vortech FAQ: read this before asking vortech questions
Old Mar 15, 2010 | 08:28 AM
  #901
05Z33's Avatar
05Z33
Originally Posted by Synjn
Is this the stock air filter that comes with the kit? These are the only lines i could see. I don't see any one going directly to the air filter. Don't understand why an air filter would need an oil line either.
Could you help me out and identify these lines for me.
Thankx in advance
No that's an aftermarket CAI setup. You are half way there. Remove the hose going into that pipe and put a crank case filter on it. You are going to have to plug the hole on the intake pipe or just replace the pipe. It should be easy to do. I removed the hose on my car all together and put the crank case filter on the back of the driver side valve cover.
Old Mar 15, 2010 | 08:43 AM
  #902
Synjn's Avatar
Synjn
This is the oil line you were refering to? The one that goes to the airfilter? Ok, intake tube. Same thing...
And What is it for? *shrug* Why would I want my crankcase breather going into my SC intake? Makes no sense to me
Also: What are those other 2 lines going under the blower on that pic I posted?
Old Mar 15, 2010 | 08:53 AM
  #903
05Z33's Avatar
05Z33
These are your A/C lines.
Old Mar 15, 2010 | 08:59 AM
  #904
Synjn's Avatar
Synjn
Thanks for the help. I'll pull that line out and cap the valve cover with a crankcase breather/filter. But I got to know what is it there for in the first place? What did vortech have in mind?
Old Mar 15, 2010 | 09:01 AM
  #905
05Z33's Avatar
05Z33
That hose used to be hooked up to the stock intake pipe. It's to relieve crank case pressure. You don't need it hooked up to your intake pipe now that you have a supercharger. They just had to give you spot for it since it was there from the factory. You do need to put a filter on the end of the hose or the valve cover to relieve the cranck case pressure and not suck in any dirt.
Old Mar 15, 2010 | 09:21 AM
  #906
Synjn's Avatar
Synjn
Any suggestions on how to clean out my intercooler of oil? Stoopid! Prev owner should of handled this long time ago (recently bought the car.)
question: On the other side I have a greddy oil catch can. Can't I do the same thing there? Just put a crankcase filter/breather on the passenger side valve cover as well, plug the vacume hose on the intake manifold and lose the oil catch can all together? Again, what's the mechanical purpose of breathing crankcase pressure back into the intake?
Seems pointless and troublesome. OR is it giving me boost? LOL : )
Old Mar 15, 2010 | 09:52 AM
  #907
str8dum1's Avatar
str8dum1
pour gas inside, shake, pour and repeat.
as for your question, all that is for emissions. You can plumb it however you like
Old Mar 16, 2010 | 03:31 PM
  #908
binder's Avatar
binder
wait, why did you have to remove intercooler piping to tighten your belts?
belts are tightened with 2 tools: 12mm socket and 14mm wrench.
loosen the pulley nut with teh 14mm then go under and tighten the adjuster with the 12mm socket. doesn't require removing any piping.
Old Mar 16, 2010 | 04:05 PM
  #909
- bigc -'s Avatar
- bigc -
what? i usually have to pull the blower in order to change my belts
Old Mar 16, 2010 | 04:10 PM
  #910
binder's Avatar
binder
tighten belts
i've changed them without removing anything also. you must have the special edition
Old Mar 16, 2010 | 04:21 PM
  #911
- bigc -'s Avatar
- bigc -
ugh, don't get me started on tightening the belts. i had to pull the blower AND bracket to do that
Old Mar 16, 2010 | 06:05 PM
  #912
CeBrwn5454's Avatar
CeBrwn5454
^^ wat?!!?
Old Mar 16, 2010 | 06:09 PM
  #913
- bigc -'s Avatar
- bigc -
Old Mar 16, 2010 | 06:29 PM
  #914
str8dum1's Avatar
str8dum1
ya hopefully the past few posts were all in jest.
Old Mar 16, 2010 | 09:40 PM
  #915
maXmood's Avatar
maXmood
Under Boost!
Question... for the v2, i was considering buying an oil pan spacer with return oil lines holes for the vortech.
should i do that? or save the money and just tap the oil pan (traditional way)?
Old Mar 17, 2010 | 12:07 AM
  #916
Synjn's Avatar
Synjn
I couldn't get my 14mm completely around the nut for the AC pulley. Started to strip. Pulled the tubing and used a socket instead. Glad I did, which alerted me to the oil blow by problem that i'm fixing.
Old Mar 17, 2010 | 05:59 AM
  #917
350Z400rwhp's Avatar
350Z400rwhp
Returning to an oil pan spacer works fine.
Old Mar 17, 2010 | 07:15 AM
  #918
Vas_Z33's Avatar
Vas_Z33
Why the hell r people removing the bracket and blower to change belts??? I chNged mine plenty of times... It's the easiest... Is there a new vortech setup I'm missing???
Old Mar 17, 2010 | 08:49 AM
  #919
binder's Avatar
binder
it's a nut on the tensioner pulley. If you removed the a/c pulley you're in for a treat later. and coming down from teh top of the car a 3/8" drive rachet with a 14mm socket on it fits in there perfectly fine. Just have to come in from the top and give it about a 1/4 turn to lossen it slightly.
between me and bigc it was a joke.
MAX: pan spacer will be fine if you do'nt want to drill. I had my stock block drilled and then this built block i use a tapped greddy pan (which will work the same as a spacer for return). Either will work fine.
Old Mar 17, 2010 | 09:35 AM
  #920
- bigc -'s Avatar
- bigc -
i have to be more careful about joking around in a thread like this
