behind the grille so I can ditch one pair of silicone couplers.
I'll post up pics when they are done and if anyone wants him to make some for them I'll send you his number.
Old May 24, 2008 | 07:25 AM
  #96
03VQ35DETT's Avatar
03VQ35DETT
has anyone tried any stainless steel air filters instead of cloth type filters?
i'm not exactly sure how well they filter but i've seen one in person and it looks like it does some pretty fine filtering and flow quite a bit but it does say that they are for track use only. but when you think about it can they really be any worse than the mushrooms heh. i think i make pick up a couple and see what happens. i'll probally remove my plenum and clean out the aftermath of the mushrooms before i go with the stainless to see if they keep the plenum any cleaner.
Old May 24, 2008 | 08:20 AM
  #97
QuadCam's Avatar
QuadCam
I've never heard of a stainless steel filter. Are you sure it isn't just a stainless steel mesh a cotton/gauze filter element sandwiched within the stainless mesh.......like a K&N.
Old May 24, 2008 | 08:37 AM
  #98
DaytonaRoadster's Avatar
DaytonaRoadster
Originally Posted by TIMMAHH
This is what I made for my G. It uses two AEM dryflow filters. I put my water/meth pump between them for a perfect fit.
nice set-up, they are even easy to clean
Old May 24, 2008 | 10:44 AM
  #99
03VQ35DETT's Avatar
03VQ35DETT
thats what i thought at first too when my friend told me about them but i have his in my hand right now and its 100% stainless steel mesh only. its a few layers of it but its all stainless
sales@czp
Sep 23, 2019 03:30 PM
350z82
Oct 1, 2015 06:25 PM
