Si TRIM VORTECH.
Old Feb 8, 2008 | 02:10 PM
  #301
sentry65's Avatar
sentry65
the burninator
sounds exactly like the TIMROD method plus two idler pulleys, unless it was a revup engine and then would be a little different
IMO this is probably the best serp belt routing you can do.
you can add in another idler pulley on that last long stretch of belt, but it probably really isn't needed unless you're desperate.
It would require the belt to be longer and wouldn't give the belt as much time too cool off
Attached Thumbnails Si TRIM VORTECH.-timrod_layout_gtm_lower_pulleys.gif   Si TRIM VORTECH.-vortech_max_serp_pulley.gif
Old Feb 8, 2008 | 04:35 PM
  #302
JET MECH's Avatar
JET MECH
thats it! it is the diagram to the right. and the engine is a non rev-up.
Old Feb 8, 2008 | 06:42 PM
  #303
booger's Avatar
booger
I actually would prefer the one on the left . Im just thinking here , but I would think the more pulley's you run the hotter the belt would run . The belt is turning to fast to have time to cool off as some might think . Either of thoughs setups will for sure help to provide more boost with a serp setup . Combined with a way to bleed boost off right at or close to the point of slippage [ more than likely 14 to 16psi ] would make for a hell of a set up . I wish I would of thought of it or had it come out before I got the cog set up . WOuld have been less costly and less head aches .
Old Feb 8, 2008 | 09:38 PM
  #304
jksstar's Avatar
jksstar
so did you get any #s today?
Old Feb 9, 2008 | 10:57 AM
  #305
JET MECH's Avatar
JET MECH
no numbers yet, waiting for Sam to call me back today. i talked to one of his techs this morning and he told me Sam was there friday night till 3 in the morning tuning a couple of cars. hopefully one of them was mine.
Old Feb 9, 2008 | 10:59 AM
  #306
JET MECH's Avatar
JET MECH
Originally Posted by JET MECH
no numbers yet, waiting for Sam to call me back today. i talked to one of his techs this morning and he told me Sam was there till 3 in the morning tuning a couple of cars. hopefully one of them was mine.
Old Feb 9, 2008 | 11:56 AM
  #307
jksstar's Avatar
jksstar
Old Feb 9, 2008 | 12:34 PM
  #308
Hexxum001's Avatar
Hexxum001
Patience my friends. The wait will be worth it!
Old Feb 9, 2008 | 12:41 PM
  #309
jksstar's Avatar
jksstar
I was just hoping to see what kind of gains he got before I got mine on the dyno tomorrow.
Old Feb 9, 2008 | 02:16 PM
  #310
sentry65's Avatar
sentry65
the burninator
could be that you'll be the first with the reported dyno. You just never know what you'll encounter when you dyno - might find that you can't get enough fuel for a good tune to be made and that has to first be addressed
Old Feb 9, 2008 | 08:26 PM
  #311
jksstar's Avatar
jksstar
good point.
I'm on my out to get tuned and I'll post up some #s later today.
Old Feb 10, 2008 | 10:33 AM
  #312
JET MECH's Avatar
JET MECH
Just got a call from Sam he is starting my tune right now. he just recived a call from Jeremey at performance factory. things do not appear to be going to well for jksstar over there on the Si-trim tune! Sam would not give me details. let's wait and see........
Old Feb 10, 2008 | 12:30 PM
  #313
JET MECH's Avatar
JET MECH
should have some dyno numbers tonight.
Old Feb 10, 2008 | 04:46 PM
  #314
booger's Avatar
booger
your running a stock block right ?
Old Feb 10, 2008 | 04:49 PM
  #315
JET MECH's Avatar
JET MECH
yes.........
  #316
Quamen's Avatar
Quamen
Where the numbers?
Old Feb 10, 2008 | 04:53 PM
  #317
JET MECH's Avatar
JET MECH
Originally Posted by Quamen
Where the numbers?
Sam has not called me back yet...i will give him a couple of hours then i will make a call to him.
Old Feb 10, 2008 | 04:56 PM
  #318
sentry65's Avatar
sentry65
the burninator
damn
6.5 hours is a long time to tune
edit - nevermind, you have a UTEC, forgot
  #319
str8dum1's Avatar
str8dum1
interesting. wonder if his injectors are too small. Thats the only thing that could really cause a problem. Shouldnt be belt slip bc ive seen over 15psi with no slip. And you guys said that the BPV flows enough air. Cant wait to hear the report!!
Old Feb 10, 2008 | 05:41 PM
  #320
Hexxum001's Avatar
Hexxum001
I hope everything is going okay. I'm anxious to see the results.
