Which Pistons? 8.5:1 or 9.0:1
Old Apr 6, 2006 | 02:26 PM
veilside350zTT's Avatar
veilside350zTT
Default Which Pistons? 8.5:1 or 9.0:1
Ok guys im doing the short block rebuild now my only hold up is the pistons.. Im getting the Darton Sleeves and going to 100mm..
Here is my dilema(sp)
CP is coming out with pistons that are 100mm and 9.0:1 compression.. Is this good for someone that wants to achieve 700+rwhp? if not what pistons should i go with? I dont wanna limit myself. i know i wont have 700+rwhp for awhile, but just knowing that i could is good to have.
1.) Are the 100mm and 9.0:1 compression CP pistons ok for me?
2.) If not what pistons should i go with? keep in mind 100mm
oh and for those of you that dont know im running Turbonetics Single turbo
Thanks!
Old Apr 6, 2006 | 02:27 PM
MIAPLAYA's Avatar
MIAPLAYA
Arias Extreme Duty...
Old Apr 6, 2006 | 02:31 PM
veilside350zTT
Thats the other pistons i was considering... Does anyone have those in stock? if not how long should it take to get them?
Old Apr 6, 2006 | 02:32 PM
MIAPLAYA's Avatar
MIAPLAYA
http://www.forgedinternals.com/store...cat=248&page=1
Old Apr 6, 2006 | 05:50 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
If my math is right, I just put 2+2 together. Kyle has an email.
The Arias Extreme Duty pistons, IMHO, is the strongest piston on the market for the 350Z...period. We recommend them for all builds above 550whp.
In terms of CR, honestly, you will be hard pressed to notice any difference between 8.5:1 and 9.0:1, both on the dyno, and via butt dyno. I have driven them all, and the VQ trq curve is to buttery, you just dont feel any decrease in off-boost response.
In terms of size, it really is your choice.
Old Apr 6, 2006 | 05:56 PM
D350Z10's Avatar
D350Z10
That is SUCH OVER KILL those pistons should be used in 750-800+ applications, We have Wiesco Pistons pushing high 600's easly and can handle alot more. The problem with this market is one product is ALWAYS used for everything, there are many other brands of the same caliber. And yes thats without sleeves and Fuel Return. Everything Can be done, just have to do it right.
I would go with a custom SGP piston or Wiesco if you can get a 100mm size... just has to be custom.
Old Apr 6, 2006 | 06:05 PM
rs350z's Avatar
rs350z
If your gonna do a build you might as well get the heavy duty, do it right the first time. Youll alwys end up craving more anyways
Old Apr 6, 2006 | 06:47 PM
MIAPLAYA's Avatar
MIAPLAYA
Bingo!!
Old Apr 6, 2006 | 10:18 PM
veilside350zTT
Yea thats how im lookin at it.. why limit myself.. I guess i will go with the Arias Extreme duty pistons 100mm.. Sharif do you have these in stock?
Old Apr 7, 2006 | 12:25 AM
sja177's Avatar
sja177
If it cant hurt to go with the 8.5, as Sharif says, than I would def go with the 8.5. Im pretty sure thats what other cars use that make BIG hp.
Also, what is the hp limit of the Turbonetics kit? Think about everything it takes to get to 700whp not just your pistons and rods...
Old Apr 7, 2006 | 02:25 AM
D350Z10's Avatar
D350Z10
the stage one T-60 can flow MAX of 500whp as it is rated at 550hp flow.
Old Apr 7, 2006 | 06:29 AM
Sharif@Forged
Forged Performance
100mm is in stock, but they heading to another customer that ordered them 3 weeks ago. We can make more!
We've never said anything bad about other manufacturer's pistons, and I have no doubt that Wiseco, CP, and others make a fine piston (we sell them all, BTW). We're just suggesting the parts that have be proven to work under very rigorous conditions. IMHO, there is no such thing as overkill, in regards to piston design. Rods, arguably, can be a bit overkill, becuase most forged 4340 chromoly rods are certainly suitable for 600whp+. But the piston takes the majority of the abuse, and needs to be strengthened to survive under not just ideal conditions, but sub-optimal conditions.
For instance, if one pistons was engineered for 1000whp, and another was engineered for 600whp, you might think that the 600whp piston is more than sufficient for your 550whp buildup. With a perfect tune, and ideal combustion you are correct. Now, last say you are at the drag strip, or road course, and its 100F outside, and your car is running hotter than normal. Maybe your AF ratios have changed slightly, or maybe you have a bad tank of gas. All of this "unexpected" scenarios can result in detonation. In this case, the stronger piston has a much better chance of surviving this type of abuse.
Given that most people are spending between $5000-$10000 in labor in parts to build up their engines, the price difference between a standard duty piston and an extreme duty piston is immaterial, in the grand scheme of your budget.
Old Apr 7, 2006 | 06:35 AM
D350Z10's Avatar
D350Z10
I understand where you are coming from, but like I said over kill, they can save that money and put it towards somthing else. Because there is no such car that is 700-800+ street car its just not possible.. theres no way that much power will hook on the street. And Those pistons are used for EXTREME loads like that power range. All it comes to is saving money!!
Old Apr 7, 2006 | 05:44 PM
veilside350zTT
Wat do you means its not possible to have that much hp..i got plenty of friends that have 700+Hp cars and drive them on the streets daily.. As for me im going to get the Arias Extreme Duty Pistons they are like $300 bucks more, thats nothing when im already spending 8K on my sleeved block.. Probably ordering it monday so i will keep u guys updated.
Arias Extreme Duty Pistons 100mm
Pauter Rods
Darton Sleeves bored from 3.5 to 3.8
ARP main/head studs
Cometic Head Gasket
Knife-Edge,Perp Drilled Crank
clevite or nissan bearings
Next mods will be
AAM Return Fuel System
Kinetix SSR PLenum
AEM EMS
Old Apr 7, 2006 | 05:53 PM
nissansource's Avatar
nissansource
Yah you can drive a 700hp Z on the streets ive done it but you aint gonna want to fill up race gas and run slicks all the time. the car will spin tire at 75mph on frwy ive done it
Old Apr 7, 2006 | 05:55 PM
nissansource
but hell its what 575 for your avg piston hell just for your sake you want more boost then your avg car then spend the extra me personally will be running the arias from shariff once i get a motor and have time to build
Old Apr 7, 2006 | 08:45 PM
Sharif@Forged
Forged Performance
True, but 700whp is perfectly streetable, from 100mph onward. And sooo much fun too.
Old Apr 8, 2006 | 10:39 AM
Metal Heart's Avatar
Metal Heart
Yeah, I giggled at that.
Old Apr 8, 2006 | 12:10 PM
D350Z10's Avatar
D350Z10
So Sharif you wanna do a 100mph roll? Haha
seagrasser
Oct 11, 2015 03:27 PM
B Esquire
Sep 24, 2015 07:52 AM
hardkicks
Sep 20, 2015 12:28 PM
