Official STS Rear Mount Turbo Discussion Thread
Old Feb 23, 2012 | 05:36 PM
  #2781
rawley_12003's Avatar
rawley_12003
Oh ok yeah first run was at 8 psi and 380 I wanted 400ish so it took alot more pulls to get to that hp and clean up the tune
Old Mar 3, 2012 | 06:02 PM
  #2782
rawley_12003
Well just got my momentum performance transmission mount in the mail today just in time before i take the z out to the drag 1/4 mile runs come the 10th of march. I will still be on street tires and no launch control setup yet. so my 60 ft will probably not change lol.. just want to see what my trap speed will be and time of course. So much wheel hop off the dig.
Old Mar 3, 2012 | 06:03 PM
  #2783
2004Black350z's Avatar
2004Black350z
Exhaust Whore
interested in the results you may or may not have with that mount
Old Mar 5, 2012 | 05:33 PM
  #2784
tilleys99's Avatar
tilleys99
So is it the sts kit that restricts the z from making more power or is it the fact it's remote mount. I just got my z running on Saturday with a built motor and a custom remote mount that I fabbed up w some parts from a sts truck kit. I haven't finished my fuel system yet so I haven't driven it. Am I gonna be sorry I did this setup?
Old Mar 6, 2012 | 07:34 AM
  #2785
rawley_12003
Well i have a stage 1 engine from ipp, for brain a haltech platinum and sts turbo kit for my z and love it i don't think it is restrictive i mean i could probably go alot more higher but want reliability. When i build the top end of my engine then i might turn up the boost.
Old Mar 13, 2012 | 05:39 PM
  #2786
SCHITZTANE's Avatar
SCHITZTANE
Originally Posted by bgant3
thats wat im talkn about rawley. If i see someone get 475-500+rwhp outta a STS. i may go that route.
I just dont want to pour 5grand into building a bottom end, for 400hp. leaning towards twins, atm. Do you think theres more potential in your setup? STS sounds like, so awesome.
the turbo goes where the muffler used to be. there is enough room to put in as big a turbo as u want to. but be aware of lag. anything bigger than a gt35r would be best for drag rather than street imho.
Old Mar 13, 2012 | 05:49 PM
  #2787
SCHITZTANE's Avatar
SCHITZTANE
Originally Posted by athenG
check if any of the charge pipe is hitting something, also check the turbo and the air filter. I had this issue but in my case it as the air filter shield hitting the rear vibrating during deceleration..
you can take the filter shield off along with that intake tube with the rediculous 90 degree bend, attach the air filter and filter shield directly to the turbo. you just need to drill another drain hole in the sheild. this will also raise the hieght of the filter a little.
Old Mar 14, 2012 | 07:06 AM
  #2788
athenG's Avatar
athenG
I was thinking of that but I was hesitant because the filter is going to be now to close to the exhaust pipe. I just tied the shield to the frame so now it doesnt rattle
Old Mar 14, 2012 | 07:14 PM
  #2789
SCHITZTANE's Avatar
SCHITZTANE
[QUOTE=athenG;9652472]I was thinking of that but I was hesitant because the filter is going to be now to close to the exhaust pipe. I just tied the shield to the frame so now it doesnt rattle[/QUOT
just go to autozone or whoever and get a smaller filter, many filter options are available. thats what i did. also the new position makes checking and changing or cleaning a snap!
Old Mar 14, 2012 | 07:21 PM
  #2790
SCHITZTANE's Avatar
SCHITZTANE
[QUOTE=SCHITZTANE;9653393][QUOTE=athenG;9652472]I was thinking of that but I was hesitant because the filter is going to be now to close to the exhaust pipe. I just tied the shield to the frame so now it doesnt rattle[/QUOT
just go to autozone or whoever and get a smaller filter, many filter options are available. thats what i did. also the new position makes checking and changing or cleaning a snap![/QUOT
besides that the drivers side exhaust dosent get hot, its the passenger side you have to be concerned with.
Old Mar 15, 2012 | 06:35 AM
  #2791
athenG's Avatar
athenG
the exhaust pipe just after the wastegate still run through the cold side of the turbo to get to the hotside. Anyway, I have no problem with mine right now but I may consider
Old Mar 27, 2012 | 01:41 PM
  #2792
jsrodz's Avatar
jsrodz
350z with sts kit, I went to the dyno yesterday. The car maybe has 500 whp+ because the 20" wheels has a lost more or less 10 to 15 whp.
http://www.youtube.com/watch?v=2aIdL...e_gdata_player
Old Mar 27, 2012 | 04:51 PM
  #2793
athenG's Avatar
athenG
can you give more details (ie, displacement, boost, EMS, turbo size..etc)
Old Mar 27, 2012 | 05:32 PM
  #2794
jsrodz's Avatar
jsrodz
The motor is stock displacement, stock cams, headers, uprev maf sensor, 15 psi, the turbo that came with the kit is a 60-1 with a .68 P but I bore the cool housing and putted a 62mm precision wheel. The car has a rev limit of 7,300 rpm.
Old Mar 27, 2012 | 05:34 PM
  #2795
jsrodz's Avatar
jsrodz
Ems is uprev
Old Mar 27, 2012 | 05:41 PM
  #2796
athenG's Avatar
athenG
Nice... all the pipes are the standard STS kit? also can you post the dyno sheet so we can look at the power curve? how's the lag on 1st and 2nd gear?
Old Mar 27, 2012 | 06:05 PM
  #2797
jsrodz's Avatar
jsrodz
2" piping, I forgot to take the print out of the run, I have to pick it up. First I was having lag problem because of the muffler gaskets, now it makes 6 psi at 1st and then full boost.
For me, is a normal lag. I have full boost from 4000 rpm until 7300 rpm, that is a big power band, that's what matter.
Old Mar 27, 2012 | 06:37 PM
  #2798
SCHITZTANE's Avatar
SCHITZTANE
the 492wtq is more impresive with stock heads and cams
Old Mar 28, 2012 | 07:33 PM
  #2799
rawley_12003
nice makes me want to turn up the boost on my z but have to wait want to do more to my z before i upgrade fuel pump and clutch.
Old Mar 28, 2012 | 07:34 PM
  #2800
rawley_12003
oh what dyno was this on.. dyno dynamics, mustang, dyno jet?
