500hp+ Stock Sleeve Guys...
Old Oct 25, 2006 | 10:33 AM
  #61
Gman2004's Avatar
Gman2004
Originally Posted by S1AMEZE
I guess the real question is who's cracked the stock sleeves pushing what kind of power? Given a setup with upgraded head gaskets, ARP L19's or 1/2", and a nice set of pistons and rods, who's seen the stock sleeves fail?
Anyone?
I am going to upgrade my head studs to the L19's and change the head gasket to an HKS. I am going to have it tuned to as much as she will put out. I hoping to get this done in December/January at Forged. I am currently at 526whp and 526ft/tq on a dyno jet @ 16psi. I am hoping for over 600whp @ 23psi. I have everything except sleeves and valve train on my block.
Old Oct 25, 2006 | 11:17 AM
  #62
Nismo350ZRT's Avatar
Nismo350ZRT
If you can make 600whp reliably with stock sleeves and L19's, that would be great news for alot of us guys waiting to go built.
Old Oct 25, 2006 | 03:12 PM
  #63
Fishey's Avatar
Fishey
How much the stock block can handle depends a ton on cylinder temp. I am not extremely in depth on the VQ motor but I am just going to go out on a limb and say they use a iron sleve inside a aluminum bore? If so just like on other cars with this configuration you will have to be very mindful of the cylinder temps. You can get away with making alot of power over short periods but if you keep on it the heat will cause a aluminum/iron expansion rate mismatch and your bores will fail.
Like this!
How thick is the aluminum of your bore?
Old Oct 25, 2006 | 03:30 PM
  #64
thawk408's Avatar
thawk408
Like this!
I am sure there are waaaay more factors that go into the sleeves cracking like that.
