Oil On Plugs !!!!!
Old Apr 25, 2008 | 01:39 PM
  #61
blasian's Avatar
blasian
Originally Posted by SC 350Z
did it work and im kinda iffy bout doing that i want it to last for a while i really dont want o tear it all back apart in a couple weeks and where di you put the rtv?
I've been to lazy to check to be honest.
Basically put RTV around the tube seals on the inside of valve cover. I honestly can't see how it wouldn't work. Basically oil seeps through the seals and eventually get to a high enough level to where it overflows.
Old Apr 25, 2008 | 03:11 PM
  #62
westpak's Avatar
westpak
SFZCC
not sure I would want to risk using RTV in the event it loosens and gets in the oil system then you will have bigger issues than leaky valve covers
Old Apr 25, 2008 | 03:13 PM
  #63
blasian's Avatar
blasian
I know of the risk but given that some people have done this before I figured I'd give it a shot.
So far so good its holding up.
Old Apr 25, 2008 | 03:25 PM
  #64
ByThaBay's Avatar
ByThaBay
Well I guess I'll be doing a DIY vid where I will use black RTV (for internal engine components) to simulate a new gasket instead of shelling out $$$ for new valve covers... although it's worth checking that one site I saw someone mention earlier where they saved $100... I'll have to talk to my friend and see how he wants to do it.
Old Apr 25, 2008 | 03:28 PM
  #65
blasian's Avatar
blasian
I could have gotten valve covers at cost but my thought is... it seems to be a common problem and why would I spend a few hundred bucks for it to probably come back again.
Although I could run into a load of problems if the RTV didn't hold up
My buddy works at Nissan and said he's never had a problem with there RTV breaking down so I went by his word.
Old Apr 25, 2008 | 04:04 PM
  #66
SC 350Z's Avatar
SC 350Z
to tell you the truth im goin to use rtv because the seal it self is at the bottom of the shaft that it seals or is suppose to seal but where the spark plug shaft and cover meet is where im goin to rtv that should seal it better plus then it the rtv did losen up it wouldnt make it to the engine becasue it wouldnt make it back past the seal i know that sounds complicated but im sitting here looking at my valve cover and im for sure it will work i will do it and take some pictures
Old Apr 25, 2008 | 04:08 PM
  #67
blasian's Avatar
blasian
Yeah... you really don't need much RTV for it. The gaps are really small but oil seems to find a way to seep through.
Old Apr 25, 2008 | 04:42 PM
  #68
SC 350Z's Avatar
SC 350Z
^ ill give it a try and see what happens
Old Apr 25, 2008 | 08:08 PM
  #69
Chef-J's Avatar
Chef-J
Booooosstt!!
^ hey thanks man thats a whole hundred bucks i saved buying from that site
I just received the valve covers from one of member here, i got it for pretty cheap. Well since it is common issue, so i got used ones, why not? If you want used one, check with 'jetpilot' he said he has good seal used ones.
Edit: My passenger side has no leak issue, i might sell it after i replace them. ( depends on condition)
Old Apr 25, 2008 | 08:11 PM
  #70
Chef-J's Avatar
Chef-J
Booooosstt!!
+1
Old Apr 26, 2008 | 05:56 AM
  #71
SC 350Z's Avatar
SC 350Z
if the rtv doesnt work ill get ahold of you or him
Old Apr 26, 2008 | 08:04 PM
  #72
Chef-J's Avatar
Chef-J
Booooosstt!!
yea, we'll see. Let me know what's going on bro.
Old Apr 27, 2008 | 11:23 AM
  #73
SC 350Z's Avatar
SC 350Z
took the covers off today applied the rtv and put the covers back on it will be till next week till i can start it and find out becuse i am doing some other stuff and hte car will not run
Old Nov 18, 2009 | 12:32 PM
  #74
gyotar's Avatar
gyotar
Did the RTV fix your problems? I just found oil on my plugs.
Old Jan 4, 2010 | 04:41 PM
  #75
orangeflash's Avatar
orangeflash
I have the same issue. plugs 3 and 6 were drenched in oil when i took them out? This just seems like poor engineering or something? does this happen in many other cars?
Old Jan 4, 2010 | 04:43 PM
  #76
Entaille's Avatar
Entaille
replaced my valve cover and gasket about 5k miles ago. plugs are oil free now.
Old Feb 12, 2010 | 01:52 AM
  #77
sweettalker's Avatar
sweettalker
Could this cause oil to show up on the turbine of vortech charger? Could they even make it up that far?
Old Mar 27, 2010 | 01:21 PM
  #78
cliffart's Avatar
cliffart
I just replaced my spark plugs and found oil in cylinders 3 and 6 like many other people here. My car is a 2003 with 98K miles on it. No telling how long oil has been in these spark plug holes.
I'm wondering if this is really an issue or if I need to fix the leaky valve covers. The oil isn't seeping into the cylinders and the spark plug coil seems to be potted so I'm not sure what problems oil could cause.
Has anyone witnessed performance issues with oil gathering above the spark plug?
Old Apr 6, 2010 | 08:36 PM
  #79
MadNismo's Avatar
MadNismo
same deal here. would this cause the engine to lose pressure? other than that i dont think im to worried about this...
Old Apr 30, 2010 | 01:55 PM
  #80
WhiteNoiz's Avatar
WhiteNoiz
I am also curious to see how well the RTV holds up. I have 60k, and have not changed my plugs, but I am anticipating this will eventually be something I have to deal with. I tried doing some research to see if RTV will hold up to oil, and I didnt find anything that said it would not. I did find this RTV
Permatex® Ultra Black® Maximum Oil Resistance RTV Silicone Gasket Maker
OEM specified. For dealership warranty requirements, ensures extended drivetrain warranty compliance. Fast-curing formula. Sensor safe, low odor, noncorrosive. Meets performance specs of OE silicone gaskets. Retains high flexibility, oil resistance properties through use of a patented adhesion system. Temperature range -65ºF to 500ºF (-54°C to 260°C) intermittent; resists auto and shop fluids and vibration.
Suggested Applications: Valve covers, oil pans, intake manifold end seals, timing covers, transmission pans
burglapfd
Dec 6, 2020 01:04 PM
350z82
Oct 1, 2015 06:25 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
