Gears for FI
Old Apr 29, 2006 | 09:24 AM
HoldThisForMe's Avatar
HoldThisForMe
Question Gears for FI
the 5AT has 3.3 gears...everything else the 3.5....for boosted cars would it be better to get the 3.3 gears? or just leave what I have now? What are you guys running?
Old Apr 30, 2006 | 05:54 AM
bullseye's Avatar
bullseye
Some of the guys with F/I and a 3.5 FD find their cars accelerate so much harder with F/I that traction is an issue in 1st and 2nd gears. Also, very rapid acceleration causes them to mis-time shifts occasionally, causing them to bounce off of the rev limiter. A change to the 3.3 FD, which is a taller gear, has several benefits for these guys: better traction in 1st and 2nd gears, more time in each gear before reaching red-line, and even better highway-cruising gas mileage. How about that?
Old Apr 30, 2006 | 06:22 AM
HoldThisForMe
I think I may just stick with what I have now. Better gas mileage sounds nice but even with the taller gears the way I drive it wont make much of a difference haha. Would be kool if someone had some track times with the difference in gears tho
Old Apr 30, 2006 | 11:04 AM
NISMOFO's Avatar
NISMOFO
One other forum member has mentioned that going to a 3.3 would be a pretty good upgrade if you're FI'd. I could see the advantages...At least 1st gear would be useful if you ever wanted to get on it off the line.
Old Apr 30, 2006 | 11:15 AM
HoldThisForMe
I can see better traction off the line...less likelyhood of hitting rev or need of reving that high?...more top end speed...
Just curious as to the difference of how the car will pull. Even with better traction off the line would the car be slower with the taller gear?
Old Apr 30, 2006 | 12:07 PM
sentry65's Avatar
sentry65
the burninator
I think the 3.3 is only an upgrade if you are turbo. I have a vortech which doesn't hammer out tons of tq at 3500-5000 like a turbo does and I think the 3.9 gears are a great match up - though I haven't been able to drive to redline yet because my 440 injectors aren't big enough for 450whp
Old Apr 30, 2006 | 12:38 PM
HDPDZO6's Avatar
HDPDZO6
From friends I've talked to with FI Z's, 3:5 is optimal for a 5AT. Suuposedly the auto tranny has difficulty shifting in time thru 1st & 2nd with the 3:9.
Old Apr 30, 2006 | 01:06 PM
sentry65's Avatar
sentry65
the burninator
it probably would be fine if you upgrade the valvebody though
Old May 1, 2006 | 10:03 AM
barthelb's Avatar
barthelb
Master
I switched to the 3.3 and this is how the car should have come stock. I still burn through 1st and 2nd and sometimes a lil in 3rd but you can hold a gear longer. 2nd goes to 65ish, 3rd is high 90's, you can cruise at 60 in 4th at about 3krpms i believe, 80 in 6th at 2900. Excelleration seems greater because you are able to go faster and holding the peak boost longer seems faster. Also helps when trying to keep the exhaust sound down because the gear is taller. Sounds weird but trust me the car is a lil quieter.
Old May 1, 2006 | 10:44 AM
HoldThisForMe
Definately sounds promising. If only I could locate someone local who would like to trade pumpkins with me
Old May 1, 2006 | 11:59 AM
gringott's Avatar
gringott
Does the switch to 3.3 from 3.5 effect the cruise control? I thought I read that here somewhere...
Old May 1, 2006 | 12:02 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Given the same traction, 3.5 FD will be faster than 3.3 down the track...
Old May 1, 2006 | 12:53 PM
HoldThisForMe
hmmmm if ur still going to spin that much with the 3.3 then why bother? lol im all over the place with this haha
Old May 1, 2006 | 01:06 PM
sentry65's Avatar
sentry65
the burninator
barthelb, what is your current tire setup?
Old May 2, 2006 | 01:19 PM
barthelb's Avatar
barthelb
Master
245/35/19 & 285/35/19 recently with the weather around 80 in Cal its been gripping alot better and my tires are nearly worn out. I have my new PS2's waiting to be installed so they should grip alot better.
Old May 2, 2006 | 01:39 PM
sentry65's Avatar
sentry65
the burninator
ah cool, what brand/type of tire have you been using right now before you go to the PS2's?
Old May 3, 2006 | 07:35 AM
barthelb's Avatar
barthelb
Master
My last "Set" were PS2's, however the rear only lasted 20k miles, so i had to get another rear and I chose the Bridgestone RE050A's. Which are a pretty good tire. However they don't last as long as the PS2's, they are more like the Toyo's but quieter and have a firmer sidewall.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sherm
Apr 11, 2020 05:21 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
Bodyboarder81
Sep 21, 2015 06:23 AM
Bigsyke
Sep 11, 2015 06:19 PM
