Help on driving with a turbo.
Old Jul 6, 2006 | 02:53 AM
  #41
hurahn's Avatar
hurahn
I'll tell you this: If you start going high horsepower you want to upgrade the wastegates. I got new wastegate springs and I was still boost creeping getting anywhere from 570-620 whp. Now I'm tuned down to a conservative 489whp Should've went open wastegates but I guess that'll be a winter project.
Old Jul 6, 2006 | 09:53 AM
  #42
Alberto's Avatar
Alberto
Cranky FI Owner
Who does your work? Who built your block and tuned your car? How much boost did you spike to when you hit 620whp? What cams?
Old Jul 6, 2006 | 10:58 AM
  #43
hurahn's Avatar
hurahn
AAM and AAM and AAM. I forget what Mike said it spiked to. It was in the tuning stage when we were having the problems. My particular wastegates have been problematic at high boost. They were stuck at one time. 500whp was my goal but the extra 70hp was icing on the cake. JWT cams.
Old Jul 6, 2006 | 01:57 PM
  #44
coachk's Avatar
coachk
Originally Posted by Oleg
So how would this be on a 5AT? When you get on it, it will downshift automatically, therefore boosting in high gears will be avoided. In other words, it is a good match for a 5AT, right?
You are correct as long as you do the VB upgrade.I'm not quite sure about JetPilots comment about boosting when your cruising,last week I was coming back from Orlando and was cruising at 120 and was not boosting at all.Maybe I'm missing something.
Old Jul 6, 2006 | 02:01 PM
  #45
coachk's Avatar
coachk
Sorry Jetpilot I meant the qoute by Oleg.
Old Jul 6, 2006 | 02:06 PM
  #46
coachk's Avatar
coachk
I am about to have another one of my signature nervous breakdowns. Once again, I am at the point at which I want nothing to do with my Z FI-wise.
Now I have this "load" crap to consider.
IS THERE A SINGLE ******* SUCCESS STORY WITH BOOSTING A 5AT CAR???!!!!!!!!!!!!!
Heres one for you, I've only lost one race to date and that was by another Built APS TT Z. I'd call that successful.
Old Jul 6, 2006 | 02:51 PM
  #47
Oleg's Avatar
Oleg
Thank you!
Your tranny setup is identical to what I have planned, except that I will go an extra step and add a tranny temp gauge, just in case.
Where did you mount the cooler anyway?
Also, how long have you been driving with this setup?
Old Jul 7, 2006 | 11:58 AM
  #48
coachk's Avatar
coachk
Thank you!
I mounted the cooler underneath in the back between the fuel tank and the bumber and ran the lines right to the tranny bypassing the radiator.I have had this setup for about 7 months.I'll try and post a picture of it.
Old Jul 7, 2006 | 02:42 PM
  #49
Oleg's Avatar
Oleg
Thank you. Waiting for the pics.
Old Aug 28, 2006 | 04:21 PM
  #50
D15na's Avatar
D15na
i dotn think you guys are explaining it correctly... boosting has to do with load...more load = more boost, hence you only boost when you put the hammer down.,, otherwise you will be runnin a vacuum
Old Aug 28, 2006 | 07:10 PM
  #51
350zDCalb's Avatar
350zDCalb
builtZmotors
The most important answer to this question (about allowed time to boost consistantly) will come from your gauges...
watch your EGT's..they will climb rapidly as you boost, if they start to pass 1600 degrees F, you are about to melt your pistons...so cool it
watch your A/F...make sure that you are not leaning out-everyone will have their opinion on what is too lean, I never like to see 12:1 or leaner..keep it in the 11:1's when in boost (unless you have methanol/water injection- in that case you can run even leaner)
These kits will operate great and the motor should stay in one piece if it is tuned carefully, that is the key!!! make sure that it is not only tuned in WOT ..make sure that the tuner runs the car on the street to "street tune" under many different throttle positions and load to ensure safety..a big mistake people make is go 100% throttle on the dyno, get it perfect... then never check the car on the street or do ANY street fine tuniing at all...
-TODD
Old Aug 29, 2006 | 07:17 AM
  #52
kennychopra17's Avatar
kennychopra17
How did it feel like when you lost your viginity...
it should feel something similar
I've owned 3 turbo cars. Miss it to death.
Can't wait till I go FI with the Z
Originally Posted by mikewagon
supernoob turbo question===Ive never driven a turbo car, what exactly is "boosting" and how do you "boost"
Old Sep 7, 2006 | 05:59 AM
  #53
Ray123's Avatar
Ray123
thats right turbo automatics arent bad at all
Obadabot
Jun 18, 2023 11:31 PM
350Z_Al
Oct 29, 2020 07:44 PM
Mattg350z
Oct 2, 2015 06:51 AM
