Car Stalling at IDLE Greddy TT
Old Feb 22, 2007 | 10:00 AM
Kenk2's Avatar
Kenk2
Professional
Default Car Stalling at IDLE Greddy TT
Hey guys..
After the install of the TT, when I am driving, and put the car in Neutral, sometimes it stalls and most of the time it 'catches' itself and doesnt.. It always drops to very low RPM's, but I would say 25% of the time it dies.. Car has NOT been tuned yet but the map I am running as of right now isnt all that bad..
I will tune as much as I can but in the meantime, is there something else I can try to do to resolve this?
Thanks!
Old Feb 22, 2007 | 10:03 AM
rookie's Avatar
rookie
Try raising your idle? Any air leaks?
Old Feb 22, 2007 | 10:07 AM
Kenk2's Avatar
Kenk2
Professional
No I need to raise the idle.. I dont 'think' I have an air leak but am not sure.. What would the car do if I did and what kind of sound??
Old Feb 22, 2007 | 10:21 AM
jpc350z's Avatar
jpc350z
I had a similar problem right after S/C install but it eventually went away.. Possible need for the ECU to get use to the new air flow rate..?
Old Feb 22, 2007 | 01:13 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
on a stock engine, you should see about -10psi of vaccum. Could be something in the tune that is causing that...assuming you are running the 440cc injectors.
Old Feb 22, 2007 | 01:32 PM
QuadCam's Avatar
QuadCam
ken,
the easiest way to check for leaks is to get a 2-3' length of tubing larger than vacuum line preferably, but vacuum line will work in a pinch.
stick one in your ear, and probe around with the other end to listen for leaks.
It is also a great way to check to leaks in the exhaust too.
you'll look like an A-hole doing it, so make sure no one is watching.
Old Feb 22, 2007 | 01:35 PM
TheCajunStyle's Avatar
TheCajunStyle
I say you have a leak too...There have been times when I had an IC pipe partially disconnected and the car would sometimes stall, while other times it would catch itself.
You can also boost leak test as well, to be 100% sure.
Old Feb 22, 2007 | 05:03 PM
rookie's Avatar
rookie
What's the A/F at when idling ok, and where is it when it stalls out?
Old Feb 22, 2007 | 05:06 PM
Jay'Z's Avatar
Jay'Z
Originally Posted by Kenk2
Hey guys..
Thanks!
#1- Get a good tune
#2- Check for leaks
#3- You may need to take it to nissan to have them raise your idle, I had this problem too!
Old Feb 22, 2007 | 05:24 PM
Cannysage's Avatar
Cannysage
prolly your tuning.. what size injectors you got and what ems? I had an exhaust leak and it died at start up, a lot.
Old Feb 23, 2007 | 06:33 AM
Kenk2's Avatar
Kenk2
Professional
Thanks fellas for the input..
When I first installed the fuel return and started the vehicle, my fuel was at about 50 psi so I thought we were good.. I drive around for a day and all seemed fine until yesterday. I checked the fuel guage again and it was reading 40 psi, so I adjusted it back up to 50 or so and all is well.. No stalling now at all!
A/F @ idle is mid 14's.. Yea I need a tune as I am running rich right now just until I get to the dyno.. Thanks again all for the help!
pslamp32
Feb 8, 2017 09:07 AM
BEBO'S ZEE
Jun 7, 2016 07:48 AM
Mattg350z
Oct 2, 2015 06:51 AM
05UltraYellow
Sep 24, 2015 05:41 AM
Darkspy
Sep 7, 2015 09:09 PM
