New vortech dyno charts at GTM 477.8 whp 383 tq
Old Apr 26, 2007 | 01:41 PM
  #161
eltness350's Avatar
eltness350
The Untouchable
those r some good tires for sure...there r guys with waaaaaaaayyyy more hp and can hook in 2nd ...my buddies supra has almost 600rwhp and hook no prob on 295 drag radials.... go home booger
Old Apr 26, 2007 | 04:16 PM
  #162
booger's Avatar
booger
Originally Posted by 350zDCalb
Just to share my experience with traction issues with a turbo setup; at 400rwhp and very similar tq[8psi apprx], SAE corrected for 5000ft altitude (so even less actual hp and tq), I would easily spin my tires through 2nd gear, that was with 285/35/19's on 10.5 rims...
the tq onset on a supercharger is much less aggressive than a turbo setup, this may explain you ability to hook up in 2nd, but nevertheless, an intersting comparison in driveability- turbo vs supercharger
-TODD
Just to share my experience with a 420whp 348trq. SC and 3.5 rear gears and a AT5 . 2nd gear is [was ] useless . More than 1/3 throttle and the tires light up . Even with his old numbers [ 430whp - 370trq. ] and his 3.9 rear gears . 2nd gear should be far worse to gain traction than I had . I dont care what tire combo , camber , or any other mod it has set up for traction . That power level and 3.9 in 2nd gear isnt going to hold at 1/3 throttle or more .
Now ...with slicks and a track with plenty of VHT down . He may gain traction sooner . But he doesnt run slick nor drag radials .
This is just MPO of course . LOL
Old Apr 26, 2007 | 04:19 PM
  #163
booger's Avatar
booger
350zDCalb..has had simular experience...so you gonna tell him to go home to ????
Old Apr 26, 2007 | 04:25 PM
  #164
booger's Avatar
booger
Originally Posted by Devil Z
Sentry, how about getting an independent Dyno where you live to verify your average power levels? I mean Booger clearly doubts. Just saying . . .
Im sure his car is making plenty of power . Ive never said it didnt . How much is in question if at WOT with 3.9 gears in 2nd it doesnt light up the tires .
Old Apr 26, 2007 | 04:41 PM
  #165
sentry65's Avatar
sentry65
the burninator
yeah VRT used to race with pirelli corsas along with the other brands they've used. They're the ones who recommended these tires to me because they don't need much heat to make them sticky. Also even though they have a treadwear of 60, they said they wouldn't be suprised if they lasted 8000 miles with normal driving on the street.
They're not too bad even though mine are like 2 years old and kinda pissed me off that I didn't read the dates on the tires until I already mounted them. I just assumed since they were competition tires that they'd be fairly new and not sitting on a shelf forever before being sold. Tire rack gave me a whole $100 back though.
They were a nice step up in grip coming from PS2's in the same size (295/35/18) and was immediately felt driving on them for the first time, but they've gotten too expensive and some of the sizes have been discontinued so next time I'll have to switch to something else.
Old Apr 26, 2007 | 04:52 PM
  #166
booger's Avatar
booger
Track tires are just like drag radials and slicks . They need to be heated up quite a bit to get sticky .That means , doing a couple laps at high speed around corners and or doing a good burn out . Sentry mentions nothing about doing a burn out before he tried his WOT 2nd gear run and getting traction .
And Sentry...I know you dont have me on ignore..you couldnt handle not reading what I post about you .
Old Apr 27, 2007 | 12:37 AM
  #167
sentry65's Avatar
sentry65
the burninator
Default video
I have a new video up. It's not that great, but it's all I have right now. Just a couple 2nd gear pulls from 19mph at 2200rpms to redline and then from about 26mph at 3000 rpms to redline. You can really see the rpms speed up because of the vortech building boost. 2nd gear goes up to around 55-56mph at 6600rpm with the 6MT with 3.9 FD and 295/35/18 tires which are smaller diameter than stock. This was on my 455whp map with a half tank of gas and nothing in the rear hatch area other than my battery -and no spare tire. It was about 80 degrees outside
video:
http://www.youtube.com/watch?v=wPl_QWJywL4
you can plainly see in the first run that the rpms go smoothly all the way to redline. If the tires lost traction you'd not only see it on the tachometer by the rpms suddenly shooting up, but you'd also hear the tires chirping or studdering (windows were down). The 2nd take really turned out crappy and was hard to steady the camera. I was thinking of not including it at all, but you can at least listen to what's going on and there's no studdering or tire chirping. I was trying to show the transmission was in 2nd gear when I moved the camera, but you couldn't make it out at night
next time I'll have my wife (who doesn't weigh much) video the run with my 477whp race gas map and I'll do a 1st, 2nd, 3rd gear pull where I can actually shift faster and not have to steady a camera
Old Apr 27, 2007 | 04:42 AM
  #168
booger's Avatar
booger
Wow..you can see the rpm's go right up with the 3.9 rear , but only gain like 20mph . Hard to believe you dont have enough power to bust loose them tires in 2nd gear and 3.9 rear end...bummer dude !
Old Apr 29, 2007 | 10:03 PM
  #169
sentry65's Avatar
sentry65
the burninator
edit:
yeah going 25-54mph in 1.8 seconds all in 2nd gear 3000-6600 rpms while being out of the powerband/high boost for the first half of the pull...guess that's pretty slow
/edit
last night my car started making this exact sound that BeerViper had with the bad jackshaft bearings
http://videos.streetfire.net/search/...bcfd728006.htm
it's the exact same sound, though not nearly as loud. And it doesn't seem to get louder as I rev higher unlike some other videos I've seen of members with the same problem, but I'm going to be careful just the same
At first I also thought it was coming from the top most grooved idler pulley, but after reading his threads, I probably have to mess with the jackshaft bearings...great
I also need to get a chip in my windshield fixed and a battery cut off switch for my battery since it was relocated in order to run the 1/4 mile and pass tech inspection
Old Apr 29, 2007 | 11:37 PM
  #170
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Damn man, that sounds terrible. Hope it's a quick and easy fix.
Old Apr 30, 2007 | 06:35 AM
  #171
THE TECH's Avatar
THE TECH
From that vid, that's different noise than when I had the problem with my jackshaft. It's not the most difficult of fixes, just a bit time consuming and delicate. Vortech was all zero help in getting the parts ordered.
Old Apr 30, 2007 | 07:40 AM
  #172
sentry65's Avatar
sentry65
the burninator
that video isn't my car, that's BeerViper's. My car sounds kinda like that only not anywhere near as loud. It also doesn't seem to get noisier as the revs go up
Old Apr 30, 2007 | 07:56 AM
  #173
sicdeusvult's Avatar
sicdeusvult
would you recommend the HKS hi power dual exhaust for a vortech?
Old Apr 30, 2007 | 08:13 AM
  #174
sentry65's Avatar
sentry65
the burninator
here's a quick video of what my car is sounding like. Has about 5000 miles with the vortech on it. Car itself has around 25k miles
http://www.youtube.com/watch?v=mmCHrEAb7pA
sure
a bunch of people have had good results with it
Old Apr 30, 2007 | 09:18 AM
  #175
jpc350z's Avatar
jpc350z
He removed the cog belt which might make your's sound a little louder if you removed your's..
Old May 8, 2007 | 10:16 AM
  #176
sentry65's Avatar
sentry65
the burninator
just an update since some people were expecting a dyno etc by now
I just got the vortech bearings in the mail yesterday. On workdays I need my wife to drive along with me to Dynocomp in a seperate car to drop my Z off but she's really sick right now - almost 102 degree fever
I found out that in order to run on any of the drag strips around here that I need a battery cut off switch installed since I relocated my battery to the rear. They say the switch must be visible from the rear of the car without having to get down on the ground and clearly labeled ON and OFF. My first thought is that it needs to go under the car in the rear, but with the APS muffler (see picture), I don't know how I can really mount it yet.
The guy at Firebird Raceway said some people have it mounted on a hinge that they flip down when they race. Not sure how I'd set that up. There might be room to the side of the exhaust somehow though. I really don't want some big ugly switch hanging out the back of my car that can turn my power off. Some switches are lockable though. I'm kinda irritated about the whole thing. I also need to fill a crack in my windshield to run on the track
Anyway, some other things I'm looking into having done at Dynocomp are removing my front reflectors and using the holes as air vents. I'll see if I can get my power steering cooler relocated to the driver side next to the reflector hole. right now it's above the intercooler next to my intake. The passenger reflector hole will let some heat from the oil cooler escape as well as let me physically be able to see how full my water/meth is in the water tank
I'm also putting in the ARC undertray, my racing seat, and I need to find an optima battery because I'm just not getting enough voltage out of my small Hawker battery
I'll start a new thread when everything is finished and I get a new comparison dyno at Dynocomp...
Attached Thumbnails New vortech dyno charts at GTM 477.8 whp 383 tq-img_0523.jpg
Old May 8, 2007 | 02:34 PM
  #177
Barzten1's Avatar
Barzten1
Goodluck man
Old May 8, 2007 | 02:51 PM
  #178
350Z_LEE's Avatar
350Z_LEE
Nice numbers! That is one smoothe curve!
Old May 8, 2007 | 04:25 PM
  #179
sentry65's Avatar
sentry65
the burninator
thanks guys
here's a couple more pics - car was wet about to get washed
Attached Thumbnails New vortech dyno charts at GTM 477.8 whp 383 tq-img_0526.jpg   New vortech dyno charts at GTM 477.8 whp 383 tq-img_0527.jpg
Old May 9, 2007 | 05:32 AM
  #180
THE TECH's Avatar
THE TECH
What bearings did you decide to replace?
