Robert_K's JWT TT Build Thread
Old Jan 11, 2008 | 04:10 PM
  #121
JAM3Z's Avatar
JAM3Z
Phenom
Originally Posted by Robert_K
Jamez & Zivman: Please take the BOV Ricer debate else where. Thanks.
Done. Sorry to derail your thread. It was a dumb discussion and I was done with it anyway.
Old Jan 12, 2008 | 06:31 AM
  #122
Audible Mayhem's Avatar
Audible Mayhem
My350z
Originally Posted by DMK
Did they change the design recently? I got mine a couple months ago.
well what they have done is brought out a whole new model. you can still get the previous model too. the new model is made from a brand new denso core and is the same exact size as a stock injector.
they work perfectly
Old Jan 12, 2008 | 06:37 AM
  #123
ncparamedic's Avatar
ncparamedic
Prodigal Son
Robert..honestly i cant remember if i had read about you saying this..
1. Do you think you will need to upgrade the torque converter on the tranny?
2. Are you going to do any type of head work on your build??
Ill delete this reply if you tell me you already discussed it
Old Jan 12, 2008 | 11:07 PM
  #124
Robert_K's Avatar
Robert_K
Didn't Go Cheap
1) Torque Converter? I have a 6sp. Upgraded to the JWT Clutch & Flywheel.
2) The motor will be stock. Maybe in the future I'll build the motor. As for now, no.
Old Jan 13, 2008 | 12:04 AM
  #125
ncparamedic
Prodigal Son
Sounds like you have it way under control. I like the way you are doing this. Very very smart..
Old Jan 13, 2008 | 12:22 AM
  #126
DMK's Avatar
DMK
they work perfectly
Are the new ones more expensive? How can you tell if you have the new ones or the old?
Old Jan 13, 2008 | 02:46 AM
  #127
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Thanks. Hardest part of this build is paying for everything. However, I'm sure the end result will pay for itself.
Old Jan 13, 2008 | 04:00 AM
  #128
TheBlackPearlZ's Avatar
TheBlackPearlZ
so robert then how are you coming?? how much have you bought now and how much you still have left?
Old Jan 13, 2008 | 04:24 AM
  #129
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Well I'm in talks (e-mail) now with my shop/tuner about pricing for the kit itself and install of everything. I have the cash set aside, so I'm pretty much ready. Just need to pick up a couple more items. Waiting on a price from Intense for the following:
- JWT 530BB Twin Turbo Kit
- Cosworth Intake Plenum w/ CF Endcaps (Pre-Ordered 14-Nov)
- JWT Clutch/Flywheel Combo (Purchased 30-Nov)
- DeatschWerks 600cc Injectors (Purchased 30-Dec)
- Walbro 255lph Fuel Pump
- A-Piller Dual Pod Set (Purchased 30-Nov)
- Defi 60mm BF Series Gauges (Purchased 30-Nov)
-- Boost Gauge
-- Fuel Pressure Gauge
-- Defi-Link Control Unit
-- Defi-Link Display
-- Defi Oil Temp Sensor
-- Defi Water Temp Sensor
-- Defi Link Indicator II
- TXS DTEC Map Sensor
- Perrin Boost Solenoid
- Stillen Oil Cooler
- ARC Oil Catch Can
- HKS SSQV BOV
- StopTech 14" F&R Big Brake Kit
ETA of install is mid-March.
Old Jan 13, 2008 | 04:27 AM
  #130
TheBlackPearlZ
so are you gonna make the hike from colorado to zdayz then??? so we can see this bad mammajamma???
Old Jan 13, 2008 | 05:00 AM
  #131
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Doubtful. I'll be headed back to Kuwait right after the install.
Old Jan 13, 2008 | 09:25 AM
  #132
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Car will be dropped off for install: 15-March-08!!!
Old Jan 13, 2008 | 09:29 AM
  #133
phat04350z's Avatar
phat04350z
I was curious how your going to get the a/f ratio? I dont see that in the list?
Old Jan 13, 2008 | 09:48 AM
  #134
Robert_K's Avatar
Robert_K
Didn't Go Cheap
As a reading/visual display or tuning? If you visited the link provided in the OP you would see I already own the TXS UTEC & Tuner wideband.
Old Jan 13, 2008 | 12:35 PM
  #135
phat04350z's Avatar
phat04350z
you running a true dual exhaust? OR a single? just curious how yur going to get 2 readings?
Old Jan 13, 2008 | 05:05 PM
  #136
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Wow! This is from the very post I responded above to answer your pervious question:
Now please visited the link in the ORIGNAL POST (aka First post) and review my current mod list.
Old Jan 13, 2008 | 06:45 PM
  #137
phat04350z's Avatar
phat04350z
All i see is about injectors above mine...
Old Jan 13, 2008 | 06:50 PM
  #138
Robert_K's Avatar
Robert_K
Didn't Go Cheap
OMFG!!! Go Here: Link <~ Click!
Look at post #1 and click the blue link called "Robert_K's 350Z." That will link you to a complete mod list.
Old Jan 13, 2008 | 08:24 PM
  #139
phat04350z's Avatar
phat04350z
Dude chill out being cocky, keep this up and no one one on here will help you. You could have just stated its a true dual exhaust (not really) with an X pipe. You still going to use 2 different a/f ratio guages? Or one?
Old Jan 13, 2008 | 08:36 PM
  #140
Robert_K's Avatar
Robert_K
Didn't Go Cheap
I think the help I might need will still come. And why would I ned two AFR readings?
