Official STS Rear Mount Turbo Discussion Thread
Old Nov 12, 2007 | 06:24 PM
  #841
TegraRacer134's Avatar
TegraRacer134
Originally Posted by 98intrigue
My car made 355whp @ 8psi on Jeremy's dyno in August, before our last track day when I ran a 12.2 @ 115mph. THe STS car made 409whp at 10psi on Jeremy's dyno on Friday night. Saturday, we compared our cars and you saw the results. His car no traction issues. My car spun through 2nd gear, so I had to feather the gas in 2nd. You saw the results...
I went to the track on Wendesday and ran a 12.4 @ 116mph with a only a 2.0 60' on 265/45/18 BFG DRs...I know I can't launch
Ryan your car has way more power than 355. It would not have been that close. Are you bitter that my car is FASTER than yours.
Old Nov 12, 2007 | 07:30 PM
  #842
taurran's Avatar
taurran
Run it at the strip and post time slips.
I would have loved to have run your car while I was on the stock motor. I have no doubt it would have hung well with less boost and on a reflash.
Old Nov 12, 2007 | 08:43 PM
  #843
98intrigue's Avatar
98intrigue
I can have Jeremy post my dyno sheet if you want.
Old Nov 13, 2007 | 05:59 AM
  #844
athenG's Avatar
athenG
Was there any correction? You dynoed at around August and he did in November so maybe that is why you have lower #'s.
Old Nov 13, 2007 | 11:37 AM
  #845
Audible Mayhem's Avatar
Audible Mayhem
My350z
ryans car really only makes 355 on my dyno. we have had it on there a few times. it really is just fast for a G35 for some reason.
Old Nov 13, 2007 | 11:54 AM
  #846
athenG's Avatar
athenG
Does this have some voodoo parts? J/K
Old Nov 13, 2007 | 05:31 PM
  #847
DanielW's Avatar
DanielW
either way its good to see these results from the rear mount kit
Old Nov 21, 2007 | 06:29 PM
  #848
DanielW's Avatar
DanielW
http://www.cardomain.com/ride/2945904 is this some marketing bs from STS or do you think this guy is for real? seems bogus to me
Old Nov 21, 2007 | 06:36 PM
  #849
athenG's Avatar
athenG
Well he has bigger turbo, but no Dyno. I don't think STS would go to car domain and do that. It's probably one customer who's jacking up his ##'s or maybe he was converting his WHP to BHP.
Edit:
Anyways I also got some TestPipes but not Invidia (I got the UTR). Hope I can replicate all your success. I was also offered to test the new FMIC by Rick but I'm still waiting for their Specs and I want to compare it to the FMIC I have. They are also in the process of testing their new BB Turbo. Subzero had some minor body accident so STS has to wait for it to be done before they can do the testing.
Old Nov 21, 2007 | 07:36 PM
  #850
Ahsmo's Avatar
Ahsmo
Imakecopies
I doubt it.
I hit 370hp at 8.2 psi. Maybe if I put on my spacer I may pick up another few ?
Old Nov 22, 2007 | 08:09 AM
  #851
DanielW's Avatar
DanielW
Edit:
I'll be interested to see the results of the BB turbo. I don't think I need the intercooler since i wont be going past 8psi without building the motor with my boost spike between shifts and all. Once I go passed 8 psi the boost spikes up so high that it will occasionally pull timing when i shift
Old Nov 22, 2007 | 10:37 AM
  #852
athenG's Avatar
athenG
That is what the test is for. Rick wanted some third party result on how the TQ curve, Power, response time, IAT after the new FMIC. Would you rather have a better flowing IC and better response even at just 8psi (Better IC will help the turbo not to work harder)? Anyways, the new FMIC should almost be a direct bolt-on but just needed to do some minor cutting. I'm comparing the cost if I just put the FMIC I have with custom fabrication and the STS seem to be more cost effective with all the Dyno's added. There is already a shop that volunteered to do all the testing so we can all just sit and wait
Old Nov 22, 2007 | 11:02 AM
  #853
DanielW's Avatar
DanielW
do you really think the intercooler will help "response"? I mean i can see it being a bottle neck once boost builds up but not really when your trying to get into positive boost
Old Nov 22, 2007 | 11:32 AM
  #854
athenG's Avatar
athenG
Well he wanted some test around 8-10 psi so you might not see anything below 8psi. I'm curious what the result will be. He didn't have the specs since he was on vacation but he said that the flow was double of the base IC. Even at 8psi there is still some pressure drop since the turbo is all the way in the back not to mention with a Tube/Fine FMIC. I guess we can just all wait and see if the the FMIC actually do help even at 8psi.
Old Nov 23, 2007 | 09:22 AM
  #855
DanielW's Avatar
DanielW
yeah it'll be interesting for sure but I think I would be much more interested in a BB turbo.
Old Nov 23, 2007 | 12:48 PM
  #856
Ahsmo's Avatar
Ahsmo
Imakecopies
My dyno graph
Old Nov 23, 2007 | 01:58 PM
  #857
DanielW's Avatar
DanielW
so what are the actual numbers and what psi are you at? 370/370 @8psi?
Old Nov 23, 2007 | 02:24 PM
  #858
Ahsmo's Avatar
Ahsmo
Imakecopies
SGP said 370/370 @ 8.2 psi
Old Nov 23, 2007 | 02:25 PM
  #859
DanielW's Avatar
DanielW
nice
Old Dec 21, 2007 | 06:52 AM
  #860
App6MT's Avatar
App6MT
Any updates on anyones aspect?
