Official STS Rear Mount Turbo Discussion Thread
Old Oct 21, 2007 | 05:51 PM
  #741
athenG's Avatar
athenG
Originally Posted by Ahsmo
haha I am addicted to this. I have a boost leak but 5.5 psi is still a hoot!
nismo mid pipe, nismo y-pipe, and ebay test pipes
thanks guys!
Just FYI, Rear-Mount has to be really warmed up before you get its max potential so take that into consideration when tuning. After the Turbo has broken-in in a few thousand miles, the turbo will respond better and sound will also be better
Old Oct 21, 2007 | 08:33 PM
  #742
DJ SMITTY's Avatar
DJ SMITTY
CIN Motorsports
thanks guys!
Which AFR gauge are you using?
Old Oct 21, 2007 | 08:35 PM
  #743
Zike's Avatar
Zike
i've been reading through some of this for hours and finally got tired. so far who has put down the most power and with what mods on the sts kit?
Old Oct 21, 2007 | 09:23 PM
  #744
Ahsmo's Avatar
Ahsmo
Imakecopies
I will take that into consideration.
DJ, I am running the AEM Uego wideband right now. In the Wideband shootout it did pretty well so I figured it would work just fine for my low HP goals.
Old Oct 22, 2007 | 04:39 AM
  #745
DanielW's Avatar
DanielW
I think right now it would either be tegraracer or athenG I think they both hit 36X whp on mostly stock setups at like 8 psi, but don'tquote me on that
Old Oct 22, 2007 | 06:27 AM
  #746
athenG's Avatar
athenG
I have about 365whp/377TQ on 8PSI and stock exhaust. The only thing I have is MREV+.
Old Oct 22, 2007 | 07:14 AM
  #747
DanielW's Avatar
DanielW
athenG it would be cool to see a before an after dyno of your car with like test pipes and retune.
Old Oct 22, 2007 | 07:35 AM
  #748
athenG's Avatar
athenG
I was thinking of doing the IC+TP at the same time with a new Tune but that will not show how the IC helped. I'm going to have to see what is the most economical way to see both changes, I don't think there is any but do them all separately.
Old Oct 22, 2007 | 08:12 AM
  #749
TegraRacer134's Avatar
TegraRacer134
We are at the same power levels. I made 364whp and 360tq but I was bone stock other than a clutch and flywheel. I am getting retuned in two weeks and I have test pipes Y pipe and a spacer so well see what kind of power I make
Old Oct 22, 2007 | 08:53 AM
  #750
Zike's Avatar
Zike
so no one has tested this with a built motor yet. i'm also curious to see what this kit maxes out at
Old Oct 22, 2007 | 09:06 AM
  #751
athenG's Avatar
athenG
We just got screwed by CUBE so no built motor yet J/K To bad Cube had a change of heart.
Old Oct 22, 2007 | 10:17 AM
  #752
Zike's Avatar
Zike
i wish someone was local to me, i would love to get a ride in one
Old Oct 22, 2007 | 11:31 AM
  #753
athenG's Avatar
athenG
If you get a chance to drop by NYC then I'll give you a ride
Old Oct 22, 2007 | 05:57 PM
  #754
Ahsmo's Avatar
Ahsmo
Imakecopies
what have you guys been using for a boost controller? I am thinking about going with the Utech solenoid... but SGP sounded a little iffy about it.
Old Oct 22, 2007 | 06:19 PM
  #755
athenG's Avatar
athenG
I use the Utec BCS and it work fine for me. It is cheap and work well with Utec so I can't complain. Great thing is that your Map/boost is one flip away.
Old Oct 22, 2007 | 06:47 PM
  #756
DanielW's Avatar
DanielW
I'm using the Apexi AVC-R EBC but wish i would've went with the HKS unit. The manual boost controller does fine but a few of us have experienced boost pressure drops at higher rpms's with this kit
Old Oct 23, 2007 | 05:56 AM
  #757
Ahsmo's Avatar
Ahsmo
Imakecopies
Did the stand along boost controller eliminate your pressure drops? I read your thread about this. It seemed like you were still playing around with it.
Did you install the BCS? If so how hard did you find it to set up? (If I go this route I would rather not pay SGP for an install that I can do)
Old Oct 23, 2007 | 06:02 AM
  #758
goosegoose's Avatar
goosegoose
I believe both athenG's setup and my own were completed with the UTEC BCS by MRC Motorsports before either of us took original delivery.
Old Oct 23, 2007 | 06:15 AM
  #759
Ahsmo's Avatar
Ahsmo
Imakecopies
okay thanks
Old Oct 23, 2007 | 06:42 AM
  #760
TegraRacer134
You dont need to go electronic...I am using the Turbo XS Boost Controller and it holds my boost great. i dont have any pressure drops or boost drops in the higher RPMs.
