my vortech tuner kit install process thread
Old Mar 8, 2007 | 09:32 AM
  #301
sentry65's Avatar
sentry65
the burninator
yeah I'm running a different belt setup, I think I documented what it is that was done and part numbers etc on the last couple pages. You'll need a different size belt too
It does help prevent slip and is easier on the bearings. It takes a bit to do and will delay your install to have the idler pulley machined or if you bought a replacement pulley which might take awhile to be delivered since it isn't a commonly stocked part...I do have my stock pulley I think still I might be willing to sell after I get some more miles on my car though, but it'd probably be a month or so before I'd want to sell it
Really though, for the stock power levels or even the 3.12 pulley, belt slip probably isn't nearly as much of an issue as when you start going for higher boost
Old Mar 8, 2007 | 04:13 PM
  #302
MUZZY's Avatar
MUZZY
yea i've dont the research and i think im not going above the 3.12 pully w/ stock internals/injectors. im hoping to hit 400rwhp next week on the dyno.
Old Mar 8, 2007 | 09:44 PM
  #303
sentry65's Avatar
sentry65
the burninator
here's some more pictures I took the other day. Some people were wanting to see some better pictures of the belt setup and water injection nozzle, etc
Attached Thumbnails my vortech tuner kit install process thread-dscf8248.jpg   my vortech tuner kit install process thread-dscf8250.jpg   my vortech tuner kit install process thread-dscf8249.jpg
Old Mar 9, 2007 | 05:31 AM
  #304
THE TECH's Avatar
THE TECH
Good stuff. Do you know if that pulley mod allows the belt to not have to be as tight to work properly? I fear that having the belt sooo tight is just gonaa end up killing parts fast.
Old Mar 9, 2007 | 07:18 AM
  #305
sentry65's Avatar
sentry65
the burninator
Looking at the design of it, I've been thinking you don't have to crank the belt so tight to reach high boost. I mean, the normal design has the belt being tight around everything except the supercharger pulley which is probably where the least tension is.
From what I can tell, this belt design evens things out a little more so there isn't such a drastic difference in tension
Old Mar 23, 2007 | 11:50 AM
  #306
sentry65's Avatar
sentry65
the burninator
had some minor work done
had an X-pipe welded into the APS exhaust - sounds better IMO than as a true dual. In a way it's slightly quieter with it, but it sounds more like a Z than it did with the pipes being seperate.
had my front brake pads changed from hawk HP+ to Axis Ultimates. There's less bite, but the squeeling is gone which I lived with for almost a year and was getting tired of hearing all the time - it's not like I'm always going to bed in my brakes every month either to reduce the squeeling.
I had the SPC toe bolts installed and got my rear camber to -1.6 degrees. Previously it was -3.5 as it turned out. I had to remove the small GTspec tie brace that connects to the toe bolts because the toe bolts are now more towards the center of the car. The GTspec bar can probably be modified to make it fit, but I honestly don't think that particular bar does a whole lot. I can't say I've noticed it being gone anyway. The other GTspec bars are the ones that really seem to make a difference
that's about it. I had some fluids changed too etc.
I think my tires are slightly flat spotted. After my last dyno session, ABS is disabled for a bit and I had a couple really hard stops without ABS and had wheel lock. So now I have some fairly severe vibration around 70-75mph, especially when I give it a little throttle, just cruising on the highway. It only started happening after those two times I locked the wheels. Oh well, hope it smooths out. There's a chance it might be lots of things I recently changed though and I'm going to have to troubleshoot it piece by piece
I bought the Fcon V-pro from GTM and will be going there sometime mid to late april. I'd go sooner but I have some things going on with some projects with my job. Sam sounded pretty confident he could find what the issue was with my fuel pressure and fix it - and also install the CJM stage 2 fuel line while we're at it.
Attached Thumbnails my vortech tuner kit install process thread-xpipe2.jpg   my vortech tuner kit install process thread-xpipe1.jpg   my vortech tuner kit install process thread-xpipe3.jpg
Old Mar 23, 2007 | 02:47 PM
  #307
THE TECH's Avatar
THE TECH
I assume that the x-pipe is just regular steel.
Old Mar 23, 2007 | 03:02 PM
  #308
sentry65's Avatar
sentry65
the burninator
it's stainless, I didn't bother to polish it or anything
Old Mar 23, 2007 | 03:10 PM
  #309
Barzten1's Avatar
Barzten1
So do we have a fix for our fuel issues?
Old Mar 23, 2007 | 03:15 PM
  #310
sentry65's Avatar
sentry65
the burninator
not at the moment
in mid to late april I'm going to GTM to see if they can figure it out, and also install the stage 2 hard fuel line.
Old Mar 23, 2007 | 11:01 PM
  #311
sentry65's Avatar
sentry65
the burninator
oh BTW the part number for the belt I'm using with the 2.87 pulley and the TIMROD belt mod plus extra pully is
GATES belt (this one was sold by NAPA so has the NAPA logo on it)
part # 5610217
It also has the number "25-060910" written on it
About the extra pulley I have by the jackshaft pulley,
I talked to my installer and he said he bought the pulley from one of their suppliers. If you call Dynocomp and ask for Jon he can probably sell you one
480-596-0500, then press 2
he said there was a hole already in place, but it had to be drilled out a little bigger. He did have to put a bolt through it and tap it which they had sitting around the shop.
The pulley looks to have a diameter somewhere around 2.5 inches or so just from eyeballing it. I haven't measured it or anything though - I'm not sure if they actually measure the surface area that the belt wraps around or they also count the size of the lip with it.
Old May 15, 2007 | 12:01 PM
  #312
n1cK!'s Avatar
n1cK!
Infiltrator!
just subscribing...lots of good info here. thanks a lot for posting this!
Old Jun 30, 2007 | 09:45 AM
  #313
xxbboiixx's Avatar
xxbboiixx
great info, ill be going f/i in early september, if i do the new belt setup what belt would i have to use with a 3.12 pulley??
Old Jul 6, 2007 | 05:28 AM
  #314
Mr_pharmD's Avatar
Mr_pharmD
Hey sentry, will GT-SPEC 4 Point Mid Chassis Brace help get tractions at launch? If not, is there anything that will help?
Old Jul 6, 2007 | 06:16 AM
  #315
sentry65's Avatar
sentry65
the burninator
no...
tires and LSD mainly
solid mounts, stiffer bushings, more rear weight bias, and soft rear springs after that
Old Jul 26, 2007 | 06:43 PM
  #316
Mr_pharmD's Avatar
Mr_pharmD
Hey sentry, is this the belt? Imperial Length:91.68" (2329mm)
http://www.napaonline.com/MasterPage...t+-+Serpentine
part # 5610217
Old Jul 26, 2007 | 07:40 PM
  #317
sentry65's Avatar
sentry65
the burninator
probably
Old Jul 26, 2007 | 09:14 PM
  #318
Mr_pharmD's Avatar
Mr_pharmD
i read u were using the 34 tooth cog pulley instead of the 28T cog pulley but u are still only making 11psi? I thought u were suppose to make more psi due to the smaller pulley?
Old Jul 27, 2007 | 07:01 AM
  #319
sentry65's Avatar
sentry65
the burninator
i'm not using the 34 cog pulley, and am not about to push my luck on the stock block for 20 more whp. IMO my car is making enough power for me to be happy with it. If what I have isn't good enough to where I need that extra 20whp, then I bought the wrong car and setup.
The 34 tooth cog pulley is larger than the stock 32. It's on the other side of the jackshaft
I said that it was an option available to me to make more power. Boost would probably rise 1 psi
I'll go with the 34 tooth pulley when I build the engine.
and because I know someone will ask me:
no you can't just go out and buy a 34 tooth cog pulley. You have to have one custom made. GTM has made them before, give them a call if you want one
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
35reilly
Sep 28, 2015 07:42 AM
samansharif
Sep 25, 2015 12:31 PM
