vortech FAQ: read this before asking vortech questions
Old Sep 27, 2009 | 08:40 AM
  #561
binder's Avatar
binder
Originally Posted by Mr_pharmD
Hey Chef, how much of the screw on your BPV is showing? Do u have it more out or more in? Mine is around the middle but I'm wondering if I need to change it especially if I'm seeing 17psi. What direction should I be turning? hehe
6-7 threads showing is the middle point.
turning it in makes the valve close SOONER.
turning it out makes the valve close LATER.
how that relates to producing more boost i'm not sure. I just left it alone.
Old Sep 28, 2009 | 05:46 AM
  #562
Mr_pharmD's Avatar
Mr_pharmD
not turning to make boost but to release it so I dont get too much surge.
Old Sep 28, 2009 | 06:13 AM
  #563
str8dum1's Avatar
str8dum1
you need to touch the BPV. Its based on vacuum, so how much you boost has no bearing on its function.
Old Sep 28, 2009 | 06:43 AM
  #564
Chef-J's Avatar
Chef-J
Booooosstt!!
Mr_pharmd,
Still runing racing bpv? Or did you upgrade it? I think I did set mine at 8 threads.
Old Sep 28, 2009 | 07:42 AM
  #565
binder's Avatar
binder
Pharm, it sounds like you need to add a blowoff valve in your intake piping for surge protection. That will set you up to a certain PSI that it won't go over. If you are worried about surging past 17psi then set the blowoff valve to 17psi. You will leave the bypass valve in place so it does the normal function.
You shouldn't be getting too much surge with a supercharger setup since it's tied directly to crank speed.
Old Sep 28, 2009 | 10:30 AM
  #566
Chef-J's Avatar
Chef-J
Booooosstt!!
Why needs to add a blow off valve, when there is good BPV for high psi/power.
Old Sep 28, 2009 | 10:33 AM
  #567
binder's Avatar
binder
the BPV closes under load and stays that way until you're off the throttle. It doesn't open back up when reaching a certain PSI like a blow off valve. A blow off valve is a pressure relief valve that stays closed until a certain PSI then it opens up to release excess pressure.
so if he wants to stay WOT and keep it from blowing past 17psi then he needs a blow off valve or a wastegate that opens at 17psi.
Old Sep 28, 2009 | 03:26 PM
  #568
str8dum1's Avatar
str8dum1
you are talking about a wastegate, not a BOV. BOV work off vacuum as well and do not care how much boost there is.
But why would you need that? He is consciously making the decision to run 17+psi with his pulley choice.
Old Sep 28, 2009 | 04:21 PM
  #569
Chef-J's Avatar
Chef-J
Booooosstt!!
First off. You don't need to explain about BOV/BPV. i'm sure everyone has enough basic education.
And i know some mustang guys runs BPV and wastegate on vortech setup. But...BPV and BOV? I'm kinda confused on this.
Old Sep 28, 2009 | 05:41 PM
  #570
binder's Avatar
binder
i think wastegate was what i was thinking about and didn't realize it in my first post.
Old Sep 28, 2009 | 07:00 PM
  #571
str8dum1's Avatar
str8dum1
http://www.musclemustangfastfords.co.../photo_19.html
they are using the standard BPV at 19psi at 800+ hp. Could you imagine 500+ ft-lbs at 3500 rpms with a supercharger..
Old Sep 29, 2009 | 07:58 AM
  #572
binder's Avatar
binder
http://www.musclemustangfastfords.co.../photo_08.html
that photo shows and explains they use a TIAL wastegate along with the vortech BPV to keep the boost at a safe pressure.
Old Sep 29, 2009 | 12:59 PM
  #573
str8dum1's Avatar
str8dum1
there are a lof of threads saying that power takes a **** after you hit the wastegate pressure. You are still heating the air but just not using it. Thats pretty stupid. Just buy the right pulley.
Old Oct 4, 2009 | 12:33 PM
  #574
gennosuke1's Avatar
gennosuke1
^^Barfs at mustangs.. trash
anyways anyone here been using the vortech as a daily on nonbuilt motor? How long ahve you guys been running?
Old Oct 4, 2009 | 12:40 PM
  #575
binder's Avatar
binder
6 months. 75k on the motor, about 5k boosted. 2.87 pulley running 12psi stock block.
Old Oct 4, 2009 | 12:53 PM
  #576
OldManZ350's Avatar
OldManZ350
12-13LBS Boost, 47,000 on Stock Motor, 42,000 on Vortech, 6-1/2 Years......
Old Oct 6, 2009 | 12:33 AM
  #577
gennosuke1's Avatar
gennosuke1
Wow that makes me feel a lot better after hearing all the stories of motors blowing and having 10-15k on me
any revups?
Old Oct 6, 2009 | 07:24 AM
  #578
binder's Avatar
binder
any revups?
just set it up with a safe tune and dont be stupid with it. The car should last.
Old Oct 6, 2009 | 08:33 AM
  #579
350z006's Avatar
350z006
I have a revup...I've run with the 2.87 pulley on my stock block for more than a year ~20k miles, no problems engine wise; I even tracked it a few times...I have upgraded my blower, so I don't know how much longer it'll last...
But if you're happy with ~380 whp then stick with the stock 3.12 pulley on the revup and be super safe...
Let me add a disclaimer: each engine is probably a little different, so I couldn't guarantee a safe setup with any FI...I've had good luck with my engine, non-oil burning from the start and still running strong...
any revups?
Old Oct 6, 2009 | 08:05 PM
  #580
alltel350z's Avatar
alltel350z
Find a long road. Put in third gear in low speed/rpms, and floor it all the way. Let us know.
I tighten the belt about one full to one and a half turn. The belt squealed during cold startbut only for about 30 second. It did not squeal when I left work tonight but only saw 4psi for a second. Afraid to get it to tight
