where to mount O2 sensor bung?
Old Jul 17, 2006 | 02:31 PM
RA11325's Avatar
RA11325
Default where to mount O2 sensor bung?
The vortech install is about to begin!
Where should i mount my sensor for my wideband? thanks in advance!
Old Jul 17, 2006 | 03:19 PM
TTRANK's Avatar
TTRANK
I put mine on the top of the cat before the first baffle.
It needs to be in that area to get a good reading. After the cat will not be a true A/F reading.
Old Jul 17, 2006 | 05:37 PM
THE TECH's Avatar
THE TECH
You can either do before or after the cat. Unfortunately, doing it before the cat is almost impossible with the exhaust manifolds still on the car. You can do it after the cats if you want, the mixture will just read a bit leaner than before the cats.
Old Jul 17, 2006 | 07:06 PM
RA11325's Avatar
RA11325
I have test pipes, will it be ok to mount it in the test pipe?
Old Jul 17, 2006 | 08:47 PM
THE TECH's Avatar
THE TECH
Sure.
Old Jul 17, 2006 | 10:53 PM
Mr_pharmD's Avatar
Mr_pharmD
anyone got pix of the placement? I always thought it goes into the 02 bung.
Old Jul 17, 2006 | 11:05 PM
taurran's Avatar
taurran
Ryan - have you started your install yet? I'd like to see it if I get the chance.
Old Jul 18, 2006 | 07:37 AM
RA11325's Avatar
RA11325
Just waiting on my gauges to get here, ive got 1 more final tomorrow then its party time
Old Jul 18, 2006 | 08:12 AM
Gman2004's Avatar
Gman2004
I had two widebands in this pictures thus the 4 bungs (2 OEM, 2 a/f).
Old Jul 18, 2006 | 05:09 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Test pipe location is perfect. A shop will have to drill a hole, and weld in a bung for the new wideband sensor. Takes about 30-40mins.
Old Jul 20, 2006 | 01:29 PM
TTRANK's Avatar
TTRANK
With test pipes you will want to get non-fouler's so you don't get a CEL.
There is a thread with all the info:
https://my350z.com/forum/showthread....with+test+pipe
ss350
Mar 4, 2005 06:42 PM
wren57
Jun 22, 2003 12:03 PM
