Professional analysis and pictures of our 6MT internals
Old Dec 3, 2008 | 12:50 PM
  #141
thawk408's Avatar
thawk408
Originally Posted by SIR_pierre
nice..finaly some posetive respons. becuse ive been searching high and low for over two months.. so some examples?
Some examples are going to be completely custom one-off set. There are no aftermarket gear sets for the 350z.
Old Dec 3, 2008 | 12:51 PM
  #142
SIR_pierre's Avatar
SIR_pierre
ok....and where can i get that?
Old Dec 3, 2008 | 01:02 PM
  #143
thawk408's Avatar
thawk408
Try well known gear manufacturers, Liberty Gears is one. I dont think you relize the cost and time it would take to make a gear set. Your talking several several thousands of dollars, and even when its made you just wasted your money as the stock gears are strong. The gears are not the problem in these transmissions.
Old Dec 3, 2008 | 01:04 PM
  #144
SIR_pierre's Avatar
SIR_pierre
ok...so then i DO need to worry....i have checked everywhere i think. and i need a new one becuse my standard is broken. and an OLD and USED oem tranny cost over 3500 dollars here in sweden
Old Dec 3, 2008 | 01:05 PM
  #145
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Exactly, it's the synchro engagement gear that's braised onto the 3rd gear main. I've been looking into getting it electron beam welded so that it won't fail...but I've yet to find a place that's willing to do it. A custom one piece 3rd gear might be the only answer.
Old Dec 3, 2008 | 01:06 PM
  #146
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
What's broken on your trans? Probably cheaper to fix it than replace it.
Old Dec 3, 2008 | 01:09 PM
  #147
SIR_pierre's Avatar
SIR_pierre
3rd gear.. yes.. but replace it with? my thought was that if my standard gear wasnt good enough so why would a new but the same do?
Old Dec 3, 2008 | 01:30 PM
  #148
thawk408's Avatar
thawk408
So it wont engage into 3rd gear?
Old Dec 3, 2008 | 01:38 PM
  #149
SIR_pierre's Avatar
SIR_pierre
this happend i havent drove it hard for a long time and this happend on the freeway. and when i drove ot the freeway the problem started. first it felt like it wasnt really in gear.. and then i couldnt get it in att all. i doubble clutched. gave gas betwen etc etc.. and when i got it in 3rd gear and drove away the whole car jumped more or less.. and after that i didnt drive at all in 3rd gear
Old Dec 3, 2008 | 01:40 PM
  #150
thawk408's Avatar
thawk408
engrish FTW
Old Dec 3, 2008 | 01:44 PM
  #151
SIR_pierre's Avatar
SIR_pierre
engrish FTW
what? you cand understand my bad english?
Old Dec 3, 2008 | 04:00 PM
  #152
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Does the shift lever actually go into the 3rd gear position or not? If it does go into the third gear position does it act like a false neutral? When third gear "failed" did the car vibrate a ton for a split second??
Old Dec 3, 2008 | 05:07 PM
  #153
ttg35fort's Avatar
ttg35fort
Professional
PAR Engineering in Australia makes gear sets for our car. I beleive they are custom, and not cheap. About $4200 U.S., but they come with a straight cut syncho set.
PM me if you want contact information.
Old Dec 3, 2008 | 08:22 PM
  #154
SIR_pierre's Avatar
SIR_pierre
at first it was like that. but now it goes all in and doesent drive at all. so when in third gear it is like in neutral.
when i first noticed that is was braking it was like that... the whole car vibrated as Fck!
Old Dec 3, 2008 | 08:25 PM
  #155
SIR_pierre's Avatar
SIR_pierre
i found their homepage but couldnt really clear out what "kitt" is for my car.
Old Dec 3, 2008 | 08:56 PM
  #156
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Why isn't this thread a sticky yet???
Old Dec 3, 2008 | 09:17 PM
  #157
ttg35fort's Avatar
ttg35fort
Professional
You need to contact them. I'll PM you the telephone number and e-mail for my contact there. I believe that they custom make gear sets to order. Thus, there will be no "kitt" until you order it.
Old Dec 4, 2008 | 07:23 AM
  #158
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Definitely the same issue I have right now. Your third gear engagement ring separated itself from the main gear. The good news is the rest of your trans is fine. The bad news is unless you can buy just third gear from PAR, you're going to have a very expensive build on your hands if you want to make sure it won't break again.
PAR "should" offer the gears individually if asked....
Old Dec 4, 2008 | 07:24 AM
  #159
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
I've been trying to get this stickied for nearly 2 years...who knows...
Old Dec 4, 2008 | 09:59 AM
  #160
BlinkerFluid's Avatar
BlinkerFluid
Here is a pretty good video that talks about the differences between gear types, synchro and dog engagment, and the such.
This should be informative for those not familiar with this type of stuff.
PPG is the name of the company, and it doesn't look like they have an application for our cars at this point but who knows what the future may bring.
Here is a link to their website.
I have one of their straight cut dog boxes in my DSM, no clutch WOT shifts are interesting to say the least.
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/-fA94Sxiu4c&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/-fA94Sxiu4c&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
