Head strengthening mod
Old May 18, 2006 | 02:06 AM
  #141
mchapman's Avatar
mchapman
Do you think this latest water loss is to do with temps? or head lift?
Is there any carbon in the water?
Old May 18, 2006 | 07:46 AM
  #142
overZealous1's Avatar
overZealous1
Originally Posted by XBS
Now Scott why would you be honest and post that you lost some water, even thought it was 100 degrees. That could affect your sales man what are you thinking!
cause i'm honest, lol.
Old May 18, 2006 | 07:49 AM
  #143
Gman2004's Avatar
Gman2004
good thing......I've been ripped off too many times by dishonest dirty fuking rats!
Old May 18, 2006 | 08:03 AM
  #144
overZealous1
i'm guessing it to be mostly due to the heat. i still have the stock radiator and no aftermarket oil cooler. i started to really drive my car near the end of last summer, and the temps around here were not that high, so i never had probs. but in this 90-100 degree weather, it is very apparent now i need to do all the cooling mods i can think of. i'm currently looking at custom 3" thick rads that i will custom fit, with very large multiple push fans (5000-6000cfm!!)
before i put these studs in the motor, even at 60 degrees, i was running out of water every 100 miles or less without even being able to get into boost. so having to add a little water over about 600 miles now and hot temps and hammering on it too, shows it is definately helping. my head gasket seal was already compromised badly before installing these. someone building a fresh motor or bairily seeing combustion leak issues will get very good outcomes with this mod.
again, this is not designed to completely eliminate the issues of "head lift" from happening, this is just to help strengthen the weakest link i feel is helping create it.
Old May 18, 2006 | 08:04 AM
  #145
overZealous1
oh btw- i didn't see any carbon in the overflow.
Old May 18, 2006 | 08:27 AM
  #146
Gman2004's Avatar
Gman2004
cool! In that case I don't want a refund.
Old May 18, 2006 | 02:31 PM
  #147
mchapman's Avatar
mchapman
Thats great, thanks.
Old May 18, 2006 | 02:44 PM
  #148
ZU L8R's Avatar
ZU L8R
Viper Sellout
I got mine today, gonna try and install on Sat. I'll take pics
Old May 18, 2006 | 03:23 PM
  #149
overZealous1
everybody else should be getting theres today also then. you are the furthest away in FL there.
Old May 18, 2006 | 03:34 PM
  #150
westpak's Avatar
westpak
SFZCC
I am further down
Old May 18, 2006 | 05:31 PM
  #151
failsafe306's Avatar
failsafe306
Didn't get mine, and I'm in the middle of the country. What carrier did you use?
If they don't come tomorrow I'm gonna say "*** it" and put my motor back together as is.
Old May 18, 2006 | 05:53 PM
  #152
booger's Avatar
booger
Omaha Ne...didnt get mine . Friday maybe
Old May 18, 2006 | 08:53 PM
  #153
AmyCroft's Avatar
AmyCroft
Smile Got mine. :)
Scott:
Thank's the kit arrived today. I see what you mean about the "Odd" thread.
The instructions are crystal clear.
Use the existing washer on the plug, and the copper washer provided in the kit. Got you !
Cheers Amy -
Old May 19, 2006 | 03:21 AM
  #154
overZealous1
they all went usps. i remember writing yours up, it is on the way.
Old May 19, 2006 | 03:26 AM
  #155
overZealous1
Originally Posted by AmyCroft
Scott:
Cheers Amy -
ya, the thread pitch is odd. this stuff is made in germany!!
only remove one plug at a time and you will lose no water. well as long as the rad cap is closed, lol. went over that in the instructions.
Old May 19, 2006 | 04:56 AM
  #156
meatbag's Avatar
meatbag
Got mine thursday. One question. After you torque the bolts in how much do you torque the nut down? Same as the bolt?
Old May 19, 2006 | 07:13 AM
  #157
Gman2004's Avatar
Gman2004
Originally Posted by westpak
I am further down
And I am further down than you.
Old May 19, 2006 | 07:43 AM
  #158
ZU L8R's Avatar
ZU L8R
Viper Sellout
Scott, are the allen head plugs reverse thread or something. Mine aren't coming out. Head is stripping.
Old May 19, 2006 | 12:29 PM
  #159
overZealous1
they are in there very tightly. they lock due to the seal they make with the stainless sealing washer. if you are using the perfect size allen wrench, you should have no prob. but yes they are in tight and no they are not left hand thread. if you are using a allen socket for a 3/8" drive, it would be way easier.
Old May 19, 2006 | 12:32 PM
  #160
overZealous1
i used a figure of 1/8th turn after touching bottom on the stud. this is basically to clear the rough sand casting and create a more solid seating surface. the large nut gets torqued to 50ft lbs and is a 1 1/16" socket iirc.
