Official STS Rear Mount Turbo Discussion Thread
Old Oct 25, 2007 | 12:17 PM
  #761
Ahsmo's Avatar
Ahsmo
Imakecopies
I ordered a Turbo XS BCS and a Greddy radiator cap (+15 HP at least)
I also got new tips to replace those non exsistance ones on there already. They are similar to the tips that are on the stock exhaust.
When they tried to put my car on the lift they tore up one of my silicone couplings. Oh well!
Old Oct 25, 2007 | 12:30 PM
  #762
athenG's Avatar
athenG
You really have to be carefully lifting your car with the old piping coz it is right next to the rail. When are you going to tune the car? Can you post a before and after the tune? If you break the 370whp then I'll definitely going to get the Greddy Radiator Cap
Old Oct 25, 2007 | 06:00 PM
  #763
DanielW's Avatar
DanielW
hey what happened to the original MRC Motorsports feedback thread on the sts kit? I wanted to look at those dynos and now i can't seem to find the thread
Old Oct 25, 2007 | 06:26 PM
  #764
Quamen's Avatar
Quamen
He deleted all his old threads after the FI conduct thread
Old Oct 25, 2007 | 07:13 PM
  #765
athenG's Avatar
athenG
Here's one of mine (4.5 and 8PSI) and you can just ask goose to post his.
Old Oct 26, 2007 | 08:53 AM
  #766
IIQuickSilverII's Avatar
IIQuickSilverII
i think julian put them down.... sounds aobut new forums rules... not sure..but i think he took down most of his "Findings" threads
Old Oct 26, 2007 | 09:13 AM
  #767
DanielW's Avatar
DanielW
are those numbers using DJ correction? or are they DD uncorrected numbers
Old Oct 26, 2007 | 09:41 AM
  #768
athenG's Avatar
athenG
Not sure if Julian used the DJ Correction.
Old Oct 26, 2007 | 10:02 AM
  #769
IIQuickSilverII
it doesnt matter cause the point was that it was making power all the way to the top
Old Oct 26, 2007 | 10:30 AM
  #770
DanielW's Avatar
DanielW
It kinda does matter, I mean the whole curve would be bumped upsignificantly with a DJ correction. And the peak WHP would be significantly better but thinking back on it he probably did do the DJ correction because he was trying to show what kind of #'s the kit could make.
Old Oct 26, 2007 | 10:46 AM
  #771
Julian@MRC's Avatar
Julian@MRC
The correction was DJ. The curve would be the same be it DJ or DD, would change the actual power curve, just the scaling of it.
On a side note,Im about to leave my shop in 5 mins to go to the local Dyno Jet to back up a customers DJ numbers to see how accurate it is.
If you look at the two different graphs at the two psi levels, you can see a loss of power at 6000 rpm's due to turbo inefficiency/heat related issues as you go up in psi.This is the same issue Tuarran is having I think with the single turbo.
Old Oct 26, 2007 | 11:53 AM
  #772
DanielW's Avatar
DanielW
yeah that slight dip in the curve was what i was wanting to see. If you don't mind could you post goose's up or goose could you do it so i can see a 5AT?
Old Oct 26, 2007 | 12:00 PM
  #773
athenG's Avatar
athenG
Page 11 has some Dyno from Goose new tune and old.
https://my350z.com/forum/showthread....293025&page=11
My Pipe being in the middle next to the CAT and exhaust added some heat so my IAT did increase. Rick also suggest that a better flowing IC will help so the Turbo doesn't have to work twice as hard. If you look at goose old Dyno (353.8whp), his power doesnt drop in the end. Now look at his new dyno with the relocated pipe, you can see he does have the same drop as mine. Post # 211
Old Oct 27, 2007 | 01:51 PM
  #774
Ahsmo's Avatar
Ahsmo
Imakecopies
I felt like I should post a few pictures of my install in this thread incase anyone reads this...
Old Oct 28, 2007 | 05:03 AM
  #775
Cube's Avatar
Cube
I must admit that is pretty sweet to have an intake tube coming out of nowhere and no hint of a filter anywhere
Anybody who didn't know any better would be puzzled and try to follow the IC piping and be even more lost. Nice clean Z, you should polish the plenum to match the intake tubing... btw did you polish the intake tubing yourself? Doesn't look like you did b/c of the engraving just under the dipstick... but just making sure.
Old Oct 28, 2007 | 05:26 AM
  #776
Ahsmo's Avatar
Ahsmo
Imakecopies
yeah it really is pretty stealthy. I am really happy it turned out the way it did. I really would like to polish the plenum but from I've read it will take a very long time. It may be worth it though. I didn't mess with the intake tubing.
Old Oct 28, 2007 | 05:32 AM
  #777
athenG's Avatar
athenG
That is the first thing I also noticed! For some reason your intake tube look more polished than mine
Old Oct 28, 2007 | 03:06 PM
  #778
DanielW's Avatar
DanielW
mines pretty shiny too. I think its a very good under hood look with this kit
Old Oct 28, 2007 | 07:21 PM
  #779
Cube's Avatar
Cube
Hey, I was wonderin, anybody ever heard of the STS single turbo kit? I heard Camaros and Tacomas and even Corvettes are putting their turbos in the rear, anybody ever try it on a Z???
lol... anyways, is it just me or are people hearing about 2 instances now of stuck-open injectors due to an STS install...? One engine-destroying and the other... not?
Old Oct 28, 2007 | 09:59 PM
  #780
zmedic16's Avatar
zmedic16
does this kit fit the 06 rev ups/??
