Official STS Rear Mount Turbo Discussion Thread
Old Jan 14, 2012 | 07:33 PM
  #2741
rawley_12003's Avatar
rawley_12003
Ok thanks I will talk to precision Monday about cost for rebuild
Old Jan 18, 2012 | 06:30 PM
  #2742
rawley_12003
Well called precision they wouldn't give me a ruff quote so my next question is what turbo are you guys running and how do you like
Old Jan 18, 2012 | 06:53 PM
  #2743
str8dum1's Avatar
str8dum1
i had my turbos rebuilt from them. 300$ for new seals, 550$ for new chra.
Old Jan 20, 2012 | 04:20 PM
  #2744
rawley_12003
well i think the my precision turbo 6265 ball bearing seized up cuz i don't even hear initial spool so i decided to get the gt35 that going for 400 and use it for my break in while I save more money to build this turbo the way i want it instead.
Old Jan 26, 2012 | 06:31 PM
  #2745
bgant3's Avatar
bgant3
Im considering this Kit. At the moment Im have another engine in garage I am going to rebuild for boost. Then just swap in, when ready for turbo.
My Question, could a rear mount turbo make an a efficient 525rwhp? That is my goal at the least. Im not interested in dumping ton of cash into a bottom end build to only get mid 400s.
all things considered, The sound is amazing on sts kit.
Old Jan 26, 2012 | 11:36 PM
  #2746
athenG's Avatar
athenG
You can but if you want mid-500 then it is much easier with a TT.
Old Jan 27, 2012 | 09:48 AM
  #2747
str8dum1's Avatar
str8dum1
you can make as much HP as you want with a rear mount. All depends on turbo size.
Old Jan 27, 2012 | 09:52 AM
  #2748
KingBaby's Avatar
KingBaby
Hardest Setting
That's what I collect from reading about the magical turbo!
Supporting mods too...
Old Jan 27, 2012 | 12:40 PM
  #2749
athenG's Avatar
athenG
Check CMyTailsBlink old build and look at the 600whp dyno and you'll see his power is way up high. That is with race gas and with a fully built 3.8L motor. I have also witness goosgoose try to break that 500whp on a built 3.5L motor and it wasn't pretty. Last time I checked he went TT and he said it was a night and day difference.
Hey, if you want to be unique and you want some challenges then go for it. I have a small turbo and I'm lucky to hit 6psi on first gear (full boost is 8psi). I can't imagine having a big turbo back there... I guess it will help with the traction.
https://my350z.com/forum/shop-builds...21-torque.html
Old Jan 27, 2012 | 01:14 PM
  #2750
Boosted Performance's Avatar
Boosted Performance
Vendor - Former Vendor
The bold should say "what gear you are in".
Old Jan 27, 2012 | 01:48 PM
  #2751
rawley_12003
Goose goose told me it was a bad build cuz I have his kit lol oh athensG did you reroute your charge pipe to the center of the car?
Old Jan 27, 2012 | 02:12 PM
  #2752
athenG's Avatar
athenG
yes goosegoose just had some bad build or bad luck. i feel bad for him because he spent a lot of money.. its not sts fault though...
yes i had my charge pipe routed in the middle. my car was the first one to get it. i just cant drive with that ugly pipe on the side here in new york... being first sometime suck because my pipe wasnt jethot coated so part of the rear pipes are rusted now wow its almost 5 years since i had the kit.... the damn kit and my motor are still running fine so i had no reason to change it.. but the moment the turbo goes out, I'm jumping ship.. for a change..
Old Jan 27, 2012 | 07:17 PM
  #2753
streetzlegend's Avatar
streetzlegend
Just curious, what was it about his build that kept him from reaching over 500?
Old Jan 27, 2012 | 07:27 PM
  #2754
str8dum1's Avatar
str8dum1
ya rear mounts suck
http://www.youtube.com/watch?v=OI8epUHHpRA
Old Jan 28, 2012 | 06:04 AM
  #2755
rawley_12003
Atheng does sts sell the reroute pipes or did you just do a custom pipe job?
Old Jan 30, 2012 | 05:56 AM
  #2756
athenG's Avatar
athenG
combination of built motor blowing twice and not having the right turbo in the first stages of his build. His tranny also being Auto didnt help..
I believe they started selling the re-route pipes on their standard kit. They do sell the modified pipes.
Old Jan 30, 2012 | 06:00 AM
  #2757
athenG's Avatar
athenG
no doubt the rear-mount will perform especially on bigger motor.. but you can say the same thing with a front-mount.. let us compare apples to apples. take a Big single front mount turob put that to a 3.5L motor and compare the number and the power curve to a rear-mount with the same size turbo and motor. I think in smaller turbo, the difference is not that huge but the bigger the turbo the power curve start shifting to the right (higher rpm).
Old Jan 30, 2012 | 05:35 PM
  #2758
rawley_12003
ok so i called sts about new re route piping total with shipping is around $505.00 is a little high?
Old Jan 31, 2012 | 12:33 PM
  #2759
athenG's Avatar
athenG
Is it jethot coated? I may just re-order a new set for my self to replace my old one..
Old Jan 31, 2012 | 07:51 PM
  #2760
rawley_12003
no it is not coated for that price and that military discount price.
