Severe belt slip on Vortech
Old Nov 20, 2006 | 08:28 AM
Alang's Avatar
Alang
Angry Severe belt slip on Vortech
I tried getting a final tune on my vortech on Friday, but had an unresolvable problem with belt slip above 5K RPM. The belt was tightened twice during the session. I am running the 3.12 pulley. I have not heard of this problem in an 8psi application. What could be wrong, and what are my options?
Old Nov 20, 2006 | 10:43 AM
jpc350z's Avatar
jpc350z
Have you tightened the gilmer belt. It drives the blower directly...
Old Nov 20, 2006 | 11:26 AM
OldManZ350's Avatar
OldManZ350
https://my350z.com/forum/forced-induction/94422-vortech-belt-slip-noise-solution.html
READ THIS THREAD... WORKS GREAT...... PICTURE
THIS IS THE BEST ADVISE I CAN GIVE YOU
Old Nov 20, 2006 | 03:15 PM
RA11325's Avatar
RA11325
Originally Posted by TIMROD1011
https://my350z.com/forum/showthread.php?t=94422
What he said.
Old Nov 21, 2006 | 07:10 PM
booger's Avatar
booger
You shouldnt have ANY PROBLEMS if you tighten it enough . It has to be much tighter than you think
Old Nov 22, 2006 | 09:45 AM
RA11325's Avatar
RA11325
Wish you guys would all just cave and do the TIMROD belt mod, it fixed everything for me.
Old Nov 22, 2006 | 10:11 AM
OldManZ350's Avatar
OldManZ350
Hay Vash350,
did you go for the 3.12 or 2.87 pulley?
Hows your A/R now?
Glad to see someone that someone has some "*****" and tried my belt/pulley redsign.
Old Nov 22, 2006 | 11:26 AM
RA11325's Avatar
RA11325
Hay Vash350,
Hows your A/R now?
Im actually still running the junky 3.33, but i could not get my belt to stop slipping regardless of how tight my belt was. I havent had an issue since i switched to your setup. My A/F's are a little better, but I just ordered a spacer so i am gonna wait until i get that on before i get it perfect.
Old Dec 10, 2006 | 04:02 PM
Alang's Avatar
Alang
Well, my belt was slipping even worse, so I tried to tighten it today. The tensioner was maxed! It wouldn't go any tighter. Could the installers have put on the belt for the stock pully instead of the one for the 3.12? Or is the stock belt so much bigger that it wouldn't work at all if someone tried to use it on the 3.12 pully?
Alan (hoping a simple belt change will solve this problem and I can finally boost!)
Old Dec 10, 2006 | 04:14 PM
OldManZ350's Avatar
OldManZ350
The problem with the stock setup is that the belt has to be extra long just to get it over the pulleys. By the time you take up the slack in the belt and adjust it a few times, theres no more adjustment left and you can't use a shorter belt, because you can't get it over the pulleys. Its a bad design, Do the Fix.............
Old Dec 10, 2006 | 04:27 PM
Triji's Avatar
Triji
Timrod.... Are you running that 2.87 w/ 12 PSI on your stock internals?
Old Dec 10, 2006 | 04:36 PM
OldManZ350's Avatar
OldManZ350
Yes 12psi+ over 30,000 miles no problems
Old Dec 10, 2006 | 06:33 PM
Alang's Avatar
Alang
I plan to, but I need to find a machine shop for the idler pulley mod. Around X-mas, its hard to locate someone (I'm just too busy).
Old Dec 10, 2006 | 06:44 PM
Eazzy's Avatar
Eazzy
+1 ---Make sure u got a good belt like a Gator. That belt has to be as taut as a guitar string so there is almost no deflection up top on the long run.
Old Dec 10, 2006 | 07:13 PM
kevinapex's Avatar
kevinapex
I did the "Timrod fix" thanks for the info Tim, no test time yet but I will post.
Old Dec 13, 2006 | 04:23 AM
DMK's Avatar
DMK
I'm sure you could try a .5" smaller belt. Don't see why it wouldn't work. When my belt is untightened all the way, there is more than .5" of play left.\
Btw, when you are tightening the bolt, you loosen the tensioner pulley before, right? If not, you need to.
Old Dec 13, 2006 | 09:44 AM
Alang's Avatar
Alang
LOL, yea I loosened the pulley bolt. I could loosen the belt tensioner, just couldn't tighten it any more. It was at max tightness. I have a new belt and just order the super grip pulley. Keeping my fingers crossed that this will solve the slip issues.
loudtoyz
Apr 6, 2023 04:52 AM
350Z_Al
Oct 29, 2020 07:44 PM
dcains
Nov 11, 2015 11:36 PM
Fixxxercask
Nov 9, 2015 11:10 AM
samansharif
Sep 25, 2015 12:31 PM
