AEM EMS Now available for 350Z
Old Apr 6, 2006 | 12:31 PM
Old School's Avatar
Old School
Shift_Boost
subscribing
Old Apr 6, 2006 | 12:33 PM
RageWoRX's Avatar
RageWoRX
Sounds great and I know alot of VQ people have been waiting for this.
Leave it up to Larry and the guys at Sound Performance to get the job done.
-Jon
Old Apr 6, 2006 | 12:43 PM
MI 35th's Avatar
MI 35th
OGPremierMafia
I know i have... we will see what the price diff is between a utec with tuner pro depending on how impatient i become will determine which to get...
variable valve timing and rev limit adj for the rev up motor???
Old Apr 6, 2006 | 12:46 PM
SoundPerformance's Avatar
SoundPerformance
Sound Performance
Here is some more info on the AEM EMS' capabilities.
Trust me guys, this is the one product that has enabled the Supras to make 1000+RWHP reliably.
AEM Plug & Play Programmable Engine Management System (EMS)
AEM's Plug & Play Engine Management System (EMS) is the first of its kind and will forever change the way you look at fuel injection tuning! This user-programmable system plugs directly into a vehicle's factory ECU harness and requires no additional wiring. Windows™-based software (2000, NT, 98, 95, ME) makes the task of copying, viewing and manipulating data as simple as a click of the mouse. User-defined templates are easily configurable and enable tuners to establish "quick keys" to any pertinent information during the tuning process. The AEM EMS's infinitely-adjustable software allows tuners to program virtually any combination of engine control, power adders and auxiliary devices, and accurately deliver proper amounts of fuel and correct ignition timing for ANY boost level or operating condition.
AEM EMS Applications»
Installs In Minutes
Since the EMS is designed to work with your specific car, it can be installed in minutes without the need to modify your vehicle in any way. You literally just unplug your factory ECU and replace it with the EMS.
Plug & Play Technology - No Wiring Necessary
Each EMS part number has been designed with a specific car in mind, meaning it will plug in exactly the same as the factory computer it replaces. It uses no adapter loom or external jumper harness. It has been built with the same plug that your factory ECU came with.
Fuel Table Automapping
With AEM's new Fuel Automapping software, you can tune your engine in literally minutes! All you need is an accurate air fuel ratio input and then let the ECU do the rest. You have the ability to define the target A/F ratio at 357 different Load/RPM points as well as all the accuracy criteria. Automapping is included with every AEM EMS sold at no additional cost!
Base Maps Included
AEM always make available base maps to help you get started. They are what you need to start your car, get a basic idle, make you're A/C work and more. AEM actually put hundreds of hours into their base maps on stock cars and even drive them back and forth to work in traffic as final tests. But what about heavily modded cars? Put a Big Turbo on your Si?, How about a ProCharger on your Mustang? Check out the AEM Electronics Forum because AEM makes available all sorts of maps for most of the common modifications. AEM probably already has a map for you!
Programmable Traction Control
Finally a way to put that power to the ground. With AEM's programmable traction control, you can get the 60 ft times you need. No individual wheelspeed sensors are required and you get to program the allowable acceleration rates based on RPM and Gear. This is included with every AEM EMS sold at no additional cost!
Onboard 512kb Datalogger
No more racing with your laptop in the passenger seat! With our 15 channel, high speed internal datalogger, you can finally get the data you need to take it to the next level. With access to over 400 internal operating parameters and featuring logging rates of up to 250 samples/sec per channel and "loop" logging, you'll practically be buried in data! Additionally, the logger can be activated based on a cockpit switch, RPM, car speed, load or throttle thresholds. The supplied AEMLog professional data analysis package supports math channels, multiple file & channel overlays and histograms. Of course, if you want to race with your laptop duct taped to your roll bar, go right ahead because we also feature adjustable speed PC datalogging. Both loggers are included with every AEM EMS sold at no additional cost!
10 Cyl Sequential Fuel Injection
The AEM EMS features 10 sequential fuel injector drivers. Any injector can be configured to fire in any order at any time. Also, any injector can be configured to run as a fully sequential Staged injector of any size. No shortcuts here, the staged injectors are fully sequential and you can define exactly how much fuel they deliver via a 357 point Load/RPM table.
16 General Purpose Outputs
Tired of trying to decide if the ECU should control your Radiator Fan or your Fuel Pump? Well, there's no way you could use all the outputs available on the AEM EMS. With 16 dedicated GPO's you can activate most anything. Both Low Side (switched ground) and Hi Side (Switched +12v) GPO's are available. Each is activated based on user defined Load, Temp, TPS, RPM and Speed thresholds. Alternately, they can be activated by dedicated functions like "Fuel Pump", Cooling Fan", "Gear Dependant Shift Light", AFR Warning light" and so on. Not enough for you? well every unused Fuel (10), Coil (5), Stepper (8) and PW (2) drivers are also available as additional GPO's bringing the potential number of GPO's to a staggering 41. Think about the possibilities.
7 Definable Switch Inputs
Want a 2 step launch control?, want to control your A/C?, want a dry nitrous setup? Want them all at the same time? Well then, what you need are switch inputs, lots of them. The AEM EMS has 7. That's more than anyone else. It's more than enough.
Electronic Boost Control
You don't need to buy a piggyback boost controller ever again! The one that is included with the EMS at no cost is state of the art. It can drive the factory or aftermarket boost solenoids and can work with all boost levels. It can run in open loop (MBC mode) or full feedback with a 357 point boost target table. Not enough? how about a cockpit boost target override switch or having the boost target defined by vehicle speed? The EMS can do it all.
Soft Cut Rev Limiters
Utilizing user programmable stages, the EMS offers 5 distinct modes of rev limiter. With ignition retard, programmable partial cylinder cut of fuel and/or spark and full cut of fuel and/or spark, the combinations are limitless.
2 Step Launch Control
The EMS gives you the ability to define a secondary rev-limiter, commonly called a 2-Step limiter (Full Throttle, Clutch In, you use both feet, 2 step, get it?). With a user defined RPM value and Cut %, you have the ability to tune your launch to suit the track conditions. Additionally, with AEM's definable switch inputs, you can use the 2-step without the requirement of wiring in a clutch switch.
Wet or Dry Nitrous Control
With the EMS, you have the ability to fully control your nitrous system, either wet or dry. The EMS features two 357 point fuel and spark maps exclusively for nitrous. This allows you to add any amount of fuel and retard the timing in any way you like. Add to this the ability to monitor your bottle pressure (with optional sensor) and activate your bottle heater and you have the ultimate nitrous computer. All this control is included with every AEM EMS sold at no additional cost!
Definable Knock Control
There's a reason why all new cars come with knock sensors and there is no reason not to use them. With the EMS, you can. User programmable knock thresholds and full control on the quantity of fuel to add and/or timing to retard, the EMS allows you unmatched ability to use these sensors to their full potential.
Full Idle Control
With support for both PW and Stepper Motor idle bypass hardware, the AEM gives you the flexibility to tune your idle just like the factory. It features adjustable feedback rate, programmable hi idle, timing and fuel trims based on idle speed and more.
4 EGT Inputs w/Fuel Control
The EMS lets you hook up 4 RTD type EGT sensors directly to the EMS. You can log the data or set up a fuel trim based on your exhaust temperature. This gives you the safety to run big boost numbers and only add fuel as you need it.
16/32 Hybrid High-Speed Processor
Utilizing an advanced 16/32 bit hybrid processor by Motorola guarantees the EMS will always be one step ahead even under the most demanding operating environments.
Wide Band O2 sensor Correction
Utilizing the input for the AEM wide band O2 sensor, you can set up a target air fuel ratio map based upon load and rpm and the EMS will auto correct to get you there. Of course you should tune the car first and get as close to your target as you can!!
Old Apr 6, 2006 | 12:55 PM
SoundPerformance
Sound Performance
How much is the Utec? Does it come with a wide band O2 and gauge? How much boost can it read up to?
Old Apr 6, 2006 | 12:57 PM
MIAPLAYA's Avatar
MIAPLAYA
Did I miss the timing control? I don't see that in that post...
Old Apr 6, 2006 | 01:00 PM
MIAPLAYA's Avatar
MIAPLAYA
The tuner packages for the Utec run you about $1499 for the unit, wideband tuner with wideband sensor, map sensor, and remote map switch..
SoundPerformance
Sound Performance
Also, once you guys have the EMS installed, you can get the serial gauge and monitor 19 channels on one gauge!!
This means you can look at load, boost, air temp, water temp, ign timing, speed, and any other data that the aem sees!!
On my car I have the gauges showing fuel pressure, oil pressure, oil temp, tranny temp, Exhaust back pressure, NOS pressure, IGN timing and a few other things!
Then you can data log every one of these things which is invaluable when trying to squeeze every last HP out of a car!!
Every 1/4 mile run I log all those items!!
Here is some more info on the serial gauge!
AEM’s Serial Gauge plugs into the company’s Programmable EMS and has the ability to read 19 channels simultaneously to provide reference for all outputs, including boost, AFR, EGT, H2O, IAT, knock, volts, RPM, vehicle speed, and more! Since it can read all channels at once, AEM’s Serial Gauge eliminates the need to buy a cluster of gauges, or you can link multiple Serial Gauges together to monitor additional channels or to divide your readouts across a few gauges.
The Serial Gauge includes a user-selectable LED display allowing users to set vehicle specific limits, warnings, display ranges and operating ranges. This unit runs the standard EMS datastream by default, and includes 12 preset channels and seven user-selectable channels that are custom-configurable through the PC interface, allowing you to monitor practically anything attached to a sensor. AEM’s Serial Gauge includes user-programmable MIN/MAX storage for EVERY channel and records MIN/MAX values even if you are not using the function—if it’s in the stream the gauge records it. Red, yellow and green LEDs and the center three-digit display are fully user-programmable as well, making this a truly custom configurable unit. Users can set alarms for each channel so that when the signal exceeds a value the Gauge notifies you by flashing all LEDs and switching to the channel where the value was exceeded. User-selectable qualifiers eliminate false warning lights, and the unit includes two outputs to trigger ancillary warning lights based on user selectable conditions. The Serial Gauge also includes user-selectable alarm priority in the event multiple alarms sound, allowing you to set alarm readouts in your order of priority.
AEM’s Serial Gauge includes interchangeable silver and black bezels and pin guides, and black and white faces for a customizable look. Quick-Connect technology allows you to install the gauge and connect the wiring separately for easy installation and less chance of damage to the circuit board. The Serial Gauge includes a harness, wiring to connect to the EMS, a daisy-chain adapter for linking multiple gauges to one EMS and software for a trouble-free installation.
Key Features:
• Monitor 19 channels simultaneously—it’s like having 19 gauges in one!
• Works with AEM Programmable Engine Management Systems Only
• User-programmable datastream channels (PC interface)
• User-programmable MIN/MAX values for every channel (PC interface)
• Includes two input buttons for scrolling through displayed channels and for clearing MIN/MAX values
• 24 user-programmable LEDs and three-digit center display (PC interface)
• User-selectable alarm values include qualifiers to eliminate false warnings
• User-selectable alarm priorities in the event multiple alarms are triggered
• Two outputs included to trigger ancillary warning lights or other devices (lights not included)
• Silver and black bezels and pin guides, and black and white faceplates included for creating custom look
• Quick-Connect technology eases installation
• Standard 52mm gauge housing fits in most pods and can be remotely mounted virtually anywhere
• All necessary hardware and software included for installation
Old Apr 6, 2006 | 01:02 PM
SoundPerformance
Sound Performance
Of course full timing control! And timing control for NOS, meth or any other additional fuel etc......
Old Apr 6, 2006 | 01:03 PM
MIAPLAYA's Avatar
MIAPLAYA
Well I know it has it but I didn't see it described as to what kind of map it uses for that...
Old Apr 6, 2006 | 01:17 PM
mistaboosta's Avatar
mistaboosta
omg this cant be true, its only been 1 month since i bought the utec
Old Apr 6, 2006 | 01:35 PM
plumpzz's Avatar
plumpzz
So is the AEM full standalone or is it a piggy back? Looks promising, and its helped other cars acheive the best of their abilities.
Old Apr 6, 2006 | 01:41 PM
EM-EFER's Avatar
EM-EFER
AEM is very user friendly GUI for anyone that has worked on them. I had one on my turbo prelude and was able to do all the Fuel maps/Ignition timing myself.
Old Apr 6, 2006 | 01:42 PM
EM-EFER's Avatar
EM-EFER
Standalone but still uses the factory ECU for the electronics.
Kinda like the UTEC.
Old Apr 6, 2006 | 01:43 PM
SoundPerformance
Sound Performance
The AEM is full standalone. However because of the DBW in the 350, you still need to utilize the factory ECU.
In a lot of new cars, because the factory ECU does so much more than just engine control, you will need to retain it for some functions.
Old Apr 6, 2006 | 01:44 PM
plumpzz's Avatar
plumpzz
oO. Wow. This might be something to look into. What price range are you aiming for? FCON range? UTEC range? Emanage Ultimate range (we can dream..)
Old Apr 6, 2006 | 01:47 PM
dmoffitt's Avatar
dmoffitt
So just to clarify - you maintain the factory ecu for the gauges, vdc, etc? or... ?
Old Apr 6, 2006 | 02:21 PM
  #38
NA&CH's Avatar
NA&CH
Does it drive the car?? or make lunch? Sounds like an awesome product. Cant wait.
Thank You Guys
Old Apr 13, 2006 | 11:21 AM
  #39
SoundPerformance
Sound Performance
Bump Finally
Old Apr 13, 2006 | 11:23 AM
  #40
EM-EFER's Avatar
EM-EFER
Bump Finally
Put some prices up
