vortech FAQ: read this before asking vortech questions
Old Feb 4, 2010 | 04:58 PM
  #801
whitez33350ztt's Avatar
whitez33350ztt
dan@aussaltech mentioned putting a new filter.. where do i get that also..?
Old Feb 4, 2010 | 05:14 PM
  #802
- bigc -'s Avatar
- bigc -
from courtesyparts.com:
link
you can get it at infinitpartsusa.com too.
Old Feb 4, 2010 | 05:19 PM
  #803
whitez33350ztt
i know about o-ring... i need to know about the filter i need. where that can be found and wat its called
Old Feb 4, 2010 | 05:59 PM
  #804
binder's Avatar
binder
Originally Posted by whitez33350ztt
yea so i go to napa and say i need a bosch o-ring? wat do i exactly say when i go to napa bc i wouldnt know how to describe it
year, make, model, fuel pump o-ring. it's the large oring that seals the fuel pump to the tank.
next weekend i'm heading home to indiana so if i remember i'll get the part number off my box.
idk about the filter. the only thing i can think of is the "sock" on the basket. It's not really a filter since it's very porous. I never changed mine.
Old Feb 4, 2010 | 07:04 PM
  #805
- bigc -'s Avatar
- bigc -
the part number for the o-ring is in the link i posted. as for the sock, you don't need to change it. like everything else on the basket, just be careful not to break it.
Old Feb 5, 2010 | 05:51 AM
  #806
Dan@Assaultech's Avatar
Dan@Assaultech
As he said, you dont need to change the sock/filter.
http://cj-motorsports.com/342install.htm
Good luck
Old Feb 5, 2010 | 07:04 AM
  #807
whitez33350ztt
i just took the easy way out and orddered the sp racing install kit .... that was 15 bucks and its everything i need. so i guess there is an install kit bc i just ordered 1..
Old Feb 6, 2010 | 06:34 PM
  #808
binder's Avatar
binder
That's not a bad deal then. I think the o-ring from napa was around 12 or 14$ so your 15$ plus shipping for a kit with other stuff in it is pretty decent. what other stuff comes in that kit?
Old Feb 6, 2010 | 08:12 PM
  #809
str8dum1's Avatar
str8dum1
i've always reused that o-ring. just coat with vasoline and it will stick right back into place.
Old Feb 7, 2010 | 01:05 PM
  #810
binder's Avatar
binder
I would have. Mine expanded like a beast when I took it out. It was like 10" in diameter when i got done with it. lol.
I'm heading home next weekend to put my RFS in so hopefully the bosch oring i have in now doesn't go crazy on me and i can reuse it.
I never understood how they can make orings that sit down in gasoline and not have a problem yet that oring can't handle gasoline. You would think they would make that oring out of gasoline resistant material.
Old Feb 9, 2010 | 05:22 AM
  #811
catcapt's Avatar
catcapt
Default oil drain line
Thanx for all the help here and given personnally on this install. I have a concern about my oil drain line. it ends at my oversized oil pan with an adapter that shrinks from 3/8 to 14 inch and want to know if this is a potential problem with the gravity drain. Thanx
Old Feb 9, 2010 | 06:18 AM
  #812
str8dum1's Avatar
str8dum1
1/4 internal diameter? Thats pretty small.
what return are you using? Oil pan spacers have -8an ports on them which is 1/2".
If you are returning above the oil line, then it might be ok, but if its returning below the oil line, i wouldnt do it.
Old Feb 9, 2010 | 05:29 PM
  #813
whitez33350ztt
the 0 ring and the thing that clicks in the fuel pump i guess its caled the fuse... and some new clamps
Old Feb 11, 2010 | 01:55 PM
  #814
binder's Avatar
binder
same question that rich asked, is that 1/4" NPT or 1/4" internal diameter. there is a difference.
1/4" internal diameter is pretty small. I would probably drill it out and use at least 3/8" NPT for the drain.
Old Feb 23, 2010 | 02:28 AM
  #815
Synjn's Avatar
Synjn
Gentlemen I have a question regarding my next upgrade. What would you recommend? I want to make more power of course, but I want to do it safely. Very safely. I was considering a water/meth kit OR maybe some nismo headers. But, after reading as much as I have I am now considering maybe a UTEC and a return fuel system may be the better investment. The safer route. Was also considering the T-Trim blower. Saw one go on ebay the other day for 700$ Any advice would be great. Thankx in advance
My current mods are as follows:
Vortech Supercharger 10-12 psi (2.87 pulley)
GTM Stage 1 longblock (rated to 600hp, low compression pistons)
GTM Stage 1 cam
GTM Stage 1 heads
550cc injectors
Walbro fuel pump
Motordyne plenum spacer
GTM spec ECU flash
Stock exhaust manifold
Stillen high flow cats
Stillen dual exhaust
Stillen lightweight aluminum flywheel
ACT heavy duty PP & 6 puck disc
No
Old Feb 23, 2010 | 02:53 AM
  #816
CeBrwn5454's Avatar
CeBrwn5454
If you've got a built motor...which you do, I vote t-trim and meth....which would be nicely complimented by a stand-alone and a RFS.
Old Feb 23, 2010 | 06:02 AM
  #817
nurrishd's Avatar
nurrishd
Still waiting to get mine on the dyno and tuned!!
My utec is playing up with my uprev tuned ecu....so i am going to let the uprev take control of everything and ditch the utec....
Old Feb 23, 2010 | 06:46 AM
  #818
str8dum1's Avatar
str8dum1
good to hear its moving forward. too bad you couldnt get the utec dialed in. For a supercharger, a good UPrev tune should be fine. You'll need that HPX MAF sensor though. I was maxing out my stock MAF sensor at 4500 rpms with that setup.
Old Feb 23, 2010 | 06:55 AM
  #819
nurrishd's Avatar
nurrishd
Luckily the tuner i am going to stocks them ...but he reckons i wont max out....but if i do then it wont be an issue with just dropping it in.
At the moment i have it running on a map off turboxs and i can really feel the power....just dont want to push it hard until its tuned up...
My main reason to go with uprev is so i can let it control everything and not have to worry about cell lights putting the car into high det....with the uprev the cells can be turned off......and at the moment i have cells on which i feel if i were to tune it now on the utec i will have a constant battle against cell lights
Old Feb 23, 2010 | 06:40 PM
  #820
binder's Avatar
binder
well, honestly meth will lower intake temps and increase octane but that doesn't really mean it will make the car "safer". It also wo'nt increase the power unless you take advantage of that octane by increasing the timing and adjusting the tune further.
i would be careful of 700$ t-trim blowers. They are 3200$ from vortech for a reason. 700$ used ones will probably be in bad shape. They are also probably from a mustang which depending on the year could be the incorrect blower. I think the early 90's and the 05 and newer are the same but the other years have something different about them.
headers would be a nice addition due to the decrease in exhaust bottleneck. FI loves more flow in any direction. Be prepared for a hell of a time though. Headers are so far the worst thing i've had to install on my car. I would pull the engine again before changing out my headers, lol.
