Official STS Rear Mount Turbo Discussion Thread
Old Aug 13, 2007 | 09:31 AM
  #61
DanielW's Avatar
DanielW
Originally Posted by aarantes
Like abyss said I am sure it can be done but this kit is fairly new. So the owners of this kit are still in the process of figuring out what works best with it.
+1 I'm thinking the kit is good for maybe like 450 with all the bolt ons, cams and possibly heads. I think I'm gonna go ahead and build my motor soon though so hopefully then we'll see what its capable of
Old Aug 13, 2007 | 10:43 AM
  #62
DanielW's Avatar
DanielW
I was just doing some reading about the sts kit for corvettes on the corvette forum and it appears that some of those guys changed the AR housing (I'm guessing this is the turbo housing) from like .49 to .36 to get spool up about 500 rpms quicker. Does anyone know if this would work for our kit?
Old Aug 13, 2007 | 10:59 AM
  #63
taurran's Avatar
taurran
I'd assume it comes with a T3 turbine housing out of the box, it is .49 ar? That's pretty small! If you went any smaller you'd might get slightly better spool but run the risk of killing top end power. I'd personally go larger if anything. The kit obviously spools quick enough as is.
What are the exact specs on the turbo that come with it?
Old Aug 13, 2007 | 11:32 AM
  #64
Oleg's Avatar
Oleg
Off-topic as ever, but what the hell...
Awesome avatar, and couldn't be in a better time. I was moving some more crap from my parents' house this weekend and found my old Nintendo. Fired up that thing for the first time since college. Huffed and puffed forever until finally getting the Mario 3 to work.
OK, back to topic...
Old Aug 13, 2007 | 12:02 PM
  #65
MIAPLAYA's Avatar
MIAPLAYA
The STS kit comes with a T4 O trim turbine with a .49 A/R. you could go smaller to help spool up but you might hurt top end power...
Old Aug 13, 2007 | 12:10 PM
  #66
athenG's Avatar
athenG
hhhmm... last time I check I have a 60-1 with .58AR, at least that what I saw from the Turbo. got to check them again
STS states that Rear-Mount Turbo are different from Front-Mount Turbo. Interchanging them will not yield best performance since they are a little differently made. Is this true? I'm thinking of getting the GT35R for faster spooling but don't know if it will work
Old Aug 13, 2007 | 12:39 PM
  #67
DanielW's Avatar
DanielW
The kit includes:
-Turbo – TO4E60 O Trim .58 AR housing 520 Crank HP turbo
-Spark Plugs – NGK One stage colder
-Injectors – 440cc
-Intercooler – Front mount air to air
-BOV - Tial 11 # spring below 4000 feet
-Waste Gate – Tial 38mm .4bar spring unless order different
-Tuning – UTEC tuning with MAP-Unless different MAP needed Email Rick
-Oil – STS patented 2 speed oil pump with lines and check valve
-PCV – STS patented PCV crank case boost eliminator with lines
-Wire – STS Multi role wire harness with optional meth pump connection
-Pipes – STS HPC coated inside and out charge pipes with high pressure silicones and clamps
-Bolts – STS 350Z bolt kit
-Fuel- Walbro 255lph fuel pump
those are the specs
Also, I wouldn't necessarily say lag is a huge issue but it is deffinitely there and something that i want to improve on.
Old Aug 13, 2007 | 12:54 PM
  #68
athenG's Avatar
athenG
I was looking at some of the Dyno on a TN kit and most I see is that they get Full Boost around 4K-4.2K RPM (Maybe I'm wrong). I typically hit full boost around 3900RPM. So I guess we are on par with other ST Kit out there.
TN guys feel free to correct me.
Old Aug 13, 2007 | 12:56 PM
  #69
MIAPLAYA's Avatar
MIAPLAYA
The kit includes:
-Injectors – 440cc
those are the specs
my apologies on the A/R i thought it was a .49. Everything I else I stated is still valid. Its a T4 O trim turbine and yes going down on the A/R should help spool up but the smaller you go on the A/R the larger the hit you will take on the top end as the turbine starts getting choked. The compressor I made no mention of but I would have said it was a T04E 60 trim...
Old Aug 13, 2007 | 12:57 PM
  #70
MIAPLAYA's Avatar
MIAPLAYA
I make a full 8 PSI by 3500-3800. I have seen full boost at 3200 several times...
Old Aug 13, 2007 | 02:12 PM
  #71
DanielW's Avatar
DanielW
Yeah from what i understand the traditional single's spool up a bit quicker. When you guys are sayin hits full boost does that mean in 4'th gear? because it seems like mine spools much more quickly in 4'th and 5'th...
maybe its just the fact that in those gears the boost is climbing alot faster than the rpms
Old Aug 13, 2007 | 05:24 PM
  #72
HDPDZO6's Avatar
HDPDZO6
With the TT STS setup at stock boost (5.5psi), C5ZO6 owners report an average of 500-550 rwhp (conservative tune) and report hitting boost ~3000rpm.
Is there a reason why the STS for the 350Z is only single?
Old Aug 13, 2007 | 06:05 PM
  #73
athenG's Avatar
athenG
Most of the TT STS kit are for V8. Not sure if there is enough exhaust flow to spool 2 turbo in the back with our little V6... Maybe it can
  #74
abyss's Avatar
abyss
They all start out single. Every car they have made a Single turbo kit for, then developed a Twin system for cars that had high demand.
Old Aug 13, 2007 | 06:13 PM
  #75
HDPDZO6's Avatar
HDPDZO6
So if enough units sell, then possible of a TT kit, I guess. Would be very interesting to see what kind of numbers from a 350Z TT kit.
Old Aug 14, 2007 | 11:52 AM
  #76
DanielW's Avatar
DanielW
I honestly don't think with the current pricing of this kit that they are going to be that successful with it, at least not enough to justify a TT kit
Old Aug 14, 2007 | 03:58 PM
  #77
Cube's Avatar
Cube
I honestly don't expect it to stay above $6k for much longer, if they are even charging that as it stands... they're slowly realizing their market. Give it another few months and it'll go above $6k and back down below, UTEC and all.
If not, they'll stop offering it. If they stop offering it, they might offer TT version for ~$7k would be a reasonable price for everything included.
Old Aug 14, 2007 | 04:33 PM
  #78
i8acobra's Avatar
i8acobra
I'd pay about $4K for a kit with the BB upgrade but without the UTEC, Walbro or injectors.
Old Aug 14, 2007 | 04:46 PM
  #79
HDPDZO6's Avatar
HDPDZO6
Can get the universal tuner kit for under 3k. Piping and other parts not included.
Old Aug 15, 2007 | 05:26 AM
  #80
goosegoose's Avatar
goosegoose
Since this is the "official" thread, I figured I might chime in. Here's some logs of my recent 8 PSI run for documentation of before and after the heat wrapping.
https://my350z.com/forum/showthread....66#post4232466
