Last FI question for a while.
Old Dec 19, 2007 | 03:25 PM
Everybodywildou's Avatar
Everybodywildou
Default Last FI question for a while.
Okay so I installed my vortech S/C a week ago. I noticed that the oil PSI is kind of low at idle. Forgive me if this is a stupid question, but should I add a little more oil since it is being shared with the S/C unit now?
Old Dec 19, 2007 | 03:26 PM
iStan's Avatar
iStan
ZR
Check your dip stick. It should be a little more than the normal, but I don't think it's much
Old Dec 19, 2007 | 03:31 PM
Everybodywildou
You mean it should read lower right? Cause mine looks like its reading around 15 psi at idle. Just seems kinda low to me.
btw you got PM stan.
Old Dec 19, 2007 | 03:39 PM
iStan's Avatar
iStan
ZR
I meant the oil should be a little more than normal, not the pressure. 15Psi at idle? Hmm, I think I'm reading around 30.
What oil/weight are you using? Any leaks?
Old Dec 19, 2007 | 03:46 PM
Jay'Z's Avatar
Jay'Z
That is low.. Your idle prob needs to be raised.. What are you idling at??
Old Dec 19, 2007 | 03:49 PM
taurran's Avatar
taurran
Don't add more oil unless you have an aftermarket pan or spacer that adds volume. Just check it and change it a bit more regularly.
Old Dec 19, 2007 | 04:17 PM
tommykazi's Avatar
tommykazi
iii
Old Dec 19, 2007 | 04:31 PM
G35asian's Avatar
G35asian
I am running about 20 psi of oil pressure at idle right now fully warmed up. When I really get the car hot (run my car through the gears a few times ) I see around 15psi for a little bit. Just check your dipstick and you should be fine.
Old Dec 19, 2007 | 05:45 PM
Everybodywildou
I'm using Royal Purple 5w30. My Idle seems to be around 700 rpms.
Old Dec 20, 2007 | 07:01 AM
eez's Avatar
eez
After I'm warmed up, my pressure is around 15 PSI at idle and I idle at 1k. No leaks.
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
