UTEC Molex: what are pin 11/12
Old Jan 20, 2008 | 05:26 PM
str8dum1's Avatar
str8dum1
Default UTEC Molex: what are pin 11/12
So according to the manual:
Pin 1 Ground
Pin 2 Boost Control Solenoid Output
Pin 3 Knock Light
and pPin 4 Ground
Pin 5 Remote Map Switch bit-3/Clutch Switch
Pin 6 Remote Map Switch bit-2
Pin 7 Spare Solenoid 1
Pin 8 Shift Light Output
Pin 9 Spare Solenoid 2
Pin 10 +12V Output
Pin 11 Remote Map Switch bit-1
Pin 12 Remote Map Switch bit-0
Does this mean with a trigger you can get the Utec to switch maps, say like a trigger from a water/methanol injection low level sensor?
Also, they show Pin 3 as a knock light and pin9 for spare solenoid2 but it is also used a shift light?? anyone use pins 3,8,9 for sequential shift lights?
Old Jan 20, 2008 | 06:01 PM
athenG's Avatar
athenG
I don't think Utec accept input but you can use the spare solenoid to activate your water/Meth kit though. There is also no way for it to switch map automatically so either way it is not going to work.
Old Jan 20, 2008 | 07:18 PM
str8dum1's Avatar
str8dum1
i'll call TurboXs tomorrow to try to find out what pin11/12 are for then.
Old Jan 20, 2008 | 08:48 PM
rcdash's Avatar
rcdash
There is no knock light or spare solenoid 2, but there is supposed to be a 3 signal shift light. BUT the shift light functionality is not working in firmware version 2.8. i actually went to the trouble of wiring it up, trying it, asking tech support about it - txs bench tested, and confirmed it did not work. I believe I read that the coding is BCD (binary coded decimel) for the map bits but not 100% sure...
Old Jan 21, 2008 | 05:40 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
when you add the remote map switch, it comes with a new white plug that plugs in and has wires in those spots.
what are you trying to set up??
if you are just doing a simple water meth setup, it will control it just fine...
you need to know a few secrets though that we figured out along the way if you are using version 2.8 .
Old Jan 21, 2008 | 05:48 AM
str8dum1's Avatar
str8dum1
hmm, so no dice on the shift lights or the map switching.
sheesh
i dont have much of plan of whats next, just seeing what all the UTEC can do as it options.
Secrets huh?
Old Jan 21, 2008 | 08:25 AM
QuadCam's Avatar
QuadCam
the knock light output is supposed to work with an led, but you have to make your own light.
Old Jan 21, 2008 | 08:28 AM
MardiGrasMax's Avatar
MardiGrasMax
Just an LED circuit for this to work?
NissanZcrazy
Nov 2, 2015 06:03 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
Z CRAZY
Nov 4, 2002 02:57 PM
