Which Radiator for FI Z
Old Mar 22, 2006 | 05:16 AM
MoodDude's Avatar
MoodDude
Default Which Radiator for FI Z
Wanting to upgrade my Radiator for my APS TT Z. I wanted some suggestions from other FI people on what to do to increase water cooling.
Should I replace the radiator and/or remove the thermostat?
If I replace the radiator, what will give me the best performance for the money:
1. Stillen
2. ARC
3. Blitz
4. PE
5. Koyo (my shop has told me they have had many failures with Koyo on TT Z's)
Thanks
Old Mar 22, 2006 | 05:47 AM
chimmike's Avatar
chimmike
I'd say ARC might be the best, but defniitely not for the money. ARC stuff is highway robbery with a capital R. Stillen is highway robbery too, but to a lesser extent.
I would check and see if Griffin makes a radiator for the Z yet. They make some nice stuff.
Old Mar 22, 2006 | 05:49 AM
Zilvia's Avatar
Zilvia
no real need for one, unless your gonna be tracking...but its a good way to prevent a prob.........I would sya the griffin but i think it larger than the stock
Old Mar 22, 2006 | 05:52 AM
ReV2Red's Avatar
ReV2Red
I haz da turbos
I thought Koyo was quite a reputable manufacturer of radiators.
Old Mar 22, 2006 | 05:56 AM
MoodDude's Avatar
MoodDude
I do track my car, and I live in Southern Georgia, so it gets hot here in the summer, and until now, have to stay way from the track when during the summer.
I thought the same of Koyo, yet the Z specific shop I go to says they experienced problems with them (not the install, but actual failure of the radiator).
Old Mar 22, 2006 | 06:00 AM
Zilvia's Avatar
Zilvia
well than def get one..............didnt know there we so many actually ...........
Old Mar 22, 2006 | 06:11 AM
MIAPLAYA's Avatar
MIAPLAYA
The Koyo has had fitment issues with APS cars in the past although I have heard they fit right in as well. PE seems to be a good one. Stillen as well..
Old Mar 22, 2006 | 06:39 AM
thawk408's Avatar
thawk408
Have you tried just replacing the thermostat?
Old Mar 22, 2006 | 06:40 AM
Gman2004's Avatar
Gman2004
I have the PE and it works fine especially here in the FL heat. It's a direct fit and no cutting of fans or shroud is required. I had to switch a stock radiator cause it was losing water under pressure. A breather tank is a good idea also. It will purge any air bubbles you may have in the cooling system.
Attached Thumbnails Which Radiator for FI Z-breather-tank-001.jpg   Which Radiator for FI Z-breather-tank-003.jpg
Old Mar 22, 2006 | 06:46 AM
Zivman's Avatar
Zivman
1. Stillen
2. ARC
3. Blitz
4. PE
Thanks
I have the Koyo on my APS TT setup. Fitment is great, basically direct drop in. I haven't heard about isssues with them, but maybe I am just talking to the wrong people. A local to me just bought a stillen for his Z (N/A) and claimed it was not direct drop in. Don't know if that is true or not, but what I do know is he paid like 600 bucks for it vs the 350-400 the koyo costs.
Old Mar 22, 2006 | 06:47 AM
MoodDude's Avatar
MoodDude
Not yet, was thinking of removing it completely since there are no such thing as Winter in Southern Georgia!
Old Mar 22, 2006 | 06:49 AM
MoodDude's Avatar
MoodDude
Was planning on getting a breather tank. How has the PE performed? Did you notice a big improvement in your temps?
Old Mar 22, 2006 | 06:50 AM
ReV2Red's Avatar
ReV2Red
I haz da turbos
Zivman, how long have you been running with the KOYO, cause thats the one i'm looking at getting, but i dont want to find out later that it wil fall appart.
Old Mar 22, 2006 | 06:53 AM
thawk408's Avatar
thawk408
On the APS kit the turbos are water cooled, right? Does this run off of your engine coolant?
Old Mar 22, 2006 | 07:11 AM
Zivman's Avatar
Zivman
I have only had it on since Nov. I put about 1500 miles on the car since then. MN and winter and all
Zippycar has had this on his car for a while and tracks the heck out of it:
LINK
Old Mar 22, 2006 | 07:15 AM
MoodDude's Avatar
MoodDude
There is no water ran to the APS turbos. APS only connects the oil to the turbo's and this actually cools the turbo's. I have installed an oil cooler for this reason. Yet, since I am making twice as much hp than stock, I need a radiator that will take all that extra heat away from the engine.
Old Mar 22, 2006 | 07:19 AM
chimmike's Avatar
chimmike
I think you'll find a set of slim fans will help too (high cfm ones that is)
ReV2Red's Avatar
ReV2Red
I haz da turbos
I thought the APS turbos were water cooled aswell. In fact im almost 100% certain they are.
Old Mar 22, 2006 | 07:22 AM
Zivman's Avatar
Zivman
+1
Old Mar 22, 2006 | 07:25 AM
MoodDude's Avatar
MoodDude
LINK
Just wondering, what does your dyno look like. Since your torque is much higher than your HP, I am assuming that you Torque must come down at higher RPM's?
