Ran my car....
Old May 25, 2006 | 02:39 PM
  #101
bigbri's Avatar
bigbri
Ok June 7th Infineon....its a plan EVERYONE go...all the sac z's will caravan there.....excited to meet a bunch of you guys and see a bunch of FI Z's Someone make a thread and a list and everyone sign up...
Old May 25, 2006 | 02:42 PM
  #102
atar350's Avatar
atar350
I wonder if my APS TT will be done by then? Brian, you said your stock exhaust can be bent to stock position instead of center exit right? I need it, lol...
Old May 25, 2006 | 02:43 PM
  #103
bigbri's Avatar
bigbri
Originally Posted by Philthy
Basicly my car is set for 23lbs boost..but it hotter weather it only boosts 20lbs...better description...???
Old May 25, 2006 | 02:44 PM
  #104
bigbri's Avatar
bigbri
Yea bring my buy $400 tonight and it's yours....If not I have a couple of other people that want to buy it...you better go regardless if it's ready..and if you took it in today it should be ready by then...
Old May 25, 2006 | 03:05 PM
  #105
drsifu's Avatar
drsifu
let' do it.
june 7th. curious what i can do at the track my my set-up.
Old May 25, 2006 | 03:18 PM
  #106
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Not sure if you mentioned it earlier...but what pressure were you running? I usually run about 14psi and after the 3rd, I can usually hook up decently down the track. It's a little squirly, but I can nail WOT in most of 3rd, all of 4th/5th....in the low 600whp range.
My launches are still poor...but I agree...proper setup, dialed in correctly, and DR's is all you'll need for easy 10's. Best of luck.
Oh, when you warm up your tires, are you blasting 1st and shifting into 2nd while brake boosting? You need a REALLY good smoke show to get those DR's hot, and I think you'll be surprised with how well they stick.
Old May 25, 2006 | 03:23 PM
  #107
350Z33's Avatar
350Z33
You may want to get some kind of boost controller, and then turn the boost up as you hook up better. A muli-stage boost controller would be ideal IMO.
You'll run low 10s eventually with that kind of power, then they'll make you get a roll cage before they let you back on the track. Good luck.
Old May 25, 2006 | 04:13 PM
  #108
BrianLG35C's Avatar
BrianLG35C
Originally Posted by barthelb
HAHAHHA i can just see yal in a field. bad mental picture. lol
We won't go there. YEEHAW!!
Old May 25, 2006 | 04:51 PM
  #109
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Originally Posted by chimmike
it's almost asinine though, after spending all that on the motor build, that you wouldn't be willing to get slicks and just get it overwith instead of bothering with suspension crap and an alignment just to see IF it'll make that big a difference.....I mean really. Solve it fast. Buy some MT slicks, slap 'em on, and run 10s. Easy.
That's a REALLY ignorant statement. Suspension setup is VERY important for drag racing, even on slicks. I've seen plenty of cars pull the front wheels on drag radials...suspension is the key.
Bias ply slicks aren't some magical fairy dust...they use basically the same rubber compounds as the drag radials with 1930s sidewall technology. There's a reason LOTS and LOTS of competition drag racers are ditching their bias ply slicks for M/T ET Street radials.
Old May 25, 2006 | 05:40 PM
  #110
atar350's Avatar
atar350
You gotta understand, not all of his tire is hitting the ground BECAUSE of the alignment/camber, when I threw my 285's on, it was like I had a 265 on because of bad camber, under WOT it was probably worse, now that the camber is perfect all the tire is on the ground and traction is much better, even if he did get slicks, its not making much of a difference since his camber is jacked.
Old May 25, 2006 | 05:48 PM
  #111
taurran's Avatar
taurran
I'm going to agree that slicks won't matter if your camber looks like your axles have already snapped.
Old May 25, 2006 | 06:22 PM
  #112
bigbri's Avatar
bigbri
I'm fixing my camber before June 7th then everyone will get a show... Also I'd rather burn out on stock axles so I don't break them...
Old May 25, 2006 | 06:51 PM
  #113
bigbri's Avatar
bigbri
Well said.
Old May 25, 2006 | 07:04 PM
  #114
alving's Avatar
alving
11.7 at 128mph...that is absolutely WICKED BigBri.
1) Does this make you the first 350 to break the 12s barrier?
2) Have you rolled/embarrassed any Ferrari's, Porsche's or Lamborghini's?
3) Can I drive it?
4) Do you think it can hang with this?
http://community.webshots.com/photo/...60954891ASPmtc
TRY ME
BTW,for those that have not seen Infineon's strip:
http://community.webshots.com/photo/...66001410gwrWbX
It's an uphill battle
Old May 25, 2006 | 07:19 PM
  #115
taurran's Avatar
taurran
You're kidding, right?
Old May 25, 2006 | 07:21 PM
  #116
JimRHIT's Avatar
JimRHIT
Alving .... we have Zs in the 15s, 14s, 13s, 12s, 11s, 10s, 9s, 8s, and 7s ....
Bri is making a nice statemet with a street car here ... but is no pioneer
Old May 25, 2006 | 07:26 PM
  #117
BoOsTedz33TT's Avatar
BoOsTedz33TT
no 10sec run...slow........JP...leave the car alone, and enjoy it.....
Old May 25, 2006 | 08:44 PM
  #118
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
3) Can I drive it?
TRY ME
Yea..he's definitely the first 350Z lower than 12s.... And you've been here over a year????? Do you live in a hole?
Old May 25, 2006 | 08:47 PM
  #119
Nealoc187's Avatar
Nealoc187
Post up the timeslip I want to see how all the numbers look.
Old May 25, 2006 | 10:07 PM
  #120
bacalhau16's Avatar
bacalhau16
he's gone over pretty much his entire slip
60' 2.1
1/8 mph 98
1/4 et 11.7
1/4 trap 128
this is pretty much his slip. I guess i havent figured out what his 1/8 et is, but just from his conversation with us, this is what the 11.7 run should look like.
