Sound Performance 350z Twin Turbo kit update!
Old Jun 10, 2007 | 08:59 PM
  #121
Chris@SP's Avatar
Chris@SP
Sound Performance
Just buttoning up a few things, and we had a bunch of cars that had to get done last week.
I'm waiting on a couple of little odds and ends pieces that will be at the shop tomorrow! I have charlies dual billet fuel pump hanger ready to get dropped in tomorrow as well. I am pushing to get it on the dyno by Tuesday or Wed of this week
Numbers to come!
Chris
Old Jun 10, 2007 | 09:08 PM
  #122
leeboyNY's Avatar
leeboyNY
Kimchi Eater
Originally Posted by MIAPLAYA
Ever high center the car? I have an exhaust brace in a similar location (actually a bit higher then that on the drivers side) that has scrapped on speed bumps before. Not saying this kit isn't great as I think it is but there is definitely a risk of scraping that resevoir. Perhaps a splash/debris guard for it. LOL never thought I would be asking for a skid plate on a car...
I think you forgot that K-member frame covers up that oil reservoir. That k-member frame needs to be snapped in half in order to scrape the reservoir.. But if that k-member frame is snapped in half.. Engine would have sustained major damage or get T-boned in a huge accident.... so damaging the reservoir wouldn't be the first thing in owner's mind...
BTW, APS ST oil return system needs to be corrected just like that.. I sketched that setup on blank papers before I moved on the the TT setup...
I see that SP went with Mocal oil pump... I hope that's not as leaky prone as the APS's Weldon 9200 pump...
Old Jun 13, 2007 | 11:02 AM
  #123
mjedens's Avatar
mjedens
subscribing!
Old Jun 16, 2007 | 10:15 AM
  #124
centxdsm's Avatar
centxdsm
Numbers to come!
Chris
Get on it Chris!
Old Jun 16, 2007 | 11:07 AM
  #125
CodeRed30's Avatar
CodeRed30
This might seem like a stupid question, but in comparison to your 1000whp Supras, is the Z going to have a little more kick in the midrange or any less lag?
Old Jun 16, 2007 | 12:14 PM
  #126
Shabib67's Avatar
Shabib67
^It defintley should its .5l more displacement than a supra. Even .1l displacement more than the stroked supra engines which are 3.4l. Plus the 350z has way way better flowing heads than the supra.
Old Jul 3, 2007 | 07:01 PM
  #127
rrmedicx's Avatar
rrmedicx
Anything new fellas? I've been patiently waiting to get my kit...
Old Jul 3, 2007 | 10:01 PM
  #128
SoundPerformance's Avatar
SoundPerformance
Sound Performance
So far she made 529 RWHP. That is about as far as I want to push the stock bottom end. I am sure that we could make alot more on the dyno but what is the point?
We are pulling the motor back out next week and going to jig up the kit so that we can begin selling them. Then we can put in the good motr, heads, cams, and go for 4 figures
Old Jul 4, 2007 | 08:08 AM
  #129
rrmedicx's Avatar
rrmedicx
Any possible video clips of the dyno run? Is there any possibility of running any sort of independent cat-back exhaust? It doesn't seem that way? Your exhaust is 3" to the tail? Right
Old Jul 4, 2007 | 08:57 AM
  #130
eltness350's Avatar
eltness350
The Untouchable
what psi did u make the 529rwhp with?? good to hear the block handled it on the dyno...
Old Jul 4, 2007 | 09:08 AM
  #131
doug's Avatar
doug
13 PSI https://my350z.com/forum/forced-induction/282235-sp-tt-kit-puts-down-529rwhp-at-13psi-on-stock-motor.html
Old Mar 17, 2008 | 03:35 AM
  #132
BBS's Avatar
BBS
Originally Posted by SoundPerformance
The core we chose is the same core we use in our 1500+ HP supras. The core is rated to flow 1775 HP. We chose this primarily due to its size and HP capability. I thought long and hard about this... as a vertical flowing IC would certainly fit the piping layout better. However I could not find one that would equal the HP potential of this core. The Air intake temps that we see in our supra with this core are ridiculously low....... Amazingly it fits in the Z's nose quite well!!
Larry
SP
Lar you have been holding out. If i knew what you were doing i would have sold my Supra sooner What are your thoughts on two GT3076's or two 50 trims. Stock VQ heads flow more than 2JZ heads huh interesting Please post updates as soon as they are available.
Cheers,
gc350z03
Oct 28, 2016 05:00 PM
bcoffee20
Nov 19, 2015 06:39 PM
Mattg350z
Oct 2, 2015 06:51 AM
EnjukuRacing
Sep 11, 2015 08:34 AM
EnjukuRacing
Sep 11, 2015 08:30 AM
