turbonetics wastegate?
Old Jun 9, 2007 | 09:52 AM
bbs350z's Avatar
bbs350z
Default turbonetics wastegate?
does turbonetics make a higher psi wastegate spring? this is an alternative to an electronic boost controller (aem) i dont want to worry about boost spikes and such, and a couple of my buddies just run higher wastegate springs in there cars
Old Jun 9, 2007 | 09:54 AM
diwun67's Avatar
diwun67
First of all what are you trying to accomplish?
Old Jun 9, 2007 | 09:55 AM
taurran's Avatar
taurran
+1
I know they make lower, I'd assume they make higher. Most use a boost controller to raise the boost.
Old Jun 9, 2007 | 10:11 AM
JETPILOT's Avatar
JETPILOT
You don't need a new spring. You're solution is a manual boost controller. I'm selling mine if your interested. They hold boost rock solid.
https://my350z.com/forum/showthread....ost+controller
JET
Old Jun 9, 2007 | 10:16 AM
MIAPLAYA's Avatar
MIAPLAYA
Depending on what spring you currently have in the gate they might not make one higher. You can add shims to increase the spring pressure of the wastegate but above 10-11 PSI you might as well get a boost controller. Turbonetics does make several MBC kits you could use:
http://www.turboneticsownersclub.com...opic.php?t=506
Old Jun 9, 2007 | 09:08 PM
bbs350z's Avatar
bbs350z
well the only issue that im seeing with an EBC is that maybe the solenoids arent strong/large enough to prevent a boost spike. im hoping to run 10psi (safely) before i throw the water/meth inj. kit on there for added safety. but for those of you with experence please state why or why not you choose the ebc over the mbc or vice versa (with price not being an option)
Old Jun 10, 2007 | 06:33 AM
diwun67's Avatar
diwun67
From what I've seen, mbc's are a bit more reliable.
Old Jun 10, 2007 | 09:16 AM
taurran's Avatar
taurran
I don't think they're "more reliable" as much as they are "tamper proof". People get themselves into trouble much easier when they have the abilty to dial in and tweak boost/gain settings on the fly.
Old Jun 10, 2007 | 10:45 AM
Ed 718's Avatar
Ed 718
BRAVEHEART
Depending on the wastegate you have the highest is the 9psi spring. You can add shims like posted above and 2 shims equals one psi but anything above that need to be adjusted via a boost controller. be careful however on the boost level you throw at it on a stock block or you will cause damage to the engine.
Old Nov 19, 2008 | 05:27 PM
tylerxfire's Avatar
tylerxfire
what is the stock wastegate spring in the turbonetics wastegate and how much psi does it make?
Old Nov 23, 2008 | 09:48 AM
bbs350z's Avatar
bbs350z
damn this thread is old. tt now lol. i beleive its around 6-7 psi?
Old Nov 23, 2008 | 09:59 AM
tylerxfire's Avatar
tylerxfire
yeah thanks for the reply i already got it but heard more like 7-8 so idk guess well see.
Old Nov 23, 2008 | 10:14 AM
diwun67's Avatar
diwun67
stock w/g spring is 9 lbs
m3powerrr
Jul 19, 2004 02:55 PM
ACP
Jul 10, 2004 04:02 AM
thadon
Jun 11, 2004 03:39 PM
