Oil cooler/warmer removal.............
Old Jun 14, 2017 | 08:36 AM
  #341
aarrgghh's Avatar
aarrgghh
And the crap hasn't stopped. Just pulled and reinstalled the engine as one of the dual port actuator diaphragms failed. Then a coil pack packed it in, and then it wouldn't start. Changed the starter and relay, turned out we missed the large engine to frame ground.
Anyway, the specs are on CO-27 of the FSM (the cooling system section):
Old Jun 14, 2017 | 10:14 AM
  #342
onevq35de's Avatar
onevq35de
Ah, I see. Thank you very much aarrgghh. I've been using some free-be **** I've found on a forum (infinitihelp?)for the fsm because I don't know which fsm to get. A physical copy or one of these online downloadable joints. This page, and I'm sure many others are not available, damn it.
Grounds are really important. Many don't think so, but they are.
Old Jun 20, 2017 | 02:57 PM
  #343
onevq35de's Avatar
onevq35de
There's three bolts, large bolts, that are left over from deleting the idler pulley (2 of'em) & the third that was holding the bracket for the bypass hose that connects to the pass. side hard pipe, then travels across the engine and terminates @ the driver side hard pipe.
I left the two that supported the idler pulley out but the third is so bulky. I'm assuming it's only purpose was to support one of the two brackets for said bypass hose & if so, why such a massive bolt? I put this one back in place and am hoping someone knows if this bolt is necessary, if it's for the timing chain cover or what???
Old Aug 28, 2017 | 06:56 PM
  #344
onevq35de's Avatar
onevq35de
I found that this third bolt, the lowest of the three does in fact connect to the rear timing chain cover, perhaps all three do so I put it back in, along w/the other two for ***** & giggles.
Photo of my tucked engine bay. Timing chain cover is a work in progress. JB welded the deleted hose hard lines. Original twin tube. Quick, cheap & effective.
Link to my diy wire tuck below. Yes, it's an fx35, but similar enough.
https://www.infinitiscene.com/thread...-redux.230572/
Old Dec 25, 2017 | 01:30 AM
  #345
rottingcat's Avatar
rottingcat
i cant beleive you JB welded it lol, update us if it does blow, i ordered silicone caps off mcmaster per voboys post
Old Dec 25, 2017 | 04:45 AM
  #346
onevq35de's Avatar
onevq35de
Will do, but don't hold your breath.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
Stevo Z
Oct 3, 2015 09:14 PM
