Official STS Rear Mount Turbo Discussion Thread
Old Jan 27, 2008 | 10:22 AM
  #1081
athenG's Avatar
athenG
/\ FWIW you don't really loose that much power, It's like having the MREV2, the power just shifted a little early. If I'm not mistaken, he hit his Peak HP at around 6000rpm with the old piping, and now he hit Peak HP at around 5600-5700rpm. I think it is better coz the power is very usable on street driving plus most shop suggest to ship around 6000rpm when FI and stock block anyways.
Here, this will give you an Idea since goosegoose graph is very close to mine. You can see that I hit Peak HP arond 5650rpm
Old Jan 27, 2008 | 10:26 AM
  #1082
Ahsmo's Avatar
Ahsmo
Imakecopies
hmm that looks like an advantage. For whatever reason I thought it dropped by like 20 hp. Do you have a plenum spacer?
Old Jan 27, 2008 | 10:40 AM
  #1083
athenG's Avatar
athenG
I found Goosegoose dyno..
Originally Posted by MRC Motorsports
The spool time on the Automatic car acutally seemed better than the 6MT car on the road. The power loss at higher boost levels is most likely due to several reasons.
1) The stock cats and exhaust are restricted in flow at this boost level, the set up is not the most efficient way to turbo a car you know.
2) The New intake piping runs closer to the auto tranny and cats and does absorb alot of heat. The timing map I had to run was much less aggressive than the previous map, especially around the peak TQ area.
3) The exhaust gasses going to the turbo, if allowed to flow better with an aftermarket exhauste, would most likely aid in spool up time.
4) larger intercooler couldn't hurt..
Another facotr is Auto cars are much harder to dyno consistantly as far as boost spooling..
Both of us still have stock CAT so that could be the bottleneck on the upper rpm.
Old Jan 27, 2008 | 10:47 AM
  #1084
Ahsmo's Avatar
Ahsmo
Imakecopies
Here is mine with test pipes and a nismo midpipe
Old Jan 27, 2008 | 11:24 AM
  #1085
athenG's Avatar
athenG
Do you think the nismo mid pipe is hurting your spool? Teg hit 10psi at 3700rpm and I see your Peak TQ at 4600rpm.
It think Daniel should add all of this Dyno on the first page coz after awhile it is hard to find. Goosegoose dyno is on page 12 (i think).
Old Jan 27, 2008 | 11:25 AM
  #1086
goosegoose's Avatar
goosegoose
This nismo mid pipe interests me as well. Do you have any specs on it?
Old Jan 27, 2008 | 11:48 AM
  #1087
Ahsmo's Avatar
Ahsmo
Imakecopies
Yeah I am just as confused about that as you are. I have no idea why it does that? Nobody has really commented on it in the past.
In a sense I think the larger midpipe does hurt my spool up time because it is just a larger heat exhanger than the stock mid pipe. However, I think it does a better job of getting exhaust gases to the turbine but at the expense of losing more heat to the atmosphere. I believe heat management (whatever that may be) is the key to achieving faster spool with our kits. Also that is using the utec BCS which the map may or may not have been adjusted for the best spool up rate. I am going to replace it with a the HKS EVC shortly. Also, I suspect that I have a boost leak somewhere...my idle sucks and that dyno chart looks odd.
+1
I had a nismo exhaust on before I put the turbo on so I was forced to use it. It does not bolt directly up to the turbo piping. I had to cut the nismo mid pipe and weld on a new flang which was a pain in the *** without a welder at my house. I had to use bondo to get the flang positioned right. Best bet would be to go to an exhaust shop and have them bend a mid pipe for ya. I should have done that but oh well.
Oh yeah forgot that I also have the nismo Y pipe on.
**Edit
I just bought a HKS EVC 6 so I am giving up on the utec BCS. Maybe this will help with spooling like it helped Daniel. Guess I am going to have to go back to SGP to get tuned after all.
Old Jan 27, 2008 | 03:57 PM
  #1088
TegraRacer134's Avatar
TegraRacer134
Heres my dyno sheet again if you guys wanted to see it.
Stock Plenum, Invidia Test Pipes, Turbo XS manual BC.
Old Jan 27, 2008 | 04:28 PM
  #1089
Ahsmo's Avatar
Ahsmo
Imakecopies
What PSI is that?
Old Jan 27, 2008 | 04:31 PM
  #1090
athenG's Avatar
athenG
Originally Posted by Ahsmo
What PSI is that?
I think that is around 10 psi.
Old Jan 27, 2008 | 04:48 PM
  #1091
DJ SMITTY's Avatar
DJ SMITTY
CIN Motorsports
^10.5 pretty solid all across the board. pulls reallll nice.
Old Jan 27, 2008 | 08:07 PM
  #1092
TegraRacer134
That was at 10 pounds...Driving it hard everyday since early November and havent had a problem yet.
Old Jan 28, 2008 | 07:06 AM
  #1093
Audible Mayhem's Avatar
Audible Mayhem
My350z
hey guys!!
it was nice meeting you daniel. hope the car runs just how you wanted it to.
the tune that was on it was extra extra extra conservative before and we just took advantage of what we could through your 5AT tranny.
see ya at Z Dayz!!
Old Jan 28, 2008 | 08:29 AM
  #1094
DanielW's Avatar
DanielW
nice meeting you too man. Thanks again
Old Jan 28, 2008 | 09:46 AM
  #1095
Ahsmo's Avatar
Ahsmo
Imakecopies
Deleted
Old Jan 28, 2008 | 09:59 AM
  #1096
athenG's Avatar
athenG
/\ I already updated the first page with all our dyno and setup.
Old Jan 28, 2008 | 10:00 AM
  #1097
Ahsmo's Avatar
Ahsmo
Imakecopies
Opps, sorry didn't see it...Thanks
On a side note, we do need to get some videos up. Mine is really too loud. I can't even hear my wastegate open...
Old Jan 28, 2008 | 10:44 AM
  #1098
athenG's Avatar
athenG
It is really hard to catch the sound on video. The video don't do justice There are some videos on the first few page. I guess maybe because you have a full upgraded exhaust. I still have stock exhaust and CAT and mine is pretty quiet and I love hearing my Turbo spool with window up or down. I can even hear the turbo whine without hitting positive boost or just cruising.
Old Jan 28, 2008 | 10:52 AM
  #1099
DanielW's Avatar
DanielW
I have a decent vid on youtube but it was with highflow cats not test pipes
Old Jan 28, 2008 | 10:54 AM
  #1100
DanielW's Avatar
DanielW
I think John may have dynamatted the inside of his rear and significantly reduced the cabin noise. Maybe he'll chime in here
