Official STS Rear Mount Turbo Discussion Thread
Old Mar 23, 2009 | 09:40 AM
  #1781
JonnyC's Avatar
JonnyC
Originally Posted by DudeMan
sorry for the n00b question but whats uprev?
http://www.lmgtfy.com/?q=uprev
UpRev is a company. Osiris Tuner is a ROM editing tool that allows a shop to create a map to flash to the ECU. No need for any piggy-back computer, just flash it and you are good to go. There are a bunch of threads on this.
Old Mar 23, 2009 | 09:46 AM
  #1782
DudeMan's Avatar
DudeMan
Originally Posted by ErkTheJerk73
tuning comapny... works wonders for n00b questions
ehh from the looks of it i think id stick with a utec over that... theres so many proven tuners who can tune utec
aem would be my preferred choice theres nothing out there that can even compare except maybe a hydra system
but good luck with it
  #1783
thom000001's Avatar
thom000001
Chris,
Just remember, with just a breather you will get some oil spray. So wherever you put it you will get some amount of oil around it (how much depens on a lot of things)....to prevent that you can always due a catch can.
tom
Originally Posted by eXe-Chris
Johnny,
Thank you very much for clearing up the breather valve question I had. I will let you know how the UpRev system works for the STS Kit. What did you end up doing with the different size pipes(wastegate & down pipe) STS sent you? I figured I would take it to a exhaust shop and have new pipes made for both sides since I am running Injen rolled Ti exhaust tips.
Old Mar 23, 2009 | 09:47 AM
  #1784
DudeMan's Avatar
DudeMan
yea we had a similar program called open source for stis... it was good to a certain level but it still isnt a nearly as good as a piggy back or standalone but for lower hp numbers like <400 it was good i used it. when you get into higher numbers youll notice how it will hold you back
Old Mar 23, 2009 | 09:49 AM
  #1785
thom000001's Avatar
thom000001
AEM and VQ's boooooooooooooooooooooooooooooo
AEM and vq ecu do not get along very well.
Much better options these days, Pro-EFI, HKS F-con, Hydra (I guess, only like 1 or 2 people using it thus far), utec, etc.
tom
Old Mar 23, 2009 | 12:11 PM
  #1786
tiguy99's Avatar
tiguy99
Tom, what are your thoughts on the Haltech EMS
Old Mar 23, 2009 | 12:18 PM
  #1787
thom000001's Avatar
thom000001
Haltech is good from what I read. Don't know who tunes it in our area.
That was a big for me, proximity to the tuner....thats why I went Pro-EFI.
tom
Old Mar 24, 2009 | 08:20 AM
  #1788
tiguy99's Avatar
tiguy99
tom
Most defiantly! Ever find out if that Camero and Z driver posted online about their experience with you on 53 Sunday?
Old Mar 24, 2009 | 10:52 AM
  #1789
Boozt's Avatar
Boozt
Ok boys.....a little off subject, but, not. I just received my TS rear diffuser and I want to know how everyone thinks the CF will hold up to the heat from the turbo. I need to mock install and check clearance.....worst case is I fabricate a heat sheild to protect the CF. Does CF stand heat well?????? Any info would be great. -Jim
Old Mar 24, 2009 | 10:57 AM
  #1790
DudeMan's Avatar
DudeMan
does it have a clear coat? if so its not going to take heat well just like hoods and trucks dont take being out in the summer... put a turbo blanket on the turbo and then a heat shield and you should be good
Old Mar 24, 2009 | 11:03 AM
  #1791
Boozt's Avatar
Boozt
Turbo blanket....GREAT IDEA I should have thought of that The outside (visual) has clear coat but not the turbo side...make a difference??
Old Mar 24, 2009 | 11:07 AM
  #1792
tiguy99's Avatar
tiguy99
In for the pics
Old Mar 24, 2009 | 11:12 AM
  #1793
Boozt's Avatar
Boozt
In for the pics
I'll post pics as soon as I get-er-done.
Old Mar 24, 2009 | 11:18 AM
  #1794
DudeMan's Avatar
DudeMan
yes it will heats still going to disperse to the other side
might want to look into this stuff heard it works really well
http://www.elephantmotorsports.com/h...old-p-526.html
Old Mar 24, 2009 | 11:33 AM
  #1795
athenG's Avatar
athenG
I believe goosgoose has a rear diffuser on his G35. My ING rear lip is also pretty low and pretty much less than .5 of on inch (maybe lower) and it has been holding up pretty well. I can barely insert a cloth to wipe the pipe down... At one point my installer didnt install the lip right so it was literally touching the tail pipe so it melted part of the lip. After reinstalling it it hasn't gotten worst, but then again I dont have a CF lip...
Old Mar 24, 2009 | 01:22 PM
  #1796
tiguy99's Avatar
tiguy99
I can only imagine the anguish if a CF lip was melted due to the heat back there.
I may have to look in to this gold foil from the link ^ ^ How much of it do you need to wrap up the everything?
Old Mar 24, 2009 | 01:28 PM
  #1797
DudeMan's Avatar
DudeMan
the everything? lol depends on the area you need to cover its sold my the square foot
Old Mar 24, 2009 | 02:08 PM
  #1798
tiguy99's Avatar
tiguy99
Whoops phone calls and simultaneous posts don't go hand in hand lol
I would assume one would want to cover the rear pipes around the bumper area to protect it from heat damage.
At 28.00/ft I can see this adding up quickly
Old Mar 24, 2009 | 02:28 PM
  #1799
DudeMan's Avatar
DudeMan
well that was for example
12"x24" for 35
http://store.bimmerworld.com/shared/...t=products.asp
Old Mar 24, 2009 | 06:14 PM
  #1800
goosegoose's Avatar
goosegoose
My diffuser has held up to everything. It hasn't melted or deformed in any way. It is fiberglass painted gloss black with a clear coat.
