White Smoke?
Old Nov 15, 2006 | 06:00 AM
jeff0181's Avatar
jeff0181
Default White Smoke?
I was running my car hard the other day and my friend following me notcied I have white smoke coming out of my right exhaust. I have an APS TT kit with the APS 2.5'' exhaust and test pipes. We are both thinking it might be burning oil somewhere, however, my oil levels are all normal.
The other funny part is it is only coming out of my right exhaust pipe, whcih seems that if there is any problem it is along the right side turbo on back through the exhaust.
So the question is what possibilities do any of you F/I gurus have in mind that could help me out.
Old Nov 15, 2006 | 06:11 AM
redline350ZZ's Avatar
redline350ZZ
Read my fun
https://my350z.com/forum/forced-induction/229866-smoke-everywhere.html.
But since only your right side is smoking it's possibly a oil seal, and it doesnt take a lot of oil to make a decent amount of smoke, especially since our dipsticks suck at giving us a accurate reading. Can you smell anything odd when your car is at idle? There's some simple tests a shop can do to rule out a coolant leak.
Old Nov 15, 2006 | 08:20 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
does your exhaust cross over anywhere? or is the right exhaust the right bank of the motor and the left exhaust is the left bank of the motor?
White smoke= coolant (water vapor like smoke): headgasket? any milkshake appearance in the oil , pull the oil cap and look.
black/grey smoke = oil ---> if oil: rings, turbo seals, valve stem seals (unlikely)
under accel? decel? cruise? idle?
-TODD
Old Nov 15, 2006 | 08:36 AM
redline350ZZ
Todd you get my PM?
Old Nov 15, 2006 | 09:38 AM
jeff0181's Avatar
jeff0181
it is white smoke under hard acceleration. the exhasut does not cross over, so right bank = right exhaust. Not a lot of white smoke just a small amount.
Here is a link to a picture of it.
http://www.photoreflect.com/pr3/Orde...0710&po=711&c=
http://www.photoreflect.com/pr3/Orde...0836&po=837&c=
Old Nov 15, 2006 | 11:06 AM
gringott's Avatar
gringott
Yikes!
Old Nov 15, 2006 | 11:11 AM
SargentZ's Avatar
SargentZ
In General
White Smoke = burning oil or steam
Black Smoke = Gas(carbon)
Old Nov 15, 2006 | 12:36 PM
lemansz20's Avatar
lemansz20
I thought it was Blue smoke=oil, white smoke=water, and black smoke=fuel
Old Nov 15, 2006 | 12:46 PM
Eazzy's Avatar
Eazzy
It is ----Seems Jeff may --may have a little head gasket prob. Not the end of the world but keep tabs and run some tests. Put a pressure tester on ur radiator and see if u are getting a pressure rise when the engine is cold and running and watch it through operating Temp rise.
When I say --Not the end of the world, I mean that u mite have had a little head lift and time for Gaskets
Old Nov 15, 2006 | 02:53 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
what does the smoke smell like? That looked kindy bluish in the pic.
Old Nov 15, 2006 | 02:58 PM
jeff0181's Avatar
jeff0181
Dont know what it smells like, i couldnt get it to reoccur unless accelerating. When in neutral and revving the engine the white smoke did not occur.
I'm going to take it to my shop tommorrow and see what they can find.
Old Nov 16, 2006 | 05:39 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
Originally Posted by redline350ZZ
Todd you get my PM?
yes... will get back to you very soon ..
thx
TODD
Chris350z03
Oct 8, 2023 07:19 PM
kyin
Oct 15, 2015 05:54 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
