Turbonetics and Power Steering Alert !!!
Old Jul 31, 2007 | 11:45 AM
nosurf2day's Avatar
nosurf2day
Exclamation Turbonetics and Power Steering Alert !!!
For those that are doing an install yourself, when you put the piping in make sure you check all piping and anything around it. You would think this is a no brainer but I found out the hard way.
Your aluminum power steering lines that run into the power steering rack are directly next to the piping. My lower power steering line was sitting on the piping from below and my TN piping melted it until a pinhole was created and all my power steering fluid sprayed all over my heat wrap. Smoke went everywhere.
Old Jul 31, 2007 | 12:04 PM
MIAPLAYA's Avatar
MIAPLAYA
This has happened to one other person and likewise the piping was not aligned correctly and it caused a rupture. Also a common thing for Greddy kits.
Old Jul 31, 2007 | 12:31 PM
IIQuickSilverII's Avatar
IIQuickSilverII
yeah... even when properly aligned its kinda tight fit so when i had mine i heat wrapped.....
Its a quick fix though... other than getting the line the rest is "cake"
Old Jul 31, 2007 | 12:48 PM
nosurf2day's Avatar
nosurf2day
I just bought a new line and the took a pry bar and moved the line about an inch from the turbo piping for both lines.
Old Jul 31, 2007 | 01:55 PM
taurran's Avatar
taurran
Stuff like this happens with aftermarket turbo installs. Like MIA said, it's common with more than one Z kit. That's the nature of installs on an engine. It's why you double check everything before you put the car on the road.
Glad you got it fixed though.
Old Jul 31, 2007 | 11:40 PM
TayTaythatsme04's Avatar
TayTaythatsme04
haha that funny because thats what happen to me. The hot side piping burned through the PS line and the fuild caught on fire . . . yes that was a fun day. Be careful you scrap the downpipe on something and it might cause the piping to move if its not tightened down well enough and you will run into problems.
T
Old Aug 1, 2007 | 05:00 AM
nosurf2day's Avatar
nosurf2day
Its nice to see that I am not the only one this has happened to. I thought because I installed it myself I did something wrong.
Old Aug 1, 2007 | 06:27 AM
IIQuickSilverII
welll i guess somethign on the install jsut wasnt perfect there...but its all good... the important thing is that you are going to get it up and running pretty soon =]
Old Aug 1, 2007 | 12:20 PM
VIZAGE's Avatar
VIZAGE
I'd like to state that again for those doing self installs. Double and triple check everything. I'm like you and wanted to install my own stuff. It was my first turbo install and I felt I did a pretty good job. Being nothing has went bad so far. But Forged did come back and change some small issues, for they went over the hole system before tuning it. No charge. That's customer service.
Old Aug 1, 2007 | 01:02 PM
nosurf2day's Avatar
nosurf2day
I agree, that is good customer service. I am going to have performance factory do my re-tune as soon as my car gets out of the shop from being rear ended 2 days after putting the turbo on. BOOOOOOO!
I am sure they will do a once over on my car as well to make sure it is in okay condition to tune. There should'nt be any problems since CFT didnt find any issues. But if there is, its going to cost me though, jeremy said a bill an hour, i guess thats a bit pricey but at least I know all the issues will be taken care of.
Old Aug 1, 2007 | 03:52 PM
VIZAGE's Avatar
VIZAGE
That price is about avg. Good luck with everything. Let us know the updates?
Old Aug 2, 2007 | 12:01 AM
solidsnake's Avatar
solidsnake
That happened to me. It was horrible but it got fixed.
HoBrahYouStink
Jun 24, 2016 10:58 PM
Depravity
Oct 1, 2015 04:49 PM
codek
Sep 28, 2015 03:03 AM
