had a terrible scare with my car last night!!
Old Oct 11, 2007 | 02:02 PM
phunk's Avatar
phunk
CJ Motorsports
Default had a terrible scare with my car last night!!
so yesterday i leakdown tested my engine to make sure after, i dunno, maybe 20K on this engine that its still in good enough shape to turn up the boost. i just put in tighter wastegate springs and im gonna crank her up a few psi or more. this thing has been ROCK solid reliable at 14.5psi for a long time now, and this last week was the first time i have worked on it since i put it together. i did the SGP 3" pipes, open dumps, wastegate springs, changed the plugs, and setup the rear for drag racing (still waiting on getting the suspension tuned by this local shop).
anyhow, my leakdown was at 6% with 2 cylinders at 8%. So I was pretty damn happy. I have seen better, but not with this tester on a VQ engine, even my stock engine before i boosted it was at 6% IIRC.
so last night im taking this girl for a ride, we put gas it, then on the way to get some food im on an open 4 lane road and rip it thru 1st 2nd 3rd. just as i let off third i see something out of the corner of my eye.... i look down, red oil light... forget the little oil spout icon, it might as well just say "you just lost 10 grrr".
i instantly shut it down and coast onto the shoulder. put the hood and look around. check the dipstick, it has oil. glance under it, no signs of a pressure leak. so now its either a broken oil pump or a bad sensor. being like 3am i was like, hell with it, its either already screwed or its fine, and i dont wanna try and get this car on a flatbed. so i fire it back up and listen. everything sounds great.... (the VQ sounds terrible with no oil pressure, as most of us have heard it after you do an oil change as the first 2 seconds or so it doesnt have pressure). i noticed my oil temp gauge is reading normal so oil must be passing over it.
so i drive it home about 10 min, probably less... pull it in and pop the hood and get a good look at it. my power steering belt was starting to shred, and a part of it that was shredded off was wacking my oil pressure sensor wires and pulled them out of the connector!!!
phew. i nearly had a heart attack at the thought of all the work i was gonna have to go thru before driving the car again if it had really lost oil pressure.
18-20psi here i come.
Old Oct 11, 2007 | 02:16 PM
iStan's Avatar
iStan
ZR
Because I'm bored:
Glad to hear everything was ok
Old Oct 11, 2007 | 02:18 PM
Quamen's Avatar
Quamen
Lol
+1
Old Oct 11, 2007 | 02:19 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Geez-that would have made my butthole pucker thinking my engine was damaged. Glad it was something so silly...
Old Oct 11, 2007 | 02:23 PM
Zridder19's Avatar
Zridder19
wow thank god your motor is straight!
Old Oct 11, 2007 | 02:24 PM
Madelinot's Avatar
Madelinot
Yep, that can be scary. I,m glad it wasn't anything serious...
Good luck upping th eboost and report back of course.
Old Oct 11, 2007 | 02:28 PM
booger's Avatar
booger
glad is wasnt bad !
Simular thing happened to me yesterday also . Did a logging run in 3rd [AT5] and got to what I thought was 6800rpm and let off . I then hear a strange ticking or simular sound . Was just 6 blocks from home so I just drove it home . On the way I smell a nasty rubber smell . Pull in the driveway and see smoke coming from under the hood . Pop it open to see I just spun the teeth off the blower belt and the smell was that rubber on the header . WHEW !!
Old Oct 11, 2007 | 02:34 PM
superchargedg's Avatar
superchargedg
Damn Noobs
That would have scared the **** outta me too.Thankfully everything is ok but the belt.
Old Oct 11, 2007 | 02:37 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
You're phunk'ed
Well nearly.
Old Oct 11, 2007 | 03:02 PM
bullseye's Avatar
bullseye
Glad y'all and the engine were OK. That was a terrible scare.
I'll mention my own oil scare while I'm at it... I had the oil changed a couple weeks ago. The next morning, I drove hard to work (running late), and when I got out of my car in our parking lot, light-blue smoke was coming out from under my hood. I first thought cr@p, I must have lost the drain plug between home and work. I gingerly opened the hood, let the smoke clear, and then spotted the dipstick... hanging loose in the engine bay BESIDE the dipstick port. I do not know what kept it from falling down on the road. Some oil (not much) had sloshed out on the side of the block to cause the light smoke. I checked the oil (OK) and replaced the dipstick properly. Then I scraped my underwear. No real harm done. Sheesh!
Old Oct 11, 2007 | 04:30 PM
failsafe306's Avatar
failsafe306
What do you think caused that belt to go, did it have anything to do with how you redid the accessories?
Old Oct 11, 2007 | 05:16 PM
Philthy's Avatar
Philthy
Boost Junkie
Holy Phunk - good thing it wasn't too major of an issue...
Old Oct 11, 2007 | 05:19 PM
taurran's Avatar
taurran
My car always does stuff like that when I've got a lady in the car. I think she (the car) gets jealous.
Glad to hear it was ok.
Old Oct 11, 2007 | 06:07 PM
booger's Avatar
booger
I believe its from still running the stock BOV and 18.6psi @ 6600rpm . BOV doesnt flow hardly enough and doesnt open fast enough . Got a bigger one on order .
edit....oh you was asking Phunk...lol.
Old Oct 11, 2007 | 06:37 PM
fairladyz47597's Avatar
fairladyz47597
interesting story.. you would make a good writer. ever written any books?
Old Oct 12, 2007 | 08:46 AM
QuadCam's Avatar
QuadCam
actually, I think it is in a V.
Old Oct 12, 2007 | 08:48 AM
QuadCam's Avatar
QuadCam
Just get married....then, your wife will hate your car, and conversely, your car will love you more!!!!! I have had less trouble with modded cars ever since I got married. Scary, but true!
QuadCam's Avatar
QuadCam
BTW, who often do you guys change your belts. I am at 32,000 miles and am still running stock belts.
Old Oct 12, 2007 | 08:53 AM
rcdash's Avatar
rcdash
Maybe that's because you have less time to work on 'em
Ha ha.
etkms
Jun 19, 2022 06:30 PM
gc350z03
Oct 28, 2016 05:00 PM
Nihsnek
Feb 9, 2016 12:57 AM
Mw870
Sep 10, 2015 07:50 PM
